AVS › AVS Forum › Display Devices › Flat Panel General & New FP Tech › Need mounting advice
post #1 of 7
Hi, I am trying to mount my 46 LCD above the fireplace. the only issue is that this is not a normal wall. There are two recessed spaces on each side of the fireplace and I am trying to mount in the middle. I was hoping there were solid wood studs in the framing, but I'm not so sure now after drilling primer holes. What's a good way to ensure proper support is available?
I have a sony 46, weighing 80 lbs. i bought a mount already.
See the picture attached, it will help to describe it.
Any suggestions?
post #2 of 7
You can mount it right smack over the fireplace on the middle column. There will be studs on the outside edge of the column. Middle of the studs on the edge should be 1 1/4" from edge including 1/2" sheetrock. Just make sure your plate will have holes that match the vertical alignment of the studs. Done it before, don't worry.
post #3 of 7
Thanks for the input. I imagined there would be studs running the entire length of the columns on the edges. I marked off where I'd be drilling holes for the mount. The lower bolts would be about 12 inches from the base (where you can see the black wires running accross). When I drilled in small test holes, it felt that there was some material for about 1/4 of an inch but then it just went through. I'm not sure if trying up or down the column makes a difference. Does it?
I hope I can figure this out. Having the TV off to the side sucks.
Thanks in advance
post #4 of 7
Sorry, whoever designed that wall should have their license pulled, visually it's a mess. Not to mention very impractical. Odds are in the center there is a 4-6" B-vent flue and the rest of the space is open. There should be studs on each edge as Hometheaterhome stated, but that is not a certainty. It may be framed with metal studs rather than wood. Drill a pilot hole and try anchoring a bolt and see if it grabs.
post #5 of 7
Thanks guys. I went ahead and drilled through 1 1/4" from the edges like HomeTheaterHome mentioned. Thankfully there were studs present. There was some type of metal on the surface then wood behind it. I installed the mount, and everything went smoothly.
Originally I was going to mount it a little higher but ended up putting it lower for better viewing height. Now I need to find a nice clock or something to fill the rest of the column.
Matt, I agree, the configuration is a bit awkward. Our place is kinda small though, so maybe they were thinking making these holes would help in not taking up floor space for AV equipment. Plus, this 'media niche' was made in 1995 before big wide flatscreens became a standard. Though it looks small in the picture, the niches are really large, probably made to accomodate a huge 4:3 projection TV...back in the day.
Thanks again...now i have to figure out what to do with those big empty holes.
post #6 of 7
Shelves, speakers, audio equipment, perfect for a built in sub woofer. Could be centre channel and/or the front L&R speakers in there too. Actually that smaller bottom hole looks perfect for a sub
post #7 of 7
If it were me, from the look of it the edges are rolled , I'd sheet rock it slightly recessed to keep the edges and make it look like it was planned that way. Use the lower opening for equipment. If you are not into construction I'd make a frame to fit the entire opening and tightly stretch fabric to compliment the room decor on it to cover the openings.
