AVS › AVS Forum › Video Components › Home Theater Computers › HTPC - Linux Chat › HOWTO: Make a Linux OS partition backup image with Clonezilla
post #1 of 32
Clonezilla 1.2.3-27 / partition backup Procedure
This is a fundamental, NECESSARY and IMPORTANT skill for *basic* PC maintenance, security and backup, suitable for noobs for imaging partitions.
This method is as simple as it gets- just step by step point-click wizard style using only FOSS tools.
This assumes your OS was installed on one partition (/) including /home and all the other system
directories like /var, /tmp, /bin, etc.
This method further assumes you did not use LVM and used standard filesystems like ext3/4 and other common Linux filesystems, though I haven't tried this method with anything other than ext3/4.
This is why I recommend using only 3 partitions on your OS hard disk:
/ ("root", the OS partition <30GB, includes /home) (C: in Windows)
swap (1-2x installed RAM) (usually just a file on the C: drive in Windows)
the rest for data/backup image storage. (D:, E:, etc partitions or drives on Windows)
To image your / ("root" OS) partition effectively, you need to be sure the size of your /home directory is minimised.
/home is equivalent to the "C:\\Documents and Settings" directory (folder) in Windows
(XP at least- I don't know what directory structure is used in Vista/W7)
Backup (copy) files in /home to another partition or burn to DVD and erase from /home to minimise the size of the backup image. Only takes a few minutes to make an image assuming your OS (/) partition is kept less than 8GB (not counting /home contents), very easy to do.
WARNING- DO NOT erase/delete /home or any user accounts there! Backup and remove only data files- .docs, mpgs, avi's, .ppt's, .pdf's, .odt's, etc.
/home and the user accounts there contain most config/settings for apps and user settings, often in hidden files and directories.
8GB is MORE than enough for the OS, drivers and most apps most people need most of the time, as of 2010, not counting work files, settings and/or temporary storage in your /home directory.
Images of complete HTPC loads with Myth, XBMC, and a large amount of additional FOSS & commercial apps, games, Wine and Windows apps & games, will fit on one or two blank DVD's - about 50 cents for 2 quality Verbatim DVD+R blanks at OfficeMax every other month or so, or Microcenter.com. OfficeMax will price match microcenter if you have one locally.
If anything borks your OS load or / partition (like an OS or app update, driver install, kernel update, config file corruption, hard drive failure, etc) , it literally takes less than 5 minutes to restore if you adhere to these simple partition guidelines.
For routine safety images you might make before applying a kernel update, Automatic Update, or driver compile/install, making the image on the data partition on the same hard disk the OS / partition is on is fine.
To protect against hard disk physical failure, you need to write the image to DVD or another physical hard disk, like a USB or eSATA drive. You don't have to create the image on the external drive, just copy it there later.
Images written by Clonezilla are compressed tarballs (.tar.gz) files, with a bunch of metadata text files stored with it describing the partition structure for rebuild purposes. All the files are written to a standard directory/folder whose name you specify during the backup wizard in Clonezilla described below.
Nothing proprietary, obfuscated or secret about the file formats/images written by Clonezilla, unlike the commercial Ghost and Acronis imaging tools. Easy to extract or recover individual files from the Clonezilla .tar.gz's if you need them without restoring the image.
Download clonezilla-live-1.2.3-27.zip at:
http://clonezilla.org/download/sourc...-zip-files.php
Extract the .iso from the .zip (right click on the downloaded file-> Extract here)
Burn the .iso with Brasero at no greater than 8x or the lowest speed your burner/media can burn at, which might be 10x or 12x:
Application menu -> Sound & Video -> Brasero Disc Burner
Burn Image -> Select an Image to Write -> (naviagte to the clonezilla .so file you extracted earlier and select it)
Select a Disc to Write to -> (use pulldown and select the DVD/CD burner you will burn the disc in, insert a blank CD-R or -RW)
Properties -> Burning Speed -> (select no greater than 8-12x if possible, 16x absolute max) -> (uncheck "Leave the disc open...") -> OK
Burn
Reboot with Clonezilla CD-ROM you just burned in your CD/DVD drive.
Be sure to plug in your USB hard disk if you plan to backup/restore to a USB drive.
Be sure your BIOs is set to boot from the CD/DVD drive- varies by motherboard/BIOs vendor.
Hit Enter at the boot menu on the Clonezilla CD.
Default Settings, VGA 1024 x 768
Enter
"Which language do you prefer:" English->Enter
Don't Touch Keymap->Enter
Start_Clonezilla->Enter
device-image work with disks or partitions using images->Enter
local_dev Use local device ->Enter -> Enter
Mount /home/partimag
(this is the drive or partition you want to read/write the backup image from)
(use arrow keys up/down to select the drive/partition you want to write image to)
Enter
(next step selects the directory on the target drive you want to write the image to)
/top_directory -> Enter ->Enter
Beginner mode ->Enter
Select save_parts (save partition)
"Input a name for saved image"
-> (press backspace key to erase existing default name)
-> (type name for image, which will be written as files in a folder with this name.)
->Enter
I like to use descriptive names like "u904_myth_xb_oo32_100322", so when you see this image later, you'll know the OS & version and any extras you added like MythTV, XBMC and OpenOffice 3.2 in this example, as well as the creation date, which tells you the OS probably has all updates/patches through that date. Since I follow a standard OS install procedure on all my machines, described in the Ubuntu 9.04 media PC Setup procedure
http://www.avsforum.com/avs-vb/showthread.php?t=1236363
I know all the other "basics" are there- codecs, media players, apps, etc.
