Exclusive to AVS from IBM.
How to view The 2010 Masters in 3D via The Masters web site
System Requirements Module Content:
In order to fully enjoy the Masters 3D video via the Internet the following is required:
· a computer system capable of supporting 3D viewing.
· an internet connection capable of a minimum of 10 Mbits/second.
· a supported 3D player.
There are multiple computer systems that support 3D viewing. These computer systems require a specific video card, CPU, 120 Mhz monitor and 3D glasses to view the 3D content.
Detail Specifications:
There are a number of different computer systems such as:
· NVIDIA® 3D Vision™
· Acer Aspire 5738DG
· Asus G51J-3D
In addition the supported computer systems a video player which supports the play back of 3D video and streaming Windows Media is required. One such player is the Stereoscopic Player. This player is available for purchase at http://www.3dtv.at.
Masters.com Viewing Instructions Module Content:
To view the Masters 3D video via the Internet (using Stereoscopic Player) please follow these instructions:
1) Ensure connectivity to the Internet
2) Choose START, RUN ……
3) Choose File>Open URL (from the menu)
4) Type or paste the URL into the text field.
5) Click OK.
6) Change viewing method with View>Viewing Method (from the menu). This is where you might select your monitor type or the NVIDIA 3D Vision system.
7) Open video in full screen mode by double clicking the video window or selecting View>Full Screen Scaled.
If you are having trouble viewing the video in 3D, please consult the help for your system and verify other content is viewable in 3D. You may also want to refer to the support and help information regarding your video player and the setup process for your hardware. If you are using Stereoscopic Player for the first time, you may need to configure it for your particular 3D setup.
The instructions to view the Masters 3D video with a player other than the Stereoscopic Player will be different. You will need to start the player and “load” the following URL … and select full screen as a viewing option.
http://www.masters.com/3D/
· Asus G51J-3D
5) Click OK.
