An Aspen Woods Theater. - Page 4
post #91 of 134
Originally Posted by JamesB77 View Post
I'm not really looking forward to getting back in there to hook up the subs. It was hot and eerily quiet. Plus, I didn't put an access door in so I'll have to contort myself through one of the driver openings.
Don't get stuck - In all seriousness make sure someone knows you are climbing in there - just in case. It would also be nice to have someone in the room to hand you stuff. You could install the subs with the driver baskets mounted inside. Would make things a bit easier.
I had to climb inside of mine and even with a fairly large access door it was not very fun in there. Just make sure you get the impedances and polarity right the first time. It would not be fun to climb in there again to re-do something. It would be really easy to mis-wire something in a dark place with no room to move around.
post #92 of 134
Thanks for the advice. I built the boxes so I could mount the drivers from the theater side. However, the mounting holes aren't drilled and I want to use huricane nuts. I'll have to line up the drivers and drill the holes from inside the manifold, then crawl inside and secure the nuts and wiring, then mount the drivers. Fun times ahead.
post #93 of 134
I was going to use hurricane nuts from parts express to mount my drivers but there was not enough space between the holes and the driver cutout. I ended up just using screws directly to the wood. The lack of space is why most people end up resorting to some sort of clamping mechanism.
post #94 of 134
I'm not sure if it's there or not, but you should use a cable connector where the NM enters the box.
These are pretty low profile:
I'm diggin the IB setup..
Tim
post #95 of 134
Mr. Tim - Maybe you are referring to the sconce boxes - if so disregard this: If the wiring needs to penetrate the box (manifold) it needs to be completely sealed off. Those connectors are for a punchout on a metal box and would allow too much air to move through. I don't see why you couldn't drill a small hole slightly bigger than the wire and then seal it off. I cant see how the connectors would be required - you don't need them in the walls when speaker wires pass through holes.
post #96 of 134
Sorry, I changed tracks midway (thus why I have been working on my theater for about 3 years)
I was referring to the electric sconce boxes.
Tim
post #97 of 134
Tim
Thanks Mr. Tim, I totally forgot about them. I shall pick them up.
post #98 of 134
Hmmm, I didn't think there would be a problem. I'll have to investigate further. If they don't work I'll just do what you did and use screws.
post #99 of 134
Work continued in the theatre over the weekend. We got the rest of the OSB on the ceiling, finished boxing in the beam and continued on the walls.
Before we could get much further on the walls we had to box in the window.
I found out whilst framing the plug that the framing around the window which the builder put in was not square, nor was it the same size as the window. In order to get the plug to fit properly I had to split it in two. I framed the two with 2x4's and used a piece of 3/4" MDF on the side facing the window. These were spray painted black.
They were then installed with a few screws
And stuffed with 3 layers of insulation.
This is the room now. I have two sheets to install to finish the back wall, the back soffit and left side wall to finish.
post #100 of 134
Hi guys,
I need a bit of help sizing wide throw hinges. I have a Masonite Safe & Sound door, Not sure if it's 1 3/8" or 1 3/4" thick. To this I'm adding a 1/2" sheet of MDF, and then the 1" sound material.
Standard hinges are 3 1/2". So to get the wide throw hinge I need would I just add everything up, adding 3" to the size of the hinge? I would then use either a 3x6 or a 4x7 hinge.
Am I on the right track?
post #101 of 134
Hi guys,
You are kind of on the right track.
4x4 is typical for a 1-3/4" thick door; 3.5x3.5 for a 1-3/8" door.
The problem with using a regular hinge size to address this issue is you would need something like an 8x8 hinge. On a 8x8 hinge the two rows of holes are at least an inch apart, which would not hold well in a 1-3/8" door.
I think what you really want is a wide throw hinge.
post #102 of 134
Thanks Mr. Tim,
I just checked the thickness of the door and it's 1 3/8". So if standard is 3.5x3.5 and I'm adding 1 1/2" I should need 3.5x6.5 which they don't make. I think I'll add a 3/4" sheet to the door and use a 4x7 hinge.
post #103 of 134
Should work; there are templates online from most major hinge manufacturers. I would just make sure everything is going to line up. I think it should with a 4x7 hinge.
