I have a 20" LG LCD TV in the kitchen, and a 50' run of Blue Jeans Series 1 Beldon cable to my DirecTV box in the other room.
Usually, this setup works just fine. However, periodically, I get the "Invalid Format" message on the TV and the audio and video go away. Wiggling the cable at the DirecTV box will usually resolve the problem.
I've tried using "port protectors" (the little 6" more flexible extenders) on the ends, thinking perhaps the really thick BJC cable is causing the connectors not to mesh properly. No help there.
Ideas? The cable run was not easy to make, and therefore I don't really want to do it again, and I really don't want to invest in another cable either. The connectors look just fine, and I made sure they were protected while I was running the cable.
Jeff
Jeff
