AVS › AVS Forum › Audio › Receivers, Amps, and Processors › "Official" Yamaha RX-V467/RX-567 Thread
post #1 of 578
Two new models are up on Yamaha's web site. The 467 and 567 ( I consider the 367 a different platform as it's cabinet size is different.) The main addition from last year's line is HDMI 1.4 with support for 3D.
RX-V567 Rated power
7.1; 90 Watts / Channel; .9% THD at 1 khz
Power Consumption - 270 Watts
Weight - 18.7 pounds
RX-V467 Rated power
5.1; 105 Watts / Channel; .9% THD at 1 khz
Weight - 18.5 pounds
What's up with those power specs?
The 467 has a higher power spec, because it's 5.1 only. It's power supply is almost certainly identical to the 567.
No 20 hz to 20 khz power consumption spec is given. A guess is that these power figures can be met only with two channels driven.
Expect sub 50 watt / channel performance with all channels driven.
These receivers will be ok for many people's power needs. Don't expect to be able to play cleanly at high volumes. And use efficient 8 ohm speakers if at all possible. (This is nothing new when dealing with receivers in this class.)
Common Main Features
* 4 HDMI 1.4 Inputs
* Decoding for all common codecs ( TrueHD, DTS-HD Master Audio, etc.)
* 5 AV inputs ( composite)
* Two digital; two coax inputs
* Audio return channel
* 2 Component video inputs
* HDMI 3D Support
* Can change inputs in standbye mode! (Nice feature if it works like I expect)
* Auto Power Down (Interesting feature?)
567 Only
* 1080p Upconversion
* OSD (Not 100% sure what this means, I am just reading the comparison chart)
* Can biamp
General thoughts
It's likely they took the previous line and added 1.4 and a few other goodies. The cabinet size, weight and power consumption of the 567 looked practically identical to the 565 for example.
Being able to switch sources in standbye mode, and auto power off looked interested to me. Otherwise, more of the same?
post #2 of 578
OSD means On Screen Display
post #3 of 578
Thank you Captain Obvious
Yes, that part I knew. I just don't know exactly how the two differ with regards to what is displayed. My guess would be the lower model can't display volume change overlay and such. But there's different OSD capabilities such as HDMI overlay, vs analog overlay.
post #4 of 578
I checked the manuals and the difference is more basic than that. The 467 has no OSD at all, the front panel is the only way to display any information. The 567 has the usual low-end Yamaha OSD which takes over the whole screen, there is no overlay.
But what's really stupid is that there is no way to disable the full screen OSD, even though the front panel lets you control everything. So if you're watching a movie with the 567 and want to check the signal info or turn up the centre channel, you can't do it without interrupting the video! It's totally stupid because the front panel display shows you everything anyway (and that's all there is on the 467). Previous models going back a long time have had the same problem, I don't know why Yamaha wouldn't include such an obvious feature as letting you disable the full screen OSD.
post #5 of 578
So it looks like the 467 setup is all displayed on the receiver. How very retro of them. How was it done on the 465?
I recommend buying the 567 over the 467 unless you sit close to your receiver!
post #6 of 578
A true "over-lay" OSD requires fairly high-end video processing for HDMI inputs, less so for analog video. But unless an AVR has some kind of video processing there will be no OSD. The mid-level Yammies use an analog video generator for the OSD and convert that to digital for HDMI. This allows them to output the OSD over both analog and HDMI.
post #7 of 578
I realize this. But the 467 lacks any ability to generate any graphics...at all, near as I can tell.
post #8 of 578
I just pre-ordered one of the 567's from amazon. great deal.
seems to fit my needs. driving PSB (T45, 8C, S50, sub 5i) speakers. Mostly needed an upgrade to HDMI switching. the biamp on this is a nice option.
Hope it works out!
post #9 of 578
Why is the RX-v367 available already but there STILL isn't a street-date for the v467 and v567?!
What's worse; why does JR already have the v367 but Best Buy says they won't have it until May 9th?
post #10 of 578
Also, for anyone who is still looking for key differences between the RX-v465 and the RX-v467, the *67 model has banana-clip connectors for all of the speakers (not just the front, which is a nice addition!)
post #11 of 578
General thoughts
It's likely they took the previous line and added 1.4 and a few other goodies. The cabinet size, weight and power consumption of the 567 looked practically identical to the 567 for example.
post #12 of 578
Originally Posted by JChin View Post
OP must have meant that the 567 is very similar to the 565 model.
post #13 of 578
well, not sure about this "ships late april" part of the sale. cancelled my order on the 567 as i notice the 467 will do exactly what i want for cheaper. ordered that one instead, but still has a preorder status. something on yamaha's site mentioned late may now!
post #14 of 578
shipped today! yay!
post #15 of 578
Originally Posted by poster72 View Post
shipped today! yay!
PM Sent
post #16 of 578
Poster72 wasn't kidding... He got his yesterday and once he had it in-hand I ordered one as well (using the free 5-9 business day shipping)... Amazon must be feeling Christmassy because it was just delivered (less than 18-hours after ordering)!
post #17 of 578
Basic reason is that there is no video processor as there is in the 567.
To output an OSD the 467 would require an additional costly IC..
Just another sign of the extreme cost pressures for these entry-level AVRs...
