Nichol1997,
Sorry to bring up the question on the ports you used on this pair of speakers. I’ve followed your posts and am moving on a similar build in a few weeks. Can’t wait. I saw your testing results on the PISpeakers forum and they look great.
I just wanted to double check a detail with you if you have a moment – For your Tall 4PI speakers each speaker has two ports and each port has an Internal diameter of the port at 4". The length of both ports is 9.25". Correct?
Just wanted to make sure Nichol1997 as I saw another builder of 4Pis do each speaker with one port per speaker at 4" port at 5" long. Wondering if I mis-understood you.
This is the speaker build with the single shorter port - http://audioroundtable.com/forum/index.php?t=msg&th=16392&start=0&
Wondering if the single 4” diameter port is doing the same as two longer run 4” diameter ports you are using.
Newbie here. My real question is just confirming the two 4” diameter ports per speaker.
Andy
Andy
