That cable connection shown does absolutely zilch that any standard off the shelf RCA cable will not do. Electrically the circuit is identical.
No where in the realm of professional audio (you know, the people who actually know and understand audio and the various functions) will you find "telescoping shields". Lifting the shield on one end is done to isolate the ground connection between 2 devices that use fully balanced interconnections.
Go ahead and build the cable shown , then take an ohmmeter set on the lowest resistance scale and measure pin to pin and shield to shield on the connectors.
You will get exactly the same reading as if you used a standard RCA cable. It makes no difference how many wires you attach on one end and how few you connect on the other, if there is a single conductor path from point A to point B there will be continuity and the will be no alteration of the signal path.