"Choose the source partition(s)"
-> (use up/down arrow keys and space to select the OS partition)
-> Enter
-> Enter
-> y
-> Enter
"Calculating bitmap"
(OS partition is backed up to the target you specified)
-> Enter
(1) Reboot
(2) Poweroff
(3) Start Over
(Select what you want to do, Enter)
To Restore the partition you just made, just select restore_parts and the correct target partition in the same procedure where appropriate.
post #2 of 32
Optionally, if you install to LVM partitions, you can use LVM snapshots to image entire partitions while they're live. Here's an older, yet I believe still viable tutorial: http://www.howtoforge.com/linux_lvm_snapshots
post #3 of 32
Steven Shiau has announced the availability of a new version of Clonezilla Live, a Debian-based live CD containing free disk-cloning software
This release of Clonezilla live (1.2.4-28) includes major enhancements,
bug fixes, and language translation updates.
http://sourceforge.net/mailarchive/f...ezilla-release
MAJOR ENHANCEMENTS:
* New file system support: UFS of FreeBSD/NetBSD/OpenBSD. It has been
tested successfully for imaging FreeBSD 8.0, OpenBSD 4.6 and NetBSD 5.0.2.
* New file system support: VMFS of VMWare ESX.
* 686 kernel is available in this release, so multi-core CPU is supported.
* XZ/Lzip compression, and parallel compression, pxz and plzip, were
added. You can choose "-z5", "-z5p", "-z6" or "-z6p" in the expert mode.
If your machine has multi-core CPU, please use the i686 version of
Clonezilla live then the -z5p and -z6p options are available in the
expert mode.
* Now both syslinux and isolinux are included in Clonezilla live iso and
zip file. This will avoid confusing.
BUG FIXES
* Delay unmounting the Windows partition when removing hibernation ans
page files. since the mounted partition was not aware so fast. This
should fix this "partition busy error":
https://sourceforge.net/projects/drb.../topic/3559920
* Delay unmounting the testing grub partition, since on some of the
GNU/Linux distributions, the mounted ntfs partition was not aware so
fast. This should fix this "ntfsfixboot I/O error issue":
* Improve all the scripts by avoiding use "rm -rf" as most as possible.
* "nosplash" was appended in failsafe mode and safe graphic mode so that
Clonezilla usplash won't be started by default.
* A workaround was added in prep-ocsroot to ensure module nfs will be
loaded when mounting nfs4 server.
* Some other minor bugs were fixed.
I have not tried this version yet- if the menus/options have changed, the procedure would need to be updated.
post #4 of 32
New version's steps are essentially the same as what you detailed. Thanks for the writeup.
post #5 of 32
'dd' (or a simple cat /dev/sda1 > /backups/filename.img )has always worked great for me so far!
Using tools like Clonezilla is for people who are afraid of really learning to know the power of Linux (the CLI tools).
post #6 of 32
Clonezilla actually uses dd, partclone, and many other FOSS disk utilities- it just packages them up in a decent wizard-style interface.
Even those of us experienced in CLI use still like easy GUI-like tools sometimes
Plus, the idea here is to help those new to Linux, or those who may have used Ghost or Acronis in the past.
Once they are experienced, then they can experiment with more manual methods using terminal commands. An inexperienced user can wreck their OS partition too easily with the dd command.
Clonezilla automatically handles partition resizing (if restoring an image to a larger hard disk, for example), MBR updating and boot flags, Grub updating, etc, while a simple cat or dd command does not, AFAIK.
post #7 of 32
Nice how-to, thank you. The only problem I ran into was that burning the clonezilla CD from the extracted zip file did not work. However, I was able to burn a functional disc from the clonezilla iso file.
post #8 of 32
heh... he is psychic too I came close...
post #9 of 32
Carnac sez- sis boom bah!
http://www.google.com/search?q=carna...N&hl=en&tab=iv
post #10 of 32
I moved my web files, and my OS partition shrank to under 9G... I used/tried CZ for a partition image.. the image finished before I could blink and is ~1.3G.. a tad nervous b/c it was almost like it didnt do anything.. is it really that fast? (gzip of 9G shouldn't be that fast....)
post #11 of 32
No, it should be 4-8 minutes.
Did you select the correct source/target partitions? Perhaps you selected the swap partition as the source to image? It's easy to confuse sda1/sdb1/sdc2/sdXY.
Be sure to make an image of only the OS (/) partition and not the entire drive.
Did you establish separate partitions/mountpoints for /var, /tmp, or other system dirs under / when you partitioned/installed your OS?
Before anyone b!tches about the clunky interface of CloneZilla- yeah, it could use some polish and cleanup in the way it switches from text GUI's in the wizard to terminal/commandline output which scrolls up the screen, but they are actively developing it and its all FOSS, so it should improve moving forward
post #12 of 32
Upcoming release info:
http://sourceforge.net/mailarchive/f...ewmonth=201005
Due to a NFS lockd issue, we have to postpone this stable release, and
it will take a few days to release another testing one, then the final
stable release.
I believe it will take another 1 to 2 weeks.
Steven.
On 2010/5/11 下午 03:18, Steven Shiau wrote:
> Clonezilla live 1.2.5-15 is planned as the next stable release on May
> 18, 2010
> This release of Clonezilla live includes major enhancements and bug fixes.
