AVS › AVS Forum › Audio › DIY Speakers and Subs › Reed Exodus Anarchy 25hz Tapped Horn
Reed Exodus Anarchy 25hz Tapped Horn - Page 13
post #361 of 713
Originally Posted by Maxjr View Post
Thanks, Mike! I can always count on you. I'll get dedicated amps for your TH build.
Would you advise to get 3 of the NHT Foster amps or a 300 Bash amp or the Dayton 240? From what I can tell, of the 3 only the NHT has a highpass filter. It would sort of be ideal for me to have just one amp and DSP rather than an amp for each build. However, I'm still a newbie . Are there advantages to having a dedicated amp to each sub?
Any subwoofer plate amp should have a built in high pass filter.
post #362 of 713
Good to know. Is there a way of knowing the highpass frequency of each plate amp, and modifying them if needed? Most plate amps I have looked at doesn't spec if there is a highpass and what it's at.
post #363 of 713
The Foster amp has a third order 29Hz high pass. Jhidley has full instructions on his website for modifying this filter. Many plate amps do not have high pass filters at all. The only way to know is by reading the specs for them.
post #364 of 713
Thanks, tsloms! This is what I assumed as many specs (Dayton and Oaudio) did not state any high pass filter. It is my understanding that I would have to purchase a separate EQ or DSP if I went this route. Thanks in advance!
What amp do you guys recommend to run two of these 6.5" Exodus Anarchy's off of? Should I purchase 2 of Jack's NHT amps? And, if so, should I get the modified 20Hz highpass version, or buy the standard 29Hz version and modify the Resistors myself? I am pretty proficient in soldering even on small pcb boards if this is the case.
post #365 of 713
One of the Foster amps per sub would be perfect. I would stick with the standard 29hz high pass. The 20hz high pass will be a bit low and put the Anarchy into overexcursion below 25hz at full power. The 29hz high pass will allow use of the full power of the amp.
post #366 of 713
Awesome! Thanks for the quick reply. I really appreciate it
post #367 of 713
Over the past 2 days, I made some sawdust Here's a pic:
I cut enough birch ply for 2 cabs (1.5 sheets) I used your awesome cutsheets!. I'm waiting for the anarchy's and NHT amps to arrive. A big thanks to lilmike for all of his help and everyone else who made this a reality!
post #368 of 713
be sure to order an extra set of panties too...................
post #369 of 713
Not sure what you mean by this?
post #370 of 713
You will
post #371 of 713
Is this referring to WAF? Cuz I'm single and of all the tapped horns, this seems to be the smallest and have the highest WAF
post #372 of 713
I'm looking to purchase a brad nailer and air compressor for this build and other future projects Do you guys have any recommendations?
post #373 of 713
No, I think they are referring to the infamous 'brown note'
They may be small, but they can play loud when needed. With two of them you should be able to shake the room.
post #374 of 713
I've had good luck with the refurbished Bostitch ones I picked up, as well as my old Craftsman (had that one forever...) and the Hitachi brad nailers I have.
As far as compressors? Are you just gonna shoot nails with it - if so - a little one will work great. If you're going to do anything else (impact wrenches or other air tools) a larger compressor makes sense. I have a little one (part of that Bostitch refurb compressor and nailer kit) that I use as a portable source for shooting nails, hanging trim and stuff, as well as a larger one that I use in the shop.
post #375 of 713
Get them done, put them in the corner, and turn them loose.
You'll find out.
post #376 of 713
Oh, hahahahah . Now I understand. I'll order a pair of black ones so they don't stain
I'm probably going to pick up a Hitachi one with what you have said and the reviews on amazon. http://www.amazon.com/Hitachi-NT50AE...4862595&sr=8-1
I will be using this air compressor for possibly impact wrenches in the future. Hopefully I'm not going too off topic here, but how does this air compressor look: http://www.amazon.com/Makita-MAC700-...4862648&sr=1-1
You'll find out.
A big thanks to lilmike and radman12 for this great thread and outside support. I really appreciate it.
post #377 of 713
Ditto on the above post. This has been a great thread to follow.
Okay , I have the enclosure built. Missed the sale on the Anarchy 6 1/2"...Need to know exactly which 6 1/2" Tang Band to use as a drop in replacement. ? Thanks , can't wait to use this in the bedroom setup.
John.
post #378 of 713
Tang Band W6-1139SI
post #379 of 713
That has to be the fastest reply i've ever had.
Thank You.
Will order asap.
post #380 of 713
Thank You.
Will order asap.
I'm here for you guys.....
Seriously - you posted while I was online....
post #381 of 713
Just plugged up my second one 20 mins ago and had to rush over to here to tell you guys how AWESOME these sound!
I'm using the tang bands and Jack's Foster plate amp along with 1/2" MDF.
Whats so impressive to me about these is how clean the bass sounds....nice, deep, rich bass, not the muddy stuff that I'm used to hearing at my friends places that distracts from music/movies.
This is my first speaker build of any kind. I don't have much experience with good home theatre subwoofers. I have 3 friends who I can compare these to and these easily, no questions asked, have a better, cleaner bass sound.....just like a high quality movie theatre bass, maybe better!
Just want to say thanks to Lilmike and Radman12 for this great design and inspiration! I can't wait to get these veneered up and start on the next 2!
Here's a pic .....still have to PL and screw down the side on this one. I'll have a bunch more pics when they are fully done.
post #382 of 713
exactly why they are my favorite tapped horn in my household, they are just so clean sounding
post #383 of 713
Nice picture of the internals there bassco. It just goes to show you what went into designing this sub, no internal waste.
post #384 of 713
Just for fun, I played this bass test track through the subs and could hear it down to about 23hz
http://www.youtube.com/watch?v=fH_sUK7hJxE
post #385 of 713
Guys I'm going to be meeting with a CNC guy on Tuesday to get these cabinets cut for cheap. They're price is about $70, including all grooves, pilot holes, and dado cuts.
I had a few questions though.
#1. Should I have them cut out an access panel for the driver? I thought it could be on the side and just big enough to get the driver in. Any ideas what size is needed? Or should we not worry about cutting one at all? Seems like a tight squeeze getting the screws in anyway.
#2. Terminals. What should I have them cut out? A small hole for a terminal plate, or should they just drill 2 holes for the tap in style binding posts? And where? Maybe on the access panel?
#3. Should they drill holes for threaded inserts to mount the driver? Does the Anarchy have the same hole spacing as the Tang Band?
post #386 of 713
I wouldn't worry about the mounting holes. Just get the driver cutouts, any self tapping screw will take care of that.
post #387 of 713
I won't be buying any flat packs, since I have all my own tools for cutting wood (except CNC). But I'll toss my opinions out.
As long as the access panel board is swappable for the left or right side of the sub enclosure, then absolutely yes.
No. Most people at least have a drill on hand.
No
post #388 of 713
No
Agreed!
No need to add complexity to the process. Keep it simple.
post #389 of 713
I just figured if they'd cut the terminal holes for free, why not.
I'm not sure there's enough room on the side for an access panel, it might need to go directly behind the driver. But if the hole's too wide, the surrounding 1/2" birch might be a bit fragile.
post #390 of 713
True, but as soon as you do you will have someone that wants it setup differently or ???
