Trust me on this. I do read and understand schematics rather well. I make a nice living drawing them, using them, and building rather extensive AV systems for many years.
As I said earlier, the picture shown with a single ended cable connection (RCA) is of absolutely zero difference electrically from a straight through soldered connection shield to shield tie point on the connectors. There is zero benefit OR electrical change in the IC circuit between 2 devices so connected. NONE.
Anyone who touts that has very little experience in the real world of audio interconnects. The ONLY benefit to lifting one end of a shielded pair is IF and ONLY if the devices are using balanced input/output connections where neither the phase nor the return is referenced to ground AND there is a low voltage potential difference between the chassis or signal grounds of the aforementioned units.
This can occur if they are powered by different AC phases, opposite legs of the same phase (as in a home system) or are separated by a distance such that there MAY be a higher resistance to earth ground of one unit from the other.
We see this frequently in commercial / professional installs where the amp racks are not adjacent to the mix desk/ source rack.
Single ended RCA to RCA is electrically the same no matter what you do to the cable. As long as there is a shielded connection and phase, the cable functions identically to an off the shelf RCA cable.
In actuality and in practice, if you are in a noisy environment interference wise, using the wiring scheme shown with no shield connection right at both connectors may well impede the clean audio and allow a substantial hum in the system.