> MAJOR ENHANCEMENTS:
> * This release was created by live-helper 2.0~a11-1drbl1, and
> live-initramfs 1.215.1-1drbl-1 is used.
> * A version with pure AMD64 (X86-64) programs was created in this
> release. It can support large partition (e.g. 10 TB) imaging.
> * The Linux kernel was updated to 2.6.32-12.
> * Partclone was updated to 0.2.9. It has been reported that the speed
> of this version is much faster than the previous one.
> * Package memtest86+ was updated to 4.10.
> * Package syslinux was updated to 3.86.
> * Package pbzip2 was updated to 1.1.1, and it's the default program
> for running bzip2 compression and decompression in parallel.
> * Package gzrt was added.
> * Boot parameter "nomodeset" was added with vga=normal to avoid using
> framebuffer mode in safe graphic mode.
> BUG FIXES
> * VGA failsafe mode was not working.
> * A harmless warning message when running grub2 installation after
> Ubuntu Lucid is restored was fixed
> * Suppress and avoid the error message when getting data from EDD.
post #13 of 32
Steven Shiau has announced the release of Clonezilla Live 1.2.5-17, a new stable version of the specialist live CD designed for hard disk partitioning and cloning:
This release of Clonezilla live (1.2.5-17) includes major enhancements,
changes and bug fixes.
MAJOR ENHANCEMENTS and CHANGES:
BUG FIXES
* A NFS locking issue found in Clonezilla live 1.2.5-15 was fixed.
Direct Download link-
http://downloads.sourceforge.net/clo....5-17-i686.iso
64bit
http://downloads.sourceforge.net/clo...5-17-amd64.iso
Checksums-
MD5SUMS
058e9492f6179a2d5ae2e7a5b89ef493 clonezilla-live-1.2.5-17-amd64.iso
74d4323e564d36bd7483c095d7f72a9c clonezilla-live-1.2.5-17-i486.iso
2d715905887db415740cbcc04d0c0ceb clonezilla-live-1.2.5-17-i686.iso
dba3036a94e67ae15f4967c3ac4cd613 clonezilla-live-1.2.5-17-amd64.zip
39e60fa3d1ae13637f356a09b6f740f3 clonezilla-live-1.2.5-17-i486.zip
c5d81a15dd4cb09106407275632c7392 clonezilla-live-1.2.5-17-i686.zip
SHA1SUMS
cddb5bcdcb124cadbf49632db987cc18749bb319 clonezilla-live-1.2.5-17-amd64.iso
e13092b54e39227c6814057a983fad35c66e3c49 clonezilla-live-1.2.5-17-i486.iso
af899c97e53b44662373b04d963d7f3d10682987 clonezilla-live-1.2.5-17-i686.iso
88153256a24c5c9e3691da2da14e736b093881ac clonezilla-live-1.2.5-17-amd64.zip
77ce35c2b21c41117b4fd52c0cb2db0ff6d53515 clonezilla-live-1.2.5-17-i486.zip
1cb4828fae90b6a2be574045672060985c01c4ac clonezilla-live-1.2.5-17-i686.zip
post #14 of 32
Steven Shiau has announced the release of Clonezilla Live 1.2.5-35, a new stable version of the specialist live CD designed for hard disk partitioning and cloning:
http://sourceforge.net/mailarchive/m...%40nchc.org.tw
This release of Clonezilla live (1.2.5-35) includes major enhancements,
* The underlying GNU/Linux operating system was upgraded. This release
is based on the Debian Sid repository (as of 2010/Jul/20)
* The Linux kernel was updated to 2.6.32-17.
* This release was created by live-helper 2.0~a19-1.1drbl, and
live-initramfs 1.236.2-1drbl-3 is used.
* Partclone was updated to 0.2.11.
* Default to use VGA 800x600 for Clonezilla live. Since most of the
netbook does not support 1024x768, and 800x600 is the common one for
most of the computers, and it's good enough for Clonezilla live. Thanks
for swdotnet for suggesting this.
* Program prep-ocsroot was improved to work with sshfs/cifs path with
space.
* Program ocs-iso is able to create the recovery iso larger than 4.5
GB. Thanks to Zoltan Kerenyi Nagy for reporting this issue.
BUG FIXES
* An extra shift should not exist in create-drbl-live. Thanks to Orgad
Shaneh for this bug report
(http://sourceforge.net/tracker/?func...roup_id=115473).
* Programs ocs-iso and ocs-live-dev were improved to include only
Clonezilla-related files. Other files in /live/image/ won't be included.