Tim
post #104 of 134
Finally, time for an update. So – what has gone on since the last time I posted? Summer has come and gone, the1 year mark of the build has passed, and a little bit of work has been done.
What’s been done:
The rest of the OSB was installed as the first layer
Insulation was installed in the rest of the basement
The equipment room had some work done in it. All of the telephone/Internet/TV connections have been moved here from where they were beside the electrical panel.
I also added a cool cube just in front of the rack to take hot air away.
Then we started installing the drywall. 5/8” in the theater and ½” everywhere else. Obligatory green glue shot.
It took us 5 days over two weekends to install all of the drywall. 2 days for the theater and 3 for the rest of the basement.
After the drywall was installed everyone needed a break and I was going to use this time to get the seams mudded and taped. Not much was done until half way through November. However, I did start a bit of work on the doors. My plan is to add a ¾” piece of MDF to both of the doors in the theater. Because they are panel style doors I wanted to fill in the detail. My first attempt was to use Great Stuff foam. I filled the panels and let it cure.
Then trimmed it flush.
This didn’t work as well as I’d hoped. I will make sure all of the gaps are filled with green glue before putting on the MDF. For the second door I decided to use some left over acoustical sealant I have. I filled the panels again and left it to dry. This worked much better.
In September and October I had called a few contractors to get some quotes for mudding and taping. For various reasons I couldn’t find anyone to do the work so decided to do it myself. My parents have been giving me tones of help with installing the drywall and mudding/taping which I am very grateful for. We started in the theater since most of the walls will be covered it till allow us to hone our skills. Again it took us 2 weekends. The first for the tape coat, the second for the second coat and 2 coats of primer.
Then I painted the front wall black.
The theater will be taking a break again until after Christmas as we concentrate on getting the rest of the basement ready for paint.
post #105 of 134
I haven't been able to get much done in the theater for a couple of reasons.
1) I wanted to get the non-theater side further along than it was
2) I decided that with the few changes to the plan that I've done since I had bpape do my accoustical design that I would have someone re-visit it. I got in touch with SierraMikeBravo and am went ahead with the Pro-Theater Layour Service that is offered. I did this to accomplish a couple of things. I wanted to make sure all of the planning I did on my own was correct - or close to it. I wanted a design to be able to utilize the riser as a bass trap, and I wanted to get the best possible sound from the room using more diffusion and taking into account the interior design of the room.
Since I needed to give Shawn all of my ideas I did up some quick drawings in AutoCAD with my ideas. So - here they are.
Front
Right
Back
Left
I should get the plan back from Shawn some time next week and I should be almost fininshed on the other side about the same time which means work on the theater can begin again.
post #106 of 134
Work is progressing in the basement, just not on the theater. As you can see below, the theater is a bit crowded at the moment with saws, tools and other stuff from the build. I'm sure most of you know this but cutting trim inside makes a heck of a lot of dust. whilst it's not quite as bad as drywall dust, it's pretty close. I would highly recommend a dust removal system if you are thinking of doing any cutting indoors. I have a Harbor Freight dust collector on order that I will be hooking up soon. Sorry for the image quality, I tried using my iPhone with the flickr app and it didn't work very well.
Continuing from the last update, we spent weeks doing 3 coats of mud in the rest of the basement. Generally it would take a weekend to get one coat done. Saturday morning we would sand the previous coat of mud and then start the next coat. That coat would be finished on the Sunday. After 3 coats we primed the walls with 2 coats of new drywall primer/sealer. Then we took one of the work lights and inspected the walls filling any holes or gouges we found. Then it was time for the first coat of paint followed by another inspection. That left the room looking like this:
I started with the windows, boxing them in with 1/2" MDF and putting the casing up.
Then moved on to the rest of the molding.
post #107 of 134
Work has been moving along in the theater and I have a new dust extractor.
I’ve also done a bit more work on the doors – adding green glue and a layer of ¾ MDF to the solid core doors.
