AVS › AVS Forum › Gaming & Content Streaming › Networking, Media Servers & Content Streaming › Samsung AllShare and Internet@TV Discussion
Samsung AllShare and Internet@TV Discussion - Page 2
post #31 of 782
Originally Posted by WulfmanX View Post
Howdy Gents,
I can't seem to find PC Share 4.03 on Samsung's site.
Could you be kind enough to direct me to it?
Wulfman
Try this link and look under software
post #32 of 782
Thanks a million BritinVA!
So, have you had better luck/experience with Samsung PC Share or TVersity?
Wulfman
post #33 of 782
PCSM seems most robust as it has been developed for the Samsung players. I found with TVersity it was hit & miss if the player saw the files.
I'm just hoping Samsung improve both the PCSM and the player interface.
post #34 of 782
Have any of you checked to see just what audio formats are supported for the shared videos? I know using the sharing feature on my Samsung plasma it only supports PCM and AC3/Dolby Digital audio output. Was hoping to find out if DTS or any of the other formats could be bit-streamed by the players.
Also what do the navigation menus look like? I'm assuming they're similar to my TV menus for the sharing. Navigating through all the folders that get listed is somewhat tedious and a tree structure or faster way to navigate would would kind of nice. I really wish they had a web interface that could be configured or something along those lines.
I've tried both the PCSM and TVersity and honestly preferred the simplicity of PCSM. TVersity worked just as well. All the Windows7 PCs in the house also show up as DLNA devices along with the PCSM and I'd suggest using the windows shares for any music that you might try playing. That streaming seems to work relatively well but can be annoying to get started sometimes.
post #35 of 782
I can't get avi movies (made with digital camera) to play either, even though the manual says it is a supported format, not even from a thumb drive. jpg and mp3 work fine from my Windows 7 PC. I finally got rovi to work, but a lot of buttons to press just for tv listings and clock is still confused by new daylight saving time switch - it may be ok after this weekend. And I found out that if you hit Tools when a jpg is on screen, you can rotate it back to vertical, as well as adjust the slide show speed.
Also, what software would you recommended to convert blu-ray to mkv.
And, how come my cable download speed is measured at 18mbps with speedtest.net and only 2.6mbps with the C5500 ??
post #36 of 782
There another media server that works fine with Samsung DLNAs. It's called Serviio, it's opensource and actively developed.
Mkv works, subtitles work, library refresh automatically. It's multiplatform (PC, MAC, Linux). Give it a try. I installed it a weeks ago and so far so good.
www.serviio.org
post #37 of 782
I installed & tried to use serviio but can't install Java 6 on my Win XP computer, but will keep trying.
post #38 of 782
www.serviio.org
Nice find - very simple and has some of the features I'm looking for (Auto DB Refresh, Custom file icons or use theMovieDB.com). This looks very promising. Could do we some more file categories but hopefully will get more traction with requests with this than with PCSM/Samsung.
One issue is images retreived from theMovieDB.com get squished in the Samsung players viewer.....but customer images may get around this.
Will play some more.
[EDIT] BTW - I have set Serviio to use the Samsung Wiselink Pro
post #39 of 782
I just tried Serviio and it works for avi, but for mkv it says "Not Supported File Format." The same files work fine from disc or pcsm. VeauX, you're sure mkv worked for you right? I wonder why it would work for you and not me... I'm using BD-C5500.
It doesnt seem to matter if I set it to generic dlna, autodetect, or samsung, all behave the same way as far as mkvs go.
Using the internet database stuff is not suitable for me. It lists the files by the name it thinks they are instead of the actual filename, which is only right 90% of the time for my movies, and for my tv shows it lists them as their episode name but not the name of the show. Not really workable for me, although if the software were updated to only do movies (not tv) or select which folders get done, and there was a way to manually correct movies it names incorrectly, it might be better for me. I also noticed it stretched the icons it got automatically.
post #40 of 782
I've got MKV working.
post #41 of 782
Now its not - this is the issue I was having with TVersity. Sometimes it worked othertime it didn't.....I'm now getting "Not Supported File Format" on MKV.
MP4 is fine.
post #42 of 782
I got Mkv to work after forcing Samsung Wiselink as the Renderer Profile. I posted this issue on Serviio forums hopefully Zip (the programmer / moderator) works it. Now I just tries a few series I and movies. I did not do extensive testing.
