AVS › AVS Forum › Gaming & Content Streaming › Home Theater Gaming › Nintendo › Nyko Charge Station
Nyko Charge Station
post #1 of 5
Using this:
http://www.amazon.com/Wii-Charge-Sta.../dp/B000LFJNF2
Seems one of my batteries no longer charges / holds a charge. it's about 2 years old, this charger station/batteries. Do they die out after a while? If so, any recommendations for good charging unit / recharger for wii?
post #2 of 5
I have the nyko charging unit and one of the batteries died within a couple months, and the other one does not hold a charge like it use to, to me it was not worth it I regret purchasing it since I already own plenty of rechargeable ones. So, I suggest buying rechargeable AA's, they will last you longer than the nyko ones, and you can replace on the fly as you need them and not have to charge the whole controller like the nyko system.
post #3 of 5
Yeah, rechargeable batteries just die out after (hopefully) a while.
My first Wii recharger's batteries were dying out, so when I saw a good deal on the MadCatz one I have now, I got it. Unfortunately, retail price is something like $40, at the time though I got it for $15.
It's not the greatest, as it uses NiMH batteries, as opposed to the better Li-Ion ones, but what I like about it is that it's inductive, so it'll work with the sleeves on for the times I'm with family with young kids, and it also works with or without the MotionPlus.
I can see the argument for rechargeable AAs. They'll probably last longer, and they're cheaper, especially if you already have a good charger for them.
However, I just find it more convenient to have a dedicated charger. I've got rechargeable AAs that I use in a number of things, but it's a pain if I have to take out the batteries from inside the remotes and charge them, when I really already wanted to be playing. And then if you have the sleeves on, you have to take them off to take out the batteries and put them back in, and I just find having a cheap set of Wii-specific batteries easier.
And since it's just a cheap set, I don't worry about doing a full discharge-charge cycle like you're supposed to do with NiMH batteries, and put them on the charger whenever I'm done. With my good Eneloop AAs, I'd rather not do that.
post #4 of 5
Most all rechargeable batteries on the market today have a "memory" it is best to not allow them to become fully discharges and to recharge at different levels of discharge.... rotate / change the amount of play time between recharge ....and the batteries will last longer.
http://en.wikipedia.org/wiki/Memory_effect
post #5 of 5
To clarify, that's only with NiMH (nickel-metal hydride) batteries as I was implying, and not the better Li-Ion (lithium ion) battieries.
Lithium ion batteries on the other hand work better if frequently topped off.
  Back to Forum: Nintendo
