Originally Posted by Possumgirl
Very few HDTVs will output 5.1 audio except from the TV's internal tuner, so you would only get 2.0 stereo from the devices connected to the TV. I assume the Direct rcvr. and the Roku have HDMI out. Connect them to the CT150. If the DVD player has HDMI, connect that to the CT150 also. The Wii only has component video, right? If so, connect to TV and then connect audio from Wii directly to the CT150. Or you could connect audio to TV and also run optical out from TV to CT150.
If all of your audio connections go direct to the CT150, you don't need optical out from TV unless you also use OTA or streaming services from the TV.
Thanks very much!