Downloads-
http://sourceforge.net/projects/clonezilla/files/
32bit-
http://downloads.sourceforge.net/clo....5-35-i686.iso
64bit
http://downloads.sourceforge.net/clo...5-35-amd64.iso
MD5SUMS
6bd39144ab5b5ec9a4e0342a985c6ab4 clonezilla-live-1.2.5-35-amd64.iso
7f0b7152d8bf28d3184f9cad3f84ebda clonezilla-live-1.2.5-35-i486.iso
f8d48b8e046c0d49f08fb1f7f680ab94 clonezilla-live-1.2.5-35-i686.iso
1d2f57c5dae3830c64ac91c313e6723a clonezilla-live-1.2.5-35-amd64.zip
468269ca978092226d189233a6281658 clonezilla-live-1.2.5-35-i486.zip
1e911c860d13db84217b569ab8680c13 clonezilla-live-1.2.5-35-i686.zip
SHA1SUMS
4c21d8d9f6028af082e1f19ea86f3bacef0a9fe9 clonezilla-live-1.2.5-35-amd64.iso
63798d87093b17bd23701ebc0cdc257144394485 clonezilla-live-1.2.5-35-i486.iso
b3ed1a88744a37bbff59f398e114200d8ebe013d clonezilla-live-1.2.5-35-i686.iso
e24248c0f961f1676dd0ae9f7329d09566bb27cb clonezilla-live-1.2.5-35-amd64.zip
019d65a7852dd0d0efda70f64a5c82a814492814 clonezilla-live-1.2.5-35-i486.zip
f53d2515ea7f69180b33a4ae44b9f18e7c2897dc clonezilla-live-1.2.5-35-i686.zip
post #15 of 32
From
http://www.avsforum.com/avs-vb/showt...1#post19151062
Originally Posted by OtherSongs View Post
Looking at the list of files that can be downloaded for Clonezilla shows Newest Files of:
File/Folder Name________ Platform__ Size___ Date_____ #Downloads
clonezilla-live-20100903-maverick.zip 136.9 MB 2010-09-03 37
clonezilla-live-20100903-maverick.iso 137.4 MB 2010-09-03 62
clonezilla-live-20100903-lucid.zip 133.7 MB 2010-09-03 21
clonezilla-live-20100903-lucid.iso 134.2 MB 2010-09-03 55
clonezilla-live-1.2.6-18-i686.zip 126.3 MB 2010-09-03 49
clonezilla-live-1.2.6-18-i686.iso 126.9 MB 2010-09-03 238
clonezilla-live-1.2.6-18-i486.zip 126.1 MB 2010-09-03 18
clonezilla-live-1.2.6-18-i486.iso 126.9 MB 2010-09-03 55
clonezilla-live-1.2.6-18-amd64.zip 138.8 MB 2010-09-03 18
clonezilla-live-1.2.6-18-amd64.iso 139.5 MB 2010-09-03 395
( I got the info at: http://sourceforge.net/projects/clonezilla/files/ )
Q1: I assume that the above Clonezilla software only runs on a recent Linux OS machine?
Q2: I gather that i686 is intended to mean being used with 32bit OS(Linux) with CPU's that have multiple cores? (I checked www.wikipedia.org on i686 and that is hardly clear)
Q3: So does that mean that the i486 files are for 32bit OS(Linux) with single core CPU?
Q4: Why is the iso file format more popular than the zip file?
Q5: And is "amd64" files for 64bit OS(Linux)? Meaning that it will work with either an AMD or Intel CPU?
Thank you in advance
1. Clonezilla is it's own OS- it does not need or use an installed OS to run. It's a standalone bootable distro with one purpose- disk imaging/cloning.
2. Yes, i686 means the 32bit P6 architecture first widely used in the Celeron and P2 CPU's
http://en.wikipedia.org/wiki/P6_%28microarchitecture%29
When compiled for i686, 32 bit software will be optimized better and rn slightly faster than if compiled for i386. When compiled for i686, the software shouldn't run on any CPU prior to the Celeron/P2- but no one should be running less than a 1GHz P3 nowadays anyways. Multiple cores are fine with i686 like all common current AMD/Intel CPUs
3. i486 means it was compiled to be optimized for the i486 architecture, 32 bit, and should work on multi core CPU's
http://en.wikipedia.org/wiki/Intel_8..._i386_and_i486
I don't know if if would run on anything prior to a 486 CPU, but as of 2010 , why would anyone want to run any CPU prior to a P3 anyways? P2/P3's are now effectively free, so there would be no reason for anyone to run anything so slow, unless it were an embedded CPU with no choice.
DIstros are starting to compile their 32bit releases to be optimized for i486/i686 vs i386 because there is little practical reason to support CPU's going back to a 20Mhz 80386, so they are trying to get a performance boost for the later 32bit CPU architectures. Again, the practical cutoff for a daily use desktop CPU is about a 1GHz P3, and even that won't play Flash smoothly on a recent Linux distro. Hence, the real low end cutoff for a Linux desktop PC is when Flash standard def video and animations can play smoothly, which is somewhere around 1.5G single core.
4. The .iso file is set up to burn directly to make a bootable liveCD. The .zip will extract all the contents to a folder for those wishing to modify /roll their own.
5. Again, Clonezilla is not for any OS- it is an OS itself, a standalone bootable liveCD/app. Yes, AMD64 means it will work in 64bit mode for most 64bit CPU's of the last 5 years, AMD or Intel.
post #16 of 32
< various snips >
Thank you for the detailed reply; the above is what I failed to understand, and why I asked the other questions.
FWIW, it's still possible that Acronis-True-Image-Home-2010 may work OK for a clone backup/restore of a dual boot PC running Win XP/32 and Mythbuntu 10.04 (which is likely also 32 bit).
I posted about using Acronis in HT thread "Windows 7 backup program" at: http://www.avsforum.com/avs-vb/showt...8#post19089498
Turns out that with Linux Ext3 and swap partitions present, Acronis takes a minute long pause, and on the 1st try I simply did not wait long enough.
