Originally Posted by WiseUp
Yes, the 650 does support Macros, in a limited fashion. They're just not called macros, they're called sequences. Under an Activity, select "Customize Buttons", then Click "Add Sequence" at the bottom left. You can build a macro with up to five steps, and it can only involve the devices included in that activity.
I believe that sequences are only available in the 650 if you use the Harmony client software... if you use MyHarmony.com, sequences are not available.
As far as I am concerned, MyHarmony.com is worthless, but if a new-to-Harmony user starts out with a 650, they unfortunately may not even be aware that the client software exists.