In the equipment room I’ve built the stair. This is the equipment room looking away from the door. The square bit that’s framed in the ceiling on the right hand side is where the rack will go.
Here is the entrance to the room and the stair framed. On the raised sections at the back and along the right side will be book shelves for DVD/CD storage.
post #108 of 134
Riser
To begin proper work in the theater we stated with the riser. It’s fairly large and runs the width (16’) and almost half the length (just under 10’) of the room and was framed using 2x12’s for the perimeter and 2x6’s for the joists. The plan is for a second row of seating as well as a small wet bar.
As it worked out a 2x12 would have been perfect height had we only been using 1 layer of sheeting for the floor. Since we were using 2 layers the first thing we had to do was rip the 2x12’s down by ¾” to accommodate the first layer of sheeting.
Then we could start framing.
Framing finished with roofing felt underneath.
The riser has wiring for 2 receptacles in the face, 2 in the floor for the chairs and another one in the face for the stair lighting. I’ve decided to do something similar to mcasio and use led rope lighting under the stair tread lip to light the stairs. I’ve also run a 1 ½” conduit to the equipment room. In the theater side I wanted a bit more room to be able to pull and hook up wiring that came through the conduit. I picked up a 4x4 box, an extension for a dryer/range receptacle, and a couple of cover plates.
The size of the box and extension work really well together so I drilled holes in the extension and used the included screws to attach them together. A hole was drilled at the back of the box to accept the conduit and the unit was attached to the framing of the riser through the extension box.
To insulate the riser we first had to figure out how to keep the insulation up in the 2x6 bays and not slipping down over time. We did this using string. The sting was pulled tight and attached to the bottom of the 2x6’s using staples. Then we stuffed the cavities with insulation and glued and screwed the first layer of ¾” t&g plywood.
A layer of Greenglue was spread and the second layer of sheeting added.
After a weekend’s work we had a completed riser. The 2 squares you can see are for a couple of plumbing clean outs that are in the concrete. These are just screwed down and are easy to remove should I ever need to access one of the clean outs.
post #109 of 134
Stage
The stage was next. Because I am not putting any speakers on the stage I didn’t build it as beefy as some of the others that have been built on the forum. It’s framed with 2x10’s for the upper bit and 2x6’s that were ripped to 4.5” for the stair. The speakers are already sitting on sand filled boxes so the stage was filled with insulation and only 1 layer of plywood used. I kept everything ½” from the walls but because of the light weight had to attach it to the floor.
Here is the plan I used. Instead of drawing an arc in the theater and matching the framing to it I did on the computer. Each 2x10 had a measurement for the long side and the short side. I cur the angle on the mitre saw and attached 3/8” plywood to give me the curved face.
Completed stage.
post #110 of 134
Really sweet job, James! It's really coming together nicely. Two questions - what are the little notches in your recessed speaker boxes for - Speaker wire? And in your riser construction you have some horizontal 2x6 framing that stops short of the main riser rim joist - is that for floor-mounted bar diffusers to use your riser as a bass trap? It appears so, but just curious.
post #111 of 134
Hi Tim - thanks, it's nice to be finally able to work on some theater related aspects of the basement. As to your questions:
The little notches in the speaker boxes are for connecting the speaker wire. Originally I was going to try and build my own in-wall surround speakers and wanted to be able to use as much depth as I could. I thought I would put the speaker terminals on the side to be able to connect them easily. I'm now not sure if I will build them myself or buy them.
I think you are talking about the horizontal framing that is shown best on the picture showing the string support for the insulation. Yes this is for a slot diffuser. It's the best way I could come up with to support everything but still maintain an airspace under the riser for bass trapping. I've covered everything over for now and will come back and cut the holes for the diffusers when I get a better idea of where they will be.
post #112 of 134
Thanks. Did you select the slot diffusers you will be using? It's a bit too late now, but I found there were many different options, each with their own support / structure needs. If it's just a metal cover that overlaps the carpet then no big deal, but if you are going for one of the flush diffusers then there is a bit more carpentry involved.