Which lead me to change the partitioning from/to:
Was:
HDD-0 (1TB) partitions:
0 2GB primary boot partition (fat32)
1 860GB extended partition (with 4 logical partitions: 70GB fat32, then approx. 340GB as NTFS (WinXP32), then Linux swap 50GB primary (I know, too big, only need roughly 2x RAM, then 400GB Linux root (" / ") as Linux Ext3 type)
HDD-1 (also 1TB) with single 900GB primary Linux partition, as /usr as Linux Ext3 type
Changed only HDD-0 partitioning (both HDD still both the same (1TB each)) to:
1 330GB extended partition (with 2 logical partitions: 70GB fat32 (unchanged), then 260GB (reduced size just to see if I could) as NTFS (WinXP32)
2 8GB primary as Linux swap
3 100GB primary as Linux Ext3 as root (" /" )
On the 2nd try I tried to see if Acronis was locked up (it wasn't), and while I was thinking about it Acronis picked up the countdown and completed.
Still not sure if I'll need Clonezilla or not; the proof of the pudding is to not only do clone backups, but to also restore, and for the end result to still work properly.
FWIW#2, I'll load Mythbuntu a 3rd time, then use Acronis to backup, then immediately use Acronis to retore from the temp external HDD. Should know by late tomorrow.
FWIW#3, I'll post some questions in your combo Ubuntu/Myth thread, as they're OT in this thread. Maybe in a day to two (or three).
Cheers
post #17 of 32
Originally Posted by omgseanrox View Post
thank you i knew searching google for awhile would help! thats why i registered for this great forum!
If this is directed at me, thank you.
But the one to thank most is Rgb, who's done many helpful threads in this forum.
BTW, I've yet to use Clonezilla, but have ordered a disc of it from www.osdisc.com and if, like me, you only have low speed internet from home, you'll find that they offer some useful Linux software on CD and DVD discs at very reasonable prices.
Cheers
post #18 of 32
He/she appears to be just a link spammer, look at his/her other posts to see what I mean...
post #19 of 32
Continuing with this, Acronis-True-Image-Home-2010 backs up (clone) and restores (clone) internal HDD to a temp HDD just fine, with fat32 and NTFS and Linux Ext3 and Linux swap. The time countdown can and does sometimes pause with Linux Ext3/swap, but the backup itself goes on is OK.
Sequence is to boot from the disc, then choose Tools/Util then Clone then Manual then Source-HDD then Target-HDD then As-is then Proceed
FWIW I got GParted-Clonezilla 2.3 ($1.95 from www.osdisc.com), and when I booted it, it asked too many questions that I didn't know the answer to, and I shut it down (reboot).
I'll retry both GParted and Clonezilla on my 3rd new PC when there's nothing to lose.
For now, Acronis-True-Image-Home-2010 works fine, costs roughly $20, and seems to me to be a much safer choice and less confusing choice for clone disk backup (internal HDD to temp external HDD).
Cheers
post #20 of 32
Stable Clonezilla live 1.2.6-24 has been released.
This release of Clonezilla live includes major enhancements, changes and
bug fixes.
release is based on the Debian Sid repository (as of 2010/Sep/21)
* New file system support, btrfs, was added in this release. It has
been tested successfully with Ubuntu Maverick beta restoration (/boot is
ext4, the rest of partitions are btrfs), and OpenSuSE 11.3 restoration
(/boot is ext3, the rest of partitions are btrfs). //NOTE// btrfs is
still in the beta status, therefore this support is in testing, too.
* Russian language was added. Thanks to Anton Pryadko.
* Program makeboot.sh was improved to allow running with full path.
* Option "--force" was added for grub-install (grub2) when it's run
with option "-g auto".
* It has been improved about running grub reinstall. If failing to
run grub2 from the restored OS, Clonezilla will next try to use the
grub2 from Clonezilla live now.
* The Linux kernel was updated to 2.6.32-23.
* This release was created by live-build 2.0~a29-1, and new
live-initramfs, i.e. live-boot 2.0.5-1.drbl1, and live-config was
2.0.6-1.drbl1 are used. Because Live-boot and live-config are used in
this release, therefore if you manage the boot paramters by yourself,
you have to put the extra boot parameter "live-config" to make
live-config to work.
* Partclone was updated to 0.2.15.
* gPXE was updated to 1.0.1.
* The etherboot boot menu was removed since it's not maintained
anymore, and we have gPXE now.
* Package syslinux was updated to 4.02.
* Usplash was removed in Clonezilla live 1.2.6-11 since it's not
available in Debian Sid.
* Due to the change from Live-boot 2.0.3, the boot parameter to
assign static IP address has been changed. The format is:
ip=**[CLIENT_IP]:[SERVER_IP]:[GATEWAY_IP]:[NETMASK]:[HOSTNAME]:[DEVICE]:[AUTOCONF]
[,[CLIENT_IP]:[SERVER_IP]:[GATEWAY_IP]:[NETMASK]:[HOSTNAME]:[DEVICE]:[AUTOCONF]]***::
e.g.
ip=10.0.0.1::10.0.0.254:255.255.255.0::eth0,:::::eth1:dhcp
BUG FIXES
* The file system header will be cleaned only when the image of the
partition exists, i.e. it will not be cleaned before testing existence.
* The bug about failing to use partclone to do disk to disk clone
was fixed. Thanks to Steve Poe for this bug report.
