Answers below:
1. I have the TV connected to our wifi. When doing that the set finds all computers that can be media servers....like my work laptop, home laptop, wife's laptop, etc. It's fine but since none of these will ever be the media source for Allshare it's a bit irritating to have a long list of computers show up all the time. I'm sure I can get rid of them somehow but haven't searched enough.
Disable the "Windows MEdia Player Sharing Service" on each Windows machine.
2. Can't see to see at any given moment if the tv is streaming content from the HTPC via wired or wireless as both show up on the set. Presuming it's the first listed network info listed in the Network Settings page?
The TV is set to either Wireless or Wired. Only one can be active at a time.
3. Assuming the TV is using the wired ethernet connection I'm getting some buffering issues whereas the TV has to pause with a 'Loading..' message in top right. Watching Tron last night (a 12GB MKV rip), in each heavy action scene the stream had to buffer about every 30 seconds. Annoying. Smaller rips don't have any issue on either wired or wireless.
What model is your TV?
4. Allshare message pops up at random times. I *think* what's happening is the TV is finding other computers that come onto the wifi. For instance, my laptop was in sleep mode and, when resuming Windows I got an Allshare message on the TV. I think it can be set via the Allshare application on the HTPC to NOT allow the popup but not sure.
See 1
5. Allshare seems to lose the connection and take 10 minutes or so to find it. A bit annoying when you want to just immediately start using the HTPC.
6. Can't seem to get Allshare app on HTPC to pull content from a NAS vs. a local drive. Help?
Have you tried mapping the shares as a drive? If Allshare runs as a service you might need to set the service to run as your user credentials.
7. Can Allshare work through a receiver vs. HTPC straight to TV? Potentially I'd need a Samsung receiver (vs. Sony) to do it? It's certainly convenient but the setup today doesn't allow sending the audio through the surround sound speakers - just straight to the TV.
TV running Allshare should be able to feed the amp using its optical/coaxial digital output.
See 1
