Originally Posted by mdavej
In this case, I believe the OP is correct about having to start over. Myharmony is a separate site, with a different login and config. The stand-alone SW and members.harmonyremote do share a common config and login. The OP will have to start over, but will at least get all advanced capabilities back when he's done. I've used all three with the same remote, and that's what I've found.
The sad thing is myharmony will probably eventually replace the old site and old SW and everyone will be stuck with doorstops. I wish logitech would get off this track of dumbing down all their products. It was fun while it lasted, but soon harmony won't be an option for advanced users any more. They're slowly destroying their whole line, one model at a time.
I got a new Harmony 650, and connected it the way the manual said which connected it to myharmony.com. I couldn't get all of the settings to match what I was reading on the internet and later downloaded and tried the standalone software. A few days later I wanted to try another setting and the software started giving me the "unable to display content" error. After internet searching I found that most people needed to contact support to get this resolved, so I sent an email. This is the response that I got:
"Our engineers just created and launched the web interface because some of the computer-based Harmony Remote Software accounts for our remote models Harmony 600, 650 and 700 do not work as well with the software interface, as you have seen.
If you continue to manage your Harmony 650 remote using the web-based interface at www.myharmony.com, you should not get any more "Unable to Display Content" messages when you go to view your devices."
It seems that they are saying that their standalone software is not very good, and the website access is the new thing.