It also categorizes the videos as being Movies or Series. Not sure how it does this.
Also nice also is that somehow uses the Movie Title name instead of the file name. If handled correctly, this is neat. I have to understand how it works.
Also apparently he is working on version 4.0 that will somehow handle transcoding. Wait and see.
This is maybe not the perfect program BUT, with some constructive feedback / bud reports / feature requests to the dev, we might have a very good alternative to PCMS .
post #43 of 782
From your thread over in the Serviio forum looks like your using it with a Samsung N40B650 LCD TV. Myself and enigma9o7 are using a BD-C5500 Blu-ray player.
It will parse the name of your media file (and it's parent folder) and try to make out the movie/series name. If found the metadata is stored in the media library
Yes it gets Metadata from www.themoviedb.org and www.thetvdb.com. Uses the file name to search so providing you name file correctly will pick up the metadata. Very nice - shame Samsung (at least on the Blu-ray players) don't use a movie poster size image (they look squished) but you can change with a custom image.
Agree - I have a higher degree of confidence that Serviio changes will be more forthcoming than with PCSM but were still reliaent I think on Samsung for the BR/TV interface.
I'm going to do some more tests later and post over at Serviio forum too.
post #44 of 782
The capabilities of the PCSM look to be very thin - and so is any kind of documentation and support. Does anyone know if any of the other DLNA/UPnP servers will work with the Samsungs like TVersity?
Our software, J. River Media Center 15.0, now works with Samsung TV's and Blu-ray players.
post #45 of 782
I'm please to say that I have Serviio up and running. Everything I've tried (MP4, WMV, MPG, MKV. MP3, WMA, JPG) works. Only AVI not tested as I don't have a fully supported test AVI file.
Also I had some success with J. River Media Center. Still working on a few issues.... will report back later.
I will also post something in the FAQ about other DLNA Server support. Be good if others can provide feedback on what works for them and what Samsung TV or BR Player they are using.
[EDIT] AVI Also working for me now
post #46 of 782
I installed Serviio but somehow it doesn't recognize that Java 6 is installed on my Win 7 computer and won't start.
PCSM and WMP12 (also EyeConnect on my Mac) work fine with my BD-C5500.
post #47 of 782
I had that problem also. What I had to do it is:
-open IE 8.0 32 bits . go to java.com. install the latest JRE 32 bits
-open IE 8.0 64 bits . go to java.com. install the latest JRE 64 bits
A bit cumbersome.... first I tried with Chrome and it didnt work. switching back to IE for this did the trick. As you imagine I have Win7 64bits
post #48 of 782
Is the Samsung renderer the same accross both TV's and Blu-ray players?
This is what I get with the BD-C5500C with Serviio (same layout with PCSM)
See how the DVD box/poster images that get imported by Servio get squished.
Just trying to understand if this is consisted accross all Samsung devices.
post #49 of 782
Is it just me, or is serviio WAY slower than PCSM? I dont mean how it affects the host computer, I mean changing folders and stuff on the bd player... I always have to wait for serviio saying 'loading' but pcsm is fast, never even noticed the 'loading' (although it is there now that I look for it, but very quick). And switching between pages (when listing files) is instanenous with PCSM, with serviio it takes forever and ever. As far as my personal uses go, PCSM is just fine other than it not updating automatically... and how slowly it builds/updates the database. It still hasnt' finished, I left it running when I was out of town 4 days and it still didn't finish - but got a lot farther than before (and is going alphabetically), so I don't think it's hanging on any particular video, it just takes forever.
MKV started working magically for me with serviio, but I finally found some videos I have that wont play with either pcsm or serviio (but havent yet tried from usb or disc)... regular mpg in vcd format (mpeg-1 with mp3 sound) . Some mpg's I have do play but they're music videos I downloaded online here and there and not sure how to tell the difference in format, right click/properties doesnt give me the same info it does for avi about codecs and stuff.
I emailed about that jriver software license about 15 minutes after the poste but guess someone beat me to it or he hasn't got around to replying yet. If it stays updated automatically and is as fast to use as PCSM, I'll go that way. Otherwise I'll guess I'll keep using PCSM for my archive, and I'll use Serviio for my tv folders that change often when 0.4.0 comes out. (Current version doesn't recognize .tp which is what my dvr software saves hd recordings as, but serviio author says next version will).