Steven Shiau
National Center for High-performance Computing, Taiwan.
http://www.nchc.org.tw
Direct Download
http://downloads.sourceforge.net/clo....6-24-i686.iso
Checksums
http://www.clonezilla.org/download/s.../checksums.php
MD5SUMS
e05d512bfaa593c80f74414099956ed2 clonezilla-live-1.2.6-24-amd64.iso
aefc1646941683ebc02bbe3879f8a8bd clonezilla-live-1.2.6-24-i486.iso
096ab86c61af49a29600e4434de1776d clonezilla-live-1.2.6-24-i686.iso
763ca2c1d53c73c19975b56cb27643e1 clonezilla-live-1.2.6-24-amd64.zip
7d6be6027bd622b38a30491ec15ec431 clonezilla-live-1.2.6-24-i486.zip
d047c44a771c3969ff1faaedd5b581e6 clonezilla-live-1.2.6-24-i686.zip
SHA1SUMS
94ebf8882aa164c8753b4fed097da00a35248bd4 clonezilla-live-1.2.6-24-amd64.iso
75fd43d318a767081f54c8d3acff1f62949369ad clonezilla-live-1.2.6-24-i486.iso
99b054c6472dd51f5f3b384b8939bb0a3b6a25b7 clonezilla-live-1.2.6-24-i686.iso
0c5f3bcb416481d6b82f500171d6a0cc75e00784 clonezilla-live-1.2.6-24-amd64.zip
510a4e7bf8abbadcba422421d478959643511e68 clonezilla-live-1.2.6-24-i486.zip
abfff2027f6b7cc0a2816fb65c6b7b8fd35d19ff clonezilla-live-1.2.6-24-i686.zip
post #21 of 32
Steven Shiau has announced the availability of a new stable release of Clonezilla Live, version 1.2.6-40. Clonezilla Live is a Debian-based live CD containing Clonezilla, a partition and disk cloning software similar to Norton Ghost
Stable Clonezilla live 1.2.6-40 has been released.
bug fixes.
* The shorter boot parameter "config" (was "live-config") is used
now, because live build 2.0.1 or later uses that and live-config
(>=2.0.7) honors both "config" and "live-config".
release is based on the Debian Sid repository (as of 2010/Nov/06).
* A better mechanism was implemented in ocs-live-run-menu so that
we can put all in a line in boot parameter ocs_live_run without using
ocs_live_extra_param.
* Program ocs-live-restore was improved to make it allow shutdown
the machine when using Clonezilla recovery iso/zip with "-p poweroff".
* Linux kernel was updated to 2.6.32-27.
* Partclone was updated to 0.2.16.
* Syslinux/isolinux was updated to 4.03.
* Live-boot was updated to 2.0.11-1.drbl1, and live-config was
updated to 2.0.11-1.drbl1.
BUG FIXES
* A bug about failing restoring swap partition on GPT disk. Thanks
to Bill Marohn for this bug report.
* Failed to run the command with "=" and "," in ocs_prerun. Thanks
to Jacobo Vilella Vilahur for this bug report
(https://sourceforge.net/tracker/?fun...roup_id=115473).
* The "startpar: service(s) returned failure: x11-common ...
failed" error was fixed.
* DNS query was not working in initrd.
Steven.
Download direct:
http://downloads.sourceforge.net/clo....6-40-i686.iso
MD5sums
MD5SUMS
f914367fd92bdd4f3f33d7d5fd323618 clonezilla-live-1.2.6-40-amd64.iso
14e7700dcc93f8317456ccf6470cca3e clonezilla-live-1.2.6-40-i486.iso
344de56906cc4b870dcc4342fc456e23 clonezilla-live-1.2.6-40-i686.iso
1c7ac721cc3eb0e10b04ae76387badb6 clonezilla-live-1.2.6-40-amd64.zip
0e22f63df224d917ca1ab3743021f6f2 clonezilla-live-1.2.6-40-i486.zip
cbb3e78fc2bb7dbee2f2e5260413bceb clonezilla-live-1.2.6-40-i686.zip
SHA1SUMS
524a5125e5250f1305863d31c7345a1c6a80f89b clonezilla-live-1.2.6-40-amd64.iso
92ee8fecd9e83c677391989767dcd1bda2ecd0af clonezilla-live-1.2.6-40-i486.iso
07c9984905f15e4311896a347b39f14ca1ca6134 clonezilla-live-1.2.6-40-i686.iso
6b52a83223b3fc9b305a2382d65d14666276407d clonezilla-live-1.2.6-40-amd64.zip
1013b39292421fcc3621a4cdcfe776b47b1668f1 clonezilla-live-1.2.6-40-i486.zip
8314920eb9890a45e23976a896aa0b384afd4c3e clonezilla-live-1.2.6-40-i686.zip
post #22 of 32
Stable Clonezilla live 1.2.6-59 has been released.
bug fixes.
release is based on the Debian Sid repository (as of 2011/Jan/13).
* Linux kernel was updated to 2.6.32-30.
* Live-boot was updated to 2.0.14-1.drbl1, and live-config was
updated to 2.0.14-1.drbl2.
* Language files were updated. Thanks to Alex Ibáñez López,
Zhiqiang Zhang, Gianfranco Gentili, Jean-Francois Nifenecker, and Akira
YOSHIYAMA.
* Option "-q1" (i.e. force to use dd) was added as an option in
expert mode for device to device clone. This could be useful if you want
to clone an encrypted partition.
* Another example custom-ocs-2 was added. It can be used to save
and restore dual boot systems.
