AVS › AVS Forum › A/V Control & Automation › Remote Control Area › Official Logitech Harmony 650/600 remote thread
Official Logitech Harmony 650/600 remote thread - Page 26
post #751 of 862
Originally Posted by jmborah View Post
Hi All, just stumbled upon this forum in my frustration with my Harmony 650. I have 1 main gripe which I would like to fix, and other minor gripes about this remote. Like others, I was very excited about being able to "program" my remote, but once I tried to use logitech software to solve specific problems I found that the cookie-cutter approach they use to script activities is really annoying.
Main gripe: I am able to set each "activity" to use TV volume, but I would like to override device volumes as well, to make TV my master volume no matter what device or activity I am on. For example, if i am on my apple tv device, the remote does not use the TV volume, in fact the volume does not work at all on that device because there is no volume associated with apple tv. I mean, come on logitech, really? So basically I'd like to make TV vol my master vol.
MInor gripe: When I switch between activity it must turn on devices that are already on, usually turning them off. Again, come on logitech, really? Part of this is due to the fact that I can not disable TV on the activity because then I would not be able to control the volume later on, so it therefore can not be removed from the activity startup script. So my gripe has to do with the limited definition of devices associated with activities and lack of control over scripts and what devices/buttons can be programmed.
I would also like to add 2 more devices to my 650, but that's my own fault for not anticipating additional hardware when I bought it.
I searched for hacks, but did not find anything I could figure out on my own. I don't know how to compile, so concordance is over my head.
I apologize if these issues were previously covered in the thread, but I wasn't able to read through the entire 25 pages. Thanks in advance for any help or advice.
-Jon
The problems you are having are due to user error and have nothing to do with Harmony software. If you want to control your TV volume from a particular device page then just teach the command to that device from the original TV remote and assign it to any button you want.
If you have devices turning off when they should stay on then there is something else wrong with your setup. I would suggest deleting each activity and start over just answering the questions correctly. When you are done and everything turns on and off properly, then you can tweak the settings and commands to your liking.
There is no "hack" for adding more devices but you can simply teach commands from any IR remote to a device that is commonly used in every activity, then assign those commands accordingly. Example: If I wanted to add a Roku to my remote I would go into the AVR device/learn commands/learn new command/ rename it "Roku Up" then teach the command from my Roku remote. This new command named Roku Up will be in the command list on your AV Receiver, so any activity which uses the AVR will have that command available (repeat for all Roku commands). Now you can just create a "Generic Activity", rename it Watch Roku, add the AVR and viola, there are your commands.
post #752 of 862
I don't have a need quite yet, so I have yet to try it ... but this is probably the best explanation I have seen yet to getting around the 5 Device Limitation on the 650. Also, fits with my experience with Harmony over the years ... 95% of normal usage is Activity based.
post #753 of 862
Exactly. My best advice to new users is "Don't be afraid to experiment with the Harmony Desktop software". Setup some Devices and Activities and explore. If things don't go quite right, tweak or delete and try again.
I have yet to find any use-case that doesn't work. I think I now know the software pretty good, but it does take some getting use to. The Auto or Wizard stuff does sometimes get in the way of me just wanting to do things manually. So, you use the Auto and then tweak.
Edited by Tesla1856 - 1/20/13 at 6:37pm
post #754 of 862
Originally Posted by willstuh View Post
I got the Harmony 650 and just finished setting it up. Everything works fine except for volume up, I set it so that it controls the volume on my Comcast box. So far all the other buttons work including volume down, its just up that doesn't. Any ideas?
Still can't get volume up to work...
post #755 of 862
What does your equipment config look like?
Usually, Volume is controlled by Amp or TV (where ever the speakers are connected). Digital audio from the DVR is usually "fixed".
Not saying the DVR can't be volume (and Harmony should be able to emulate the discrete remotes) but I can't think of a use-case where it's required these days. Are you still using analog 2-channel sound from DVR?
post #756 of 862
I've had cable boxes with variable output levels you could change from the remote. So this isn't unusual, but it is the wrong way to control volume for many reasons (reduced dynamic range, noise, overdriving input circuits, etc.). Willstuh, you really need to set the cable box volume to an optimal level and forget it. From now on, control the volume of your TV or stereo or whatever device is actually driving your speakers, not the input source like your cable box.