I wish Samsung allowed a list view instead of thumbnail view. Since PCSM and Serviio have the same interface on my player, I'm assuming that part is controlled by the player itself. If you have a big list of videos, it takes forever to get to a specific one when its on like page 23 of 48 or something.
post #50 of 782
I can't say I notice a difference - but I've not got a huge library as until I find a final solution I'm not going to invest a lot of effort in ripping.
Same here and I'm positive I the WiselinkPro profile was first one I tried. I've not had any not play but as above I have not got a large library and those I have were consistently converted using Handbrake.
Yeah - that be me.
Based on what your sayng I dont' think thev J. River MC will be any better in your situation. Its much more that a DLNA Server and the DLNA side is under developement. It does have some nice features thou out side of DLNA for creating your media library and assigning metadata.
So far I'm liking Serviio for its simplicity (like PCSM) but I think we have more chance of getting developements with Serviio than PCSM. Samsung don't seem to have an avenue for feedback. I tried via their web chat and not confident it will reach the developer.
I think were all going to be constrained by the Samsung DLNA Renderer on the player. Agree have alternate views like simple list and images to suit the media (i.e. CD cover for audio, DVD cover for movies). I'll add to the request post in hope someone from Samsung is looking at the thread.
post #51 of 782
That worked, thanks. I had used Firefox without success (strange).
post #52 of 782
Hey I discovered Samsung have a discussion forum at CNET that seems to have Samsung representation.
I posted this thread be good if others can chime in on feature requests.
post #53 of 782
I just picked up a PN50C550 that supports AllShare, I hope to have it on the wall soon and with any luck the HTPC connected to it and running the latest version of AllShare... might have some information on cross device rendering.
Anybody know if this system plays nice with a DLNA enabled NAS like the Promise NS4300?
Also, is there a manual or GSQ available for the AllShare software? It would be nice to read more about its requirments and capabilities as I understand certain Samsung phones and cameras will interact with AllShare.
post #54 of 782
I have had success using Mediatomb running on my Buffalo Linkstaion Live V2 NAS with my Samsung BD-C5500.
Mediatomb is a small media server that runs on Linux and Macs (I think).
I had to add a few lines to Mediatomb's config.xml file to get things to work. I can now play MKV, M4V, MPG and WAV files. No luck on AVI files.
I found the information over on CNET Forums and looking at Serviio's configuration files (as I recall). I posted my config.xml file at CNET as well.
The changes are highlighted below (I hope). There are path errors in my config.xml file as shown below and probably would not work as is. Forget the path errors and concentrate on the added lines that are highlighted with comments so you can see what is being changed and why. There are probably improvements that could be made.
Mediatomb's confix.xml file as modified to enable M4V, MKV, MPG and WAV file playback on Samsung BD-C5500. Also the STOP, PAUSE and PLAY buttons work (on remote) plus the <> buttons let you fast forward about 10 seconds at at time (pretty useless). On a side note, whoever posted the thing about using TOOLS (on remote) and then entering the time to jump forward or backward, Thank you. That solves a lot of problems for me.
