I just received and installed my CT150. After some experimentation with the system, the main gripe I have right now has to do with the settings on my Motorola DCX3400 cable box.
It appears that the settings frequently revert back to default. It appears to happen whenever I shut down the system (or it could be whenever I change the sequencing of turning on components).
My setup is very typical: Moto box to CT150 via HDMI. CT150 to Samsung HDTV via HDMI.
From searching this forum, I've noticed others having the same issue with the Moto box (many with Sammy HDTV's as well), but I haven't seen anyone with a solution. Is there a solution out there that I might have missed?
This issue could be a deal-breaker for me. I like having HD channels output from the box in native format, but it would be annoying as hell if that custom setting on the box never sticks (always going back to default 1080i).
Seriously, optical is optical; there's no difference in SQ between cables. Thicker sheilding does make the cable less susceptible to damage though.