* //NOTE// From Clonezilla live 1.2.6-24, if you manage the boot
parameters by yourself, you have to put the extra boot parameter
"config" or "live-config" to make live-config to work.
* //NOTE// From Clonezilla live 1.2.6-24, due to the change in
Live-boot, the boot parameter to assign static IP address has been
changed. The new format is:
e.g.
BUG FIXES
* Command "ocs-live-dev -s -d /dev/sda1" failed to copy files to
the output dev (/dev/sda1), it was using files linked. Thanks to Asou
Y.S. Chang for this bug report.
* Force to unmount image repository before rebooting/shutdowning
Clonezilla live. Thanks to Manuel Borchers for reporting this.
* The option "-j2" was not working when using restoreparts. Thanks
to dzundam for this bug report.
Steven.
Steven Shiau
Direct downloads
32bit
http://downloads.sourceforge.net/clo....6-59-i686.iso
MD5SUMS
d7d44b735c808408e6d140507d842cea clonezilla-live-1.2.6-59-amd64.iso
57777f304a0f480f7fa0dd47598fcb48 clonezilla-live-1.2.6-59-i486.iso
98a9b1b835abcbf47d9958e90f4a8149 clonezilla-live-1.2.6-59-i686.iso
cb730477c6eaea0c16481eb8c2f58caf clonezilla-live-1.2.6-59-amd64.zip
20d8b1c561663e1dcf2639f17ae83acf clonezilla-live-1.2.6-59-i486.zip
28c950c8086210fa9e31c4cfb9e41736 clonezilla-live-1.2.6-59-i686.zip
SHA1SUMS
23843210fd7757aac135c25bc7c1f2e0ac7c8ea2 clonezilla-live-1.2.6-59-amd64.iso
5c1f612b0c7121482424ef4556877abd4492c030 clonezilla-live-1.2.6-59-i486.iso
c6ae36e53467eb6c51807cfdeb0d0b2612550007 clonezilla-live-1.2.6-59-i686.iso
586325019bafac2cc42bfc667d16cca951860ae4 clonezilla-live-1.2.6-59-amd64.zip
7277b25c6bf21521890586d999abacbff3cfb7cd clonezilla-live-1.2.6-59-i486.zip
446d09064b816674e2c8fc7847f673c5078c133f clonezilla-live-1.2.6-59-i686.zip
64bit
http://downloads.sourceforge.net/clo...6-59-amd64.iso
post #23 of 32
Clonezilla only works when the destination partition is the same or larger..
if I want to move my boot partition from a 77G partition (only 13G used) on a 3.5" drive, to a 55G partition on a 2.5 laptop drive, what are my options?
ie. starting from an unformatted 2.5" drive.. what's my least painful (and safest) way to move my boot partition to the laptop drive.
I could shrink my boot partition on the existing drive, at which point I could use CZ... I'm just loathe to modify the working drive.
post #24 of 32
I tried doing this very recently using the "dump" and "restore" commands. But even after fixing up fstab to match the new drive and updating GRUB, I still wasn't able to get it to boot.
I finally just gave up and did a full install. But if you can get it to work, I'd be interested in hearing how you did it.
BTW, "dump" is not installed by default so you'll probably need to install it before you try this. Actually you really need to install it on something like a LiveCD and boot from that so that filesystem you're "dumping" is inactive during the dump.
Also, the man pages I linked to above seem to be old since they only mention ext2 and 3. The man pages that were installed in my distro claim that the dump command also supports ext4.
post #25 of 32
Current Clonezilla version seems to be Clonezilla Live 1.2.8-42
For others, see: www.osdisc.com
Is version 1.2.8-42 considered to be as stable as the slightly older version that I quoted (of you) above?
Anyhow, I placed an order yesterday for current versions of Clonezilla and Gparted and SystemRescueCD and Ubuntu 11.04
For others who depend on dial-up as I do, the disc order came to $13.70 (3 live (i.e. bootable) CD, and DVD of Ubuntu (probably bootable?)). Although I referenced osdisc.com (one order so far), I actually ordered from www.linuxcd.org (my 1st order with them) and expect to have the discs by this Fri/Sat.
FWIW, I've just gotten my 1st HDD with 4k sectors (2TB Seagate Green), and my Acronis True Image Home 2010 backup program (I only use it as a bootable disc and do NOT load it into any Windows OS), came up short on cloning it (i.e. cloning the 2nd of 2 HDD, 512B sectors to 4k sectors, and after doing a full backup of both drives a restore of the Win7/64 boot drive was problematic and required inserting and booting from the Win7/64 system disc several times in order to fix "A kernel file is missing..."
So I have renewed interest in Clonezilla, as well as doing partitions on 4k boundaries and NOT letting Windows do partitioning!
The whole thing on cloning and multi-booting (etc. etc.) and having 2 HDD on one's PC (as I do) is way more complicated than I realized. www.multibooters.co.uk/partitions.html (and it's own many internal refs) provides some head spinning info.
post #26 of 32
Redo might be a better option for noobs-
Redo Backup & Recovery is an Ubuntu-based live CD featuring backup, restore, and disaster recovery software. It centres around an easy-to-use graphical program for running bare-metal backup and recovery on hard disk partitions, as well as on external hard drives and network shares. The CD also includes several popular data recovery programs and a web browser.
http://redobackup.org/
post #27 of 32
I ran into a situation yesterday where I kept getting an error "(Standard_in) 1: syntax error" after it finished calculating bitmap on a disk that had more than enough free space. Turns out it was some sort of inode issue and I had to go through the advanced options and turn on the "-fsck-src-part" option.
post #28 of 32
Clonezilla live (1.2.9-19) includes major enhancements,
http://sourceforge.net/mailarchive/m...sg_id=27852490
is based on the Debian Sid repository (as of 2011/Jul/22).
