Sorry have no experience with running these over wireless but one of the things you might want to check is what channel is being used by your gateway (if possible) and if there are any clashes with nearby neighbors. The only channels that don't overlap with others are 1,6 & 11. If you have neighbors with WiFi see what channels they are using and steer clear of those with strongest signals e.g. If your strongest neighbors are using 6 to 11 go with channel 1.
Some WiFi clients will show the channel if not there are free WiFi sniffers you can download.
Personally I'd use wired if at all possible, I have every streaming device in the house wired and only use WiFi on portable devices. Too many things seems to impact WiFi.