Just my $0.01..
post #18 of 578
YEAH:
Banana Connectors for all speakers
The removable dummy panel to cover the front connections
BOO:
No manual?! REALLLY?!?! (it comes on a CD)
post #19 of 578
well, unfortunately im already planning on returning the 467.
hooked up a samsung blu ray after returning an LG that had issues playing blu rays. video/audio woudl hiccup every 10 seconds or so. the samsung did the same. after connecting straight to the tv i noticed its the receiver. and it only hiccups when streaming 1080p at 60fps. if i drop to 24fps, all is well.
spoke to yamaha and they were of no help whatsoever, to the point of being very frustrating. no firmware udpates for months they say. which seems reasonable as it just came out. my fault for buying an untested product. suckin. probably going to step up and buy a real receiver i guess.
i bought from amazon, not sure what to do now. but this wont do.
post #20 of 578
Summer is on the way... and...
I have a Yamaha RXV-2400 and everything in my system is connected via HDMI through it. This receiver generates enough heat to keep my living room (apartment, small) warm without much help; but summer temps overwhelm my ancient a/c and between the computer, 40" XBR, and Yamaha receiver, it's too much heat. So I've read with interest this seeming ability of new receivers to pass HDMI signals with the receiver in standby. However, the initial models would probably croak, I'm using Polk LSi-7's and LSi-C, they'd probably immediately trip out because of the 4-ohm load. This isn't a problem with the 2400. Ideally I'd like to be able to watch TV and have it's speakers used for rotten television, and switch to the receiver for 5.1 material (have Pronto remove and can probably write macros to do a lot of the switching... so I think). Is it in the cards that Yamaha will do HDMI-in-standby capability on higher powered models? I asked for advice at Best Box Magnolia and got nothing.
Advice much appreciated.
post #21 of 578
yes, best buy's got nothing. i got the same response today on several questions
ill test it out right now for ya and let ya know!
post #22 of 578
RX-V1900 will do HDMI passthrough in standbye, I think. I know the 3900 can do it. And they are very similar. You need to double check the manual to be sure (don't rely on my memory.)
post #23 of 578
yes, the rx-v467 does standby passthrough hdmi. i tested it out on mine.
it didn't fix my 1080p/60fps issue though. still hiccups when passed through that receiver. 1080p/24fps continues to work fine.
anyone want to educate me on the difference and preferences?
post #24 of 578
Hi guys.
New to the forum, and to HD/HT.
I put a post up in the HD technical area regarding a problem I have interfacing my crappy local cable company HD converter box, which has DVI and component video but not HDMI output, with my new Yamaha 467.
Just discovered that the 467 does NOT upconvert component video to HDMI, so would have to use the TV to switch, which I am trying hard to avoid.
Now I'm looking at returning the 467 to Amazon and getting the 567, as that looks like it does do the upconversion, based not only on the website comparison page but also on reading the owner's manual.
I am trying to get a very easy-to-use user interface in this system, which is used in a vacation home that is often rented out. HD and digital cable has just enormously complicated this, and I'm trying to figure out the best way to get back to an easier way to get a channel guide, and to switch from Blu-Ray DVD to cable TV.
Because the cable company's converter box does not have an HDMI output (it has DVI and component video) I am stuck with either upgrading the receiver or trading the converter box for a Tivo or Moxi. At least that's the way I understand it.
Any advice would be greatly appreciated.
If you know of any forum links that might help, that would also be much appreciated.
post #25 of 578
Hi Guys,
I am also planing to get one Yamaha RX-V567. I found that there is an amazing deal for $369.99.
The price is much cheaper than other online stores. Can I buy it from this store directly?
post #26 of 578
Hello , new to the forum, I recently bought the rx-v467 system at BB, in Yamaha site states it is compatible with 1080P , it does looks as 1080 and my TV display function states is passing the 1080 at 60, the problem I encounter was my old speaker system is 100w at 8 ohms , my sub is not preamp , so I don't have deep bass at the time My question for help is if I get a sub with a preamp built on at 100 w at 6 ohms , would that work, is there a setting where I can set that spec of 6 ohms just for the sub
Thanks for the help
post #27 of 578
Thanks for the help
You just need to check volume, phase and freq.if the subwoofer already bulit-in a preamp. Just hook up the sub output on your V467 directly.
post #28 of 578
So you are saying if I get a sub with a 6 ohms and the rest of the speakers are 8 ohms , it wont make a difference right
Thanks for help
post #29 of 578
How are the amps on the 567 compared to the older 661 model? I have a 661 getting fed pcm from the PS3 and it sounds great! Passes 1080p without fail. I just wanted a new Yamaha that upconverts all signals to HDMI so that we can play the wii on the projector. I only have an HDMI going to the PJ right now as I didn't want to look for that long of a component cable. I didn't get the last gen Yamaha because they got poor reviews for amp power. Thanks
post #30 of 578
I just bout a 467, what kind of hiccups you are talking about ? what it does or what it did , how do you manage the setting for the 1080p 60fps to drop to 24fps are you doing this with the receiver or with your TV
just want to know ,because mine so far it looks great all HDMI connected PS3 and dish , HDMI out to TV, not sure if I'm missing something or I may be blind