Have you found a place you are sourcing the diffusers? I checked into a local place that distributed Nailor....OUCH!!...almost $300 each for 4" x 36"....and I needed three!mad.gif
post #113 of 134
Haha, you know what - I haven't even looked into it. I assumed they were just like registers and they would slide into a slot. I was holding off on choosing them because I don't know exactly what size I can fit. With the columns on the sides and back and the bar at the back I don't have a ton of free room around the perimeter. I may only be able to fit 3 foot lengths. Even though they are much uglier I may have to go with standard floor registers.
I'm glad you mentioned the price of the Nailor's - I am thinking of moving the HVAC supplies at the front of the theater to be in the ceiling instead of bringing them to floor level. I'm going to have to investigate this more.
post #114 of 134
Check out this first link in particular. Seemingly the best deal going and fully customizable as to what you want (within reason):
http://www.hvacquick.com/products/residential/Grilles-Registers/Bar-Linear-Grilles/Dayus-Bar-Linear-Grilles
http://www.beaux-artes.com/products/arts_crafts_grilles.html
post #115 of 134
Thanks for the links Tim. Those are much more reasonable options for grills in the riser.
post #116 of 134
Over the weekend I got a bit more done. The soffits were started by running 2x2's on the ceiling. Since I'm now painting the ceiling I had a bit of touch up work with the drywall mud to do. The speaker alcoves and sub manifolds at the front were caulked and painted and I was finally able to place the speakers back in and hook them up.
I have a question about HVAC I'm hoping some one can answer. I've decided to take Shawn's advice and move the supplies at the front of the theater to the ceiling. Originally I had two 6" supplies with the standard 3x10 register covers on them. I think I have 2 options.
1) leave them as is using residential covers.
Advantages to this - cheap and easy.
2) replace them with a linear bar diffuser.
Advantages - better looking - possibly quieter.
Are there any other advantages to one or the other I'm missing?
If the decision is to go with the linear bar diffuser is there an easy way to figure out which one I need? ie. is there a standard size that easily replaces what I have now?
post #117 of 134
http://www.avsforum.com/content/type/61/id/170581/flags/LL
Aren't your supplies already coming through the ceiling???
The two biggest hiccups I see with the standard 3x10 grate is 1. Noise from air turbulence and 2. those standard grates throw air in all directions, so you don't want the air flow moving your screen back and forth (like a giant sail) while simultaneously collecting more dust than normal. A bar or linear slot diffuser solves both of these issues. If that's a 6" supply you should be able to go with a 24" x 4" diffusor, fyi.
Some diffuser manufacturers make a back box with a collar to attach your pipe, but most of the time your local yokel HVAC shop will have to fab one up, probably around $100 or so each.
My supplies will be at the front of the room and I will be using a bar diffuser with a 15 degree angle built into the vanes to kick the air out toward the seating area and completely away from the screen.
post #118 of 134
Hi Tim, thanks again for the reply. I should just have you on speed dial to answer all my questions.
Yes those are the supplies at the front of the room. They come through the ceiling but I still have to add the soffit. The original plan was to hide the flex duct in columns and bring the supplies to the floor pointing toward the seats. Per Shawn's advice I'm now going to put them in the ceiling - well - the soffit. I now plan to run the flex duct in the soffit to the plenums and then use angled diffusers.
I looked at the Nailor catelog http://www.nailor.com/onlineCatalog09/CAD-08/CADBLD.pdf and just so we are talking about the same thing. You are using the angled bar grills shown on page 33 and not the slot diffusers shown on page 5. Do I have that right?
Thanks for the sizing I was having lots of problems trying to figure out what would be best.
post #119 of 134
Yes, similar to the page 33 diffusers, but either one will do just fine. The bar diffusers are less restrictive than the linear slot diffusers, fyi. Probably why EG goes this route.
I have the same 6" flex duct and did all the calculations, so it was no problem relaying that information. Technically speaking you could go even smaller in length, but it's not worth it to push the diffuser size close to the 250 fpm max just for the heck of it.
post #120 of 134
wow tons progress since i last checked your build awesome job , great sized room
