post #1 of 1
Both my laptop and PS3 are wirelessly connected via a Linksys WRT160N. Sometimes I can stream movies just fine. But other times it will stutter every 3-5 seconds and I get DNS error 2104. What should I do to fix this?
I've tried changing the transmission rate to 11 Mbps, turning frame burst off, capping the bandwidth the media server uses, and using the low quality over wifi setting. same results. I've also changed it to use only -g wifi, and changed the channel to 11 and auto. Nothing works.
edit:
okay, i just noticed that the file i was trying to stream is an mp4. all of my avi files stream perfectly. this is weird, because mp4 files used to stream perfectly. i've had the same firmware (3.15), so i don't know what else could have changed. any ideas?