After you fix that, go thru the wizard for your Watch TV activity again and pick TV or AVR for you volume control device, not the cable box itself. If your vol buttons still don't work, go into customize buttons and make sure the vol up and down commands are assigned to the vol buttons. Also understand that in cable device mode, volume controls probably won't work at all. This is normal. Volume punch thru is only done with activities, not individual devices.
post #757 of 862
I set the remote to control volume from the DVR, not the TV since the remote only has 1 volume control. So literally everything else on the remote works on the DVR like guide and channel and menu, including volume down. Its just up that doesnt work for some reason.
post #758 of 862
Why control volume from the dvr at all? As was said, that's a poor way to control volume. Use the tv if that's what drives your speakers (and consider getting an avr for better quality down the line), I believe the setup programming give the option easily enough. You can still use the dvr to control other things. Pay attention during the setup routine, don't necessarily go with the default option...
post #759 of 862
Well, since you quoted MY post, I guess it's my job to answer your question.  smile.gif
You go into the DVR Device and "Learn" the Volume buttons from your existing DVR Remote. This will Over-Ride the programming from the Harmony Database. It will then work the way you wish.
You never answered my question about your equipment, so I can't help you set it up right .... the way I and the other posters are trying to help show you. One day (I'm thinking when you add a second component to your setup ... like maybe a DVD or Blu-Ray player) please come back here and finally try to understand what we were all trying to tell you... to help you with in the long run.
Edited by Tesla1856 - 1/24/13 at 12:56am
post #760 of 862
Nothing I can't live with, but these ... and the current official Harmony line-up ... kinda makes you wonder what is going on over there.
I wish I would have been wrong.
http://www.pocket-lint.com/news/49477/logitech-selling-off-harmony-remote-dissapointing-q3
Hopefully, the transition will be seamless.
post #761 of 862
Great news :-)
post #762 of 862
Not unusual to have the problems you encountered...often after you set it up on the computer
you find the remote still does not respond as you thought it would
post #763 of 862
I just ordered one of these. My first high dollar universal remote. Wellll, kind of high dollar biggrin.gif Cant wait to try to set it up. I tried setting up the remote that came with my 1122-K last night and that didnt work out to well.
post #764 of 862
post #765 of 862
It's a logical device, so "as you thought it would" doesn't mean the fault is with the device smile.gif. There's a few things you have to keep straight with these and keep it straight as to which activity/device you started off with as to where it can take you....mostly they work great. Only real problem I have is with the HDMI-CEC crap in each different device (i.e. tv vs avr etc ) fighting each other.
post #766 of 862
If anyone is having trouble controlling the volume of one device while an activity is set to another. Try adding additional devices in the activity. I was able to utilize my Roku with volume through my TV, BUT I set up another with Roku with volume through my receiver. Once you have the extra devices added you can go to edit buttons and drag/drop what you need. Learning also fixes it, but sometimes during the fine tuning process you can use the web interface. Maybe with this and others' replies it will help you. It really is a great remote and after I've gone through so many over the years, I'm sticking with this one. There is so much adjustment that none of the others seem to have allowed me, and add the long battery life we have a winner. My wife can even use a universal remote now for the first time!
I've started to review simply products on my own now, starting with this one that I own... take a look, maybe someone you know can get something out of it. That is my hope because other than these boards, there isn't much information for the average person out there.
http://thecreativealternative.com/logitech-harmony-650-remote/
post #767 of 862
Just picked up a new 650 to replace an old Harmony than fell apart. I "imported" my settings from my old Harmony, and though they are all correct I am experiencing problems with the main activity buttons working properly. Example, I click "Watch TV" and the DVD player goes on but the TV doesn't. Reset the commands manually but it is still happening.
Anyone else have similar issues with the 65?
post #768 of 862
You updated the Harmony model number?
post #769 of 862
I've never done that before. I have 2 Harmony remotes, but I use 2 different accounts.
