Originally Posted by HighdefJoe
How are the amps on the 567 compared to the older 661 model? I have a 661 getting fed pcm from the PS3 and it sounds great! Passes 1080p without fail. I just wanted a new Yamaha that upconverts all signals to HDMI so that we can play the wii on the projector. I only have an HDMI going to the PJ right now as I didn't want to look for that long of a component cable. I didn't get the last gen Yamaha because they got poor reviews for amp power. Thanks
If you compare the weight, and power consumption from the manual to the prior models in the same price category, I believe you will see no evidence of improved power.
You would have to step up the ?67, which is whatever receiver will come out this fall, and put out more power than the current 665 and related models.
The 765 is the current "step up" model in terms of power, as I recall. You can see this by comparing cabinet sizes, weights, and power consumption in the current x65 line. I posted a thread on that once, I will see if I can find it.
A lot can change in a year. Your 661 is a great amp, enjoy it for now. The 567 can't touch it.