* Linux kernel was updated to 2.6.39-3.
* Partclone was updated to 0.2.24.
* Pbzip2 was updated to 1.1.4.
* Brazilian Portuguese language was added. Thanks to Marcos Pereira da
Silva Cruz .
* The samba file system with hidden share now can be assigned in boot
parameter "ocs_prerun". Thanks to nottaken37. (Ref:
https://sourceforge.net/projects/clo.../topic/4589215)
* Xz compression instead of gzip method was used when making squashfs,
therefore the Clonezilla live iso or zip file is smaller by ~ 31 MB.
* Program prep-ocsroot was improved to make mounting sshfs with an
account name including white space.
* Remove the option "-b1024" for pbzip2 since the unit is 100K, -b1024
will use 1024*100K per thread, and this might cause system to crash due
to out of memory for multiple cores. Without the option -b, the default
value will be used. Thanks to Telligent for the bug report
e.g.
BUG FIXES
* A bug about failing to do disk to disk clone was fixed. Thanks to
seagate-wdc for reporting this issue, and others for helping to confirm
the issue and testing. (Ref:
https://sourceforge.net/projects/clo.../topic/4589758)
Steven Shiau
Public Key Server PGP Key ID: 1024D/9762755A
Fingerprint: A2A1 08B7 C22C 3D06 34DB F4BC 08B3 E3D7 9762 755A
ISO's-
http://downloads.sourceforge.net/clo....9-19-i486.iso
http://downloads.sourceforge.net/clo...9-19-amd64.iso
post #29 of 32
Just a FWIW update.
I've 2 HDD on my various PC machines.
I installed Debian 6.0.3 on the 1st HDD (swap and ext3) with a working WinXP/32 PC.
Worked great.
I then backed it up (HDD to HDD clone via Acronis 2011) and while the grub menu still is OK, only the WinXP/32 still works.
So I'm back to cloning the #1 HDD via clonezilla.
Still haven't done it yet so it remains an open question. Acronis 2011 is roughly twice as fast for cloning my bigger #2 HDD (which only has NTFS and FAT32) so I'll continue to use it for that.
post #30 of 32
Stable Clonezilla live (1.2.12-10) Released
This release of Clonezilla live (1.2.12-10) includes major enhancements and major bug fixes.
* The underlying GNU/Linux operating system was upgraded. This release is based on the Debian Sid repository (as of 2012/Jan/27).
* The Linux kernel was updated to 3.2.1-2.
* Partclone was updated to version 0.2.45.
* Syslinux was updated to 4.0.5.
* A better mechanism was implemented in ocs-update-syslinux. Only when the files to be updated are found on the system "syslinux -i" will be run.
* A better mechanism was implemented to keep the MS Windows boot reserved partition size when option "-k1" is chosen.
* A better mechanism to deal with UFS partition in a GPT table when saving FreeBSD 9.0.
* An option to use "autoname" to create the image name was added. Thanks to encephalophone (Mike) for the patch.
* An option (-icds, --ignore-chk-dsk-size-pt) to skip checking skip checking destination disk size before creating the partition table on it
was added. Thanks to Sartoratti Lorenzo for reporting this issue.
* Option -z7|--lrzip-compress was added for Clonezilla to use lrzip to compress image.
* VMFS3 and VMFS5 support are separated, no more mixed because partclone.fstype from 0.2.45 now can tell them. Since vmfs5 support is still buggy, disable it in drbl-ocs.conf.
* A mechanism was added to avoid saving an image for an unmatched GPT and MBR partition table disk.
* //NOTE// From Clonezilla live 1.2.6-24, if you manage the boot parameters by yourself, you have to put the extra boot parameter
* //NOTE// From Clonezilla live 1.2.6-24, due to the change in Live-boot, the boot parameter to assign static IP address has been
ip=**[DEVICE]:[CLIENT_IP]:[NETMASK]:[GATEWAY_IP]:[NAMESERVER]
[,[DEVICE]:[CLIENT_IP]:[NETMASK]:[GATEWAY_IP]:[NAMESERVER]]***::
e.g.
ip=eth0:192.168.100.1:255.255.255.0:192.168.100.254:8.8.8.8, eth1:192.168.101.1:255.255.255.0::
BUG FIXES
* An issue about PXE booting on a machine with multiple network cards has been fixed.
* An issue about the unknown slow execution after an image is restored 100% has been fixed.
* /live/ and /live/cow unmounting error or warning messages are suppressed when rebooting or halting.
* Serial console did not have tty when live-getty and console boot parameters are assigned. Thanks to Shuras for this bug report.
* A problem where failing to reinstall grub1 for the restored OS was fixed.
* A problem where grub2 failed to be restored along with Fedora 16 due to a different grub2 boot directory, /boot/grub2/, was fixed. Thanks to Robert Weir for reporting this issue.
2012-01-30 05:47:09 PST by steven_shiau
Downloads
http://clonezilla.org/downloads/stab...-zip-files.php
  Back to Forum: HTPC - Linux Chat
