post #1 of 1
I'm trying to decide between these 2 options: Which would give the better image? Totally light controlled cave.
1) Designer White laminate
2) White matte material from a cheap pulldown screen. I would cut material
off and staple to a DIY frame I have. Choices are "Accuscreens" matte
white, Elite Max White, 1.1 gain. There may be a couple more also.
Would these screen materials be easy to get tight enough on frame to staple on back? Thanks.