<br /> <b><ui enabled="yes"><br /> <!-- Mediatomb UI asks for username and password --><br /> <accounts enabled="yes" session-timeout="15"><br /> <account user="yourusername" password="yourpassword"/><br /> <\/accounts><br /> <\/ui><\/b><br /> <name>MediaTomb<\/name><br /> <udn>uuid:8d4ea50c-8da8-40e0-bf72-f760790e0c83<\/udn><br /> <home>/mnt/disk1/mediatomb/config<\/home><br /> <webroot>/mnt/disk1/mediatomb/usr/share/mediatomb/web<\/webroot><br /> <storage><br /> <sqlite3 enabled="yes"><br /> <database-file>mediatomb.db<\/database-file><br /> <\/sqlite3><br /> <\/storage><br /> <b><!-- Following line set to 'yes' hides PC Directory to Rendering Device --><br /> <pc-directory upnp-hide="no"/><br /> <!-- Following line set to 'yes' enables STOP,PAUSE,<> on Samsung --><br /> <protocolInfo extend="yes"/><br /> <!-- Samsung Custom Headers which make .m4v and .wmv file play --><br /> <custom-http-headers><br /> <add header="transferMode.dlna.org: Streaming"/><br /> <add header="contentFeatures.dlna.org: DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=0170000000000000 0000000000000000"/> <br /> <!-- manufacturerURL>http://samsung.com<\/manufacturerURL --> <br /> <!-- modelName>BD-C5500/<modelName --><br /> <\/custom-http-headers><\/b><br /> <!-- Uncomment the line below if you have a Telegent TG100 --><br /> <!--<br /> <upnp-string-limit>101<\/upnp-string-limit><br /> --><br />
/opt/share/mediatomb/js/common.js
/opt/share/mediatomb/js/playlists.js
/opt/share/mediatomb/js/import.js
audio/L16
no
yes
no
video/mpeg
yes
yes
yes
post #55 of 782
Thanks chateau2361 - I've added details in the FAQ in post 2
post #56 of 782
Samsung just did a firmware upgrade on my BD-C5500.
The latest version is BSP-C5500WWB-1010.4
Not sure what has changed at this time.
I did notice that if playing an MV4 files and using the ' TOOLS ' button on the remote to jump to a specified time in the video does not work. The video will lock up and no response from any button for a short while and then it seems to time out and return to the video files menu. I don't recall checking this feature on an M4V file before the upgrade so I can't say if it was broke beforehand.
The jump to time still works on MKV, WAV and MPG files on Mediatomb with my changes (as posted before) to config.xml file.
post #57 of 782
AllShare(DLNA) thumbnails, DTV drivers for Windows, AllShare guide?
Hi, I have this TV connected to a DLNA certified NAS (network attached storage) box, and have the ability to access and display pictures, video files and playback music stored on this device as well as USB attached thumb drives, USB attached hard drives and my computer with PC Share Manager installed.
Three questions:
1) Is there an AllShare manual that shows more detailed specifications and software options?
2) When my PN58C550 connects to the computer where I have PC Share Manager installed, windows recognizes it as 'new hardware' and asks to install drivers for: "Samsung DTV DMR", until I go to that computer and reply to the windows message, the process of sharing the files to the TV is sometimes interrupted. Can you provide these drivers?
3) When I browse folders for media content, with video and pictures a thumbnail image is provided on screen for this media but for music files once you are inside a folder all I see is a generic photo of a saxophone player for every song or album. This would prompt me to believe that the software is capable of displaying such images (cover art) but either they are not being retrieved from the storage device or they are in the wrong format.
Can you direct me to a manual that contains the details about this feature and/or tell me the correct format and size for the cover art of an album and where I should place the file?
This TV is a great focal point for media playback and with a few tweaks and a bit of learning I have impressed all those who I have shown it to, I hope that you can provide answers to my questions so that I can complete the experience.
post #58 of 782
Hi all,
I just ordered a BD-C5500 today, and have some questions for you folks that have been using it for a while. I have a home network, with about 30000 files organized in folders by artist and album. I also have some m3u playlists in the root music folder. Here are my questions:
1. Does Allshare allow folder and subfolder browsing?
2. Does it play playlists?
3. Will the response time be acceptable with a list this large?
4. Is there a way to play Internet radio stations?
Thanks in advance for your help!
Larry
post #59 of 782
Originally Posted by lgleaner View Post
Hi all,
Larry
I am relatively new to this but I can offer a few answers...
1) yes folders and sub folders can be viewed but you will only see music with mp3 and pcm file extensions other will not even be listed.
2) I have not seen this feature
3) Acceptable times, hmm it is not all that fast, once the page has loaded to the screen you can move within it quite quick, but moving to the next page is slow. IMHO I would consider response time 'slow'
4) Internet radio is not part of AllShare per se, but rather Internet@TV which is part of the Samsung Apps suite of programs.
BTW, your location on this planet is not apparent , but here in Canada it would seem that Samsung Apps are not available, I could be wrong but this may be a 'US centric' offering. I have asked Samsung support about this and await an answer.
post #60 of 782
Thanks for the response Al. This information is really helpful!
I am concerned that it doesn't do playlists. Does anyone have a workaround or some way to play playlists (with the list shuffled each time)?
