Numerous posts in these AVS sections point out why standard plasmas can't deliver 3D adequately. Part of consultant Andrew Wood's article, "3D Displays in the Home," in the July '09 Information Display covers these problems, too (phosphor decay time, two polarization states needed, only 60 Hz, etc.). (BTW, there are other online related pieces in this special Home Theater 3D Technology issue.) [EDIT: Online article access requires a free password signup, or SID.org membership]
Haven't read about anyone installing a polarizer plastic sheet in front of a 120-Hz-capable plasma. Opinions whether this might work with shutter-type 3D glasses (or passive?) and a 3D-capable computer with decoding software for sequential display? There's polarized sheeting online, 56" wide by 9' long; (lost the URL link). For photographic lighting, AIUI, and may not be top optical quality. And that length--way more than needed--is $500-$600. My 1080p 65" plasma (screen area only) is ~57.5" wide. If it worked, suppose you could make a roll-down screen panel or just use Velcro for occasional 3D viewing.
My Panasonic plasma (TH-65VX100U) handles 48--120 Hz vertical rates as a PC input, and has an external-scaler mode that disables video-processor settings. (That differs, of course, from 120-Hz display techniques that interpolate extra frames to 'smooth' motion images.) Suspect some 120-Hz-capable plasmas would require a down-scaled input, not 1920X1080 (!) But standard 1080i versus 720p sometimes appears very similar when the same cameras are used, as with the upcoming golf Masters tournament (ESPN/CBS). Polarizers would dim images, although this model's reported 60,000:1 contrast ratio might help. VX100s and other Panny models have non-standard wider-gamut color phosphors but suppose they wouldn't overcome ghosting due to decay times. Just musing here to exhaust possibilities. :-) -- John
