AVS › AVS Forum › 3D Central › 3D Source Components › Nvidia 3d card + Samsung LN46C630
post #1 of 2
Hi!
Sorry if this is the wrong thread but been trying to figure out with my new sammy c630 which does 120hz but only takes 60hz input, would I be able to hook up a HTPC that has a Nvidia card that does 3d and use Nvidias glasses to see 3d? Will this work on this TV via hdmi? Samsung LN46C630
Thanks in advance for your help!
post #2 of 2
Originally Posted by Soroc View Post
Hi!
I don't believe that's a 3D-Ready display, so the answer is negative.
  Back to Forum: 3D Source Components
