Yeah. You want the business end of the next gen transmitter as close to the business end of the IR LED driver circuit as possible. So one side / orientation may be better than another. It's also possible that every position is just too far away from that circuit to work well. Usually the processor in a remote is centrally located and is therefore close enough to the batteries for the next gen to work. I have no idea where the processor is in a 700.
I wouldn't expect the battery type to make any difference. But I suppose it's possible the higher voltage in alkaline batteries could make the signal a little stronger. You just have to be careful to remember never to attempt to recharge the 700 if you put regular batteries in it.
LOL J/K
