AVS › AVS Forum › Video Components › Home Theater Computers › Is there a BD-ROM with MultiRegion DVD capability?
post #1 of 5
Hi,
I am currently using a pioneer BD-ROM but is has the DVD restriction of playing DVDs from a certain region. Are there any models available which will play all regions?
Alex
post #2 of 5
You will probably find that your existing drive can play DVDs (and Blu-rays) from any region with the use of Slysoft's AnyDVD (Any DVD HD adds Blu-ray support) - assuming you are running a Windows PC. This sits between the drive and replay software and effectively strips regional encoding on the fly.
They offer (or used to) a short trial period so you can try it before you buy.
Most people with HTPCs I know run AnyDVD HD - it can also solve some tricky HDCP issues.
post #3 of 5
Thanks sneals,
I'll check that out and see how it works.
Alex
post #4 of 5
If your drive is listed here under RPC1 or RPC2 patch then you can modify the drive firmware which allows Windows to change region as many times as you like, no need for paid software:
http://ala42.cdfreaks.com/MCSE/
post #5 of 5
Hi,
Just seeing if there was an updated answer to this question.
