Ok. So, I should be able to drive the LCRs, wides and surrounds with the pre outs/external amp and the rears from the Onkyo inboard amp, right?
I'd be interested in the Denon if it had XT32 and THX Ultra2
Denon used to have a lot of their receivers THX certified, so I'm sure they're aware of the spec's. I have no doubt the 80 Hz crossover would be an exact implementation of the THX crossover.
DIYTheater.pdf 14.12109375k . file
So now I am wondering why Steve Feinstein of AT recommended bipoles. Perhaps they implemented the Dolby system and maybe Dolby calls for a diffuse Heights field. I'm going to have to follow up with Steve on the choice of appropriate direct radiators.
And most direct radiators are designed to be floor standing. Not sure how I will mount one high up and pointing in the right direction Thank you |
But, for the LR surrounds you need dipoles, and bipoles for the rears, right? I have asked Steve to recommend appropriate direct radiating speakers for the heights that will match the 8200e LCRs. I have a pair of existing B&W HTM Matrix speakers that Steve thinks can be used with the 8200s. Should I use these for the Heights and get beefier speakers for the Wides, or use them for the Wides instead? I think that the Wides are more critical.