If LovinTheHD's suggestion doesn't work, try deleting the Activity and recreating it (it only takes a few minutes).
post #770 of 862
Hello all. I'm in the market for a universal remote for our bedroom. We have a much more in depth system downstairs that we use a Harmony 1100 for and have never needed any other remote. We just upgraded the bedroom setup to a Samsung UN40ES6100 Smart TV and BD-E5400 BluRay player along with a Comcast HD cable box. I'm not looking to over complicate or over spend here since it is just 3 devices and we use this setup for less than 20% of our TV/movie viewing. The TV remote controls the BD just fine since they're both Samsung but we've found we constantly have to go back to the cable box remote for various functions and ease of use. I'm looking at getting the Harmony 650. It seems like a great value to me and reviews are okay, (better reviewed than our Harmony 1100 that we love). I just have a couple questions for you guys before purchasing.
1-Looking at the TV remote, there are three buttons on the remote that are not found on the 650 that I worry will complicate things. One of the buttons is the "Smart" button that takes you to the apps/web interface on the TV. This is one of my most used buttons and don't want to have to scroll through a bunch of soft key button selections on the 650 to get to this button. Another button is the "Tools" button. This button goes to commonly used functions on the TV like Video/Audio modes and, more importantly, the sleep function that we use every night since it is a bedroom TV. The third button is the "Search" button. Again, part of the smart TV interface. I don't really use it all that often since I find web surfing using a remote control to be cumbersome, especially when my iPhone is typically sitting on the nightstand and is much faster and easier to navigate with, but I would still like the option to be there. Will it be easy enough to program these into every day use and have the buttons readily available?
2-The only other component that may be added into this system in the future would be a sound bar which would probably have a remote control to change the volume levels. Do you see any issues incorporating an IR controlled sound bar with this remote?
Here is a picture of our setup and the Samsung remote with the buttons in question circled. Prompt advice would be great as I'm hoping to purchase today and BB closes in a few hours. Thanks in advance.
Samsung remote:
Our system:
post #771 of 862
1. I have a Samsung TV also and although I use the soft keys for the functions you mention I don't see why you couldn't assign those functions to the Hard red, green, yellow, blue buttons on the 650.
2. Don't know about the soundbar.
post #772 of 862
Harmony 650 should work fine. It will handle up to 5 devices. Programming will be similar to Harmony 1100.
1. You can manually "learn" those buttons if they don't show up on the devices you add. You can assign them to the little LCD screen or one of the 4 colored buttons. They can then be added to the "Watch TV" Activity.
2. You can add a completely custom Device (if not available in database) and learn the buttons. It can be included in multiple Activities (Watch TV, etc.).
post #773 of 862
Thanks guys. Gonna head down to BB I think. Hopefully the wife isn't too opposed. smile.gif
post #774 of 862
After having the Harmony in the Living Room for a couple of years ... When I setup the system in the Workout Room (with older/spare gear), my wife was the one that suggest I go get a Harmony for this room also.  smile.gif
Attempting to go back to using 2 (and sometimes more) different remotes was unacceptable to her now.   cool.gif
post #775 of 862
That worked - thanks for the suggestion.....!
post #776 of 862
Is there a way to set the brightness and length of time the backlight is on? Just got just remote yesterday. It was easy to set up.
Also, is there anyway to download icons for your favorite channels? Without having to download all the pictures you want and then resize all the images? Thanks.
post #777 of 862
Iconharmony. Donate if you can too. Great free database for Harmony icons.
post #778 of 862
So am I understanding this correctly that there is no way to hit the watch TV button, which will make the TV and receiver come on instantly, then set a delay (5 seconds or so) and then the cable box come on? The reason being, my receiver doesn't like to be turned on after the cable box is already sending a signal. Thanks.
post #779 of 862
Pretty sure I saw that (delay to turn-off). I think there is only one brightness. It's all in a separate place.
post #780 of 862
Be sure the cable-box is last in "turn-on order" sequence (that might be enough). There is a place where you can set custom events on Activities, (and set custom delays) ... but I'm not sure power up delay time is one of them.
  Back to Forum: Remote Control Area
