AVS › AVS Forum › Display Devices › Display Calibration › Setting contrast with Spears and Munsil disc
Setting contrast with Spears and Munsil disc - Page 9
post #241 of 484
Originally Posted by bodosom View Post
…ah standards, so many to choose from.
Yea, it’s almost like they can make $ from them… Wait, I see you can buy SMPTE-274M for $1500.00 from the SMPTE store.
I don't have 274M at hand so I don't know what 7.7 and 10.5 say about reference levels or even if the primary intent of the quoted section is regarding in-studio concerns about A/D conversions but 861 seems interested in making a distinction between pure digital and a/d transforms. ...
Here’s a little more including 10.5. Section 7 defines things like specific levels. Standard stuff like Y=16-235, CbCr =16-240, 0/255 are prohibited, etc.
Originally Posted by From SMPTE 274M-2003 View Post
5.4 To ensure the proper interchange of picture information between analog and digital representations, signal levels shall be completely contained in the range specified between reference black and reference white specified in 7.7 and 10.5, except for overshoots and undershoots due to processing.
10.5 For the Y’ component, reference black (zero) in the expressions of clauses 5 and 6 shall correspond to a level of 0 Vdc, and reference white (unity) shall correspond to 700 mV.
Table 3 (8-bit system)
C’B, C’R
Upper F0h(240)
Lower 10h(16)
Prohibited codes
Upper FFh(255)
Lower 00h(0)
Overshoot and undershoot
Upper F1h-FEh(241-254)
Lower 01h-0Fh(1-15)
7.3 Levels
Reference black level 0 (mV)
Reference white level 700 (mV)
Synchronizing level ± 300 (mV)
Also, Poynton does similarly and says pretty much the same thing as the SMPTE spec in his “Mergering RGB and 4:2:2” document
Originally Posted by From Poynton View Post
Studio video R’G’B’ standards provide footroom below the black code, and headroom above the white code. The primary purpose of footroom and headroom is to accommodate the transients that result from filtering in either the analog or digital domains.
For no good technical reason, footroom and headroom are assigned asymmetrically: Footroom has 15 levels, but headroom has 19.
The so-called valid colors encompass the volume that is spanned when each R’G’B’ component ranges from reference black to reference white. In Rec. 601, each component has 219 steps (risers) – that is, 220 levels. That gives 220×220×220, or 10648000 colors: About 64% of the total volume of codewords is valid.
Note in both places, overshoot (WTW) and undershoot (BTB) ARE linked or lumped together (much like two sides of the same coin) and the reason cited for the presence of BOTH is exactly the same. …due to processing and to accommodate the transients that result from filtering.
I understand the desire to keep BTB/WTW separate, but as noted here and in many other places, they DO seem to me to be closely linked in specs and by industry insiders. The original debates here were all about BTB, and now most everyone has forsaken them.
I’ll also note again that I don’t place filter ring, processing artifacts, or filter transients in the same classification as valid signals, and neither did SMPTE or Poynton as shown by the above references.
I think A/B side-by-side images can be very helpful in making the distinction.
Dave
post #242 of 484
Originally Posted by sotti View Post
To go even a step farther, how do you calibrate a display to handle that sort of input.
How do you calibrate a display with an input that has a clamp at BTB/WTW? You could calibrate to levels for one.
Because even if those values are "Error" but they come into the display unclipped.
They don’t come in if the input has clamped them.
With a display calibrated for max light output at 235, you're usually driving red very near 100%, so any additional intensity in the signal will cause discoloration as the blue and green channel can reproduce the additional intesity. This unbalancing of your whitepoint could effect your overall perception of the image, beyond the pixels that are effected.
Additional intensity over 100% won't cause discoloration if the input has clamped them at 100%, additional drive over 100% isn't possible then. Blue and green won’t reproduce any additional intensity over 100%- it won’t be there. Only the BTB/WTW pixels will be clamped. All the other 100% and lower pixels will stay at the exact same levels they were at. You'll get all of the 0-100% and only the 0-100%.
If additional signal intensity over 100% is causing discoloration, or unbalancing your whitepoint and effecting your overall perception of the image, then maybe the problem is with the signal intensity being over 100%?
So from a calibration standpoint, I think the answer may be that since there might be data there you need to calibrate for it's presence unless you have a surefire way to eliminate it's presence.
Surefire way to eliminate BTB/WTW? Are you setting me up?
Dave
post #243 of 484
I was a unclear -- I was making a distinction between disc mastering artifacts and objects in the "film" source however they got in there. I consider passively not bounding excursions to be the moral equivalent of inserting them into the source.
I guess I consider it the ‘moral equivalent’ of not toeing the line or foot-faulting. < I'm sorry, Smokey. You were over the line, that's a foul. This isn’t 'Nam. This is bowling. There are rules.>
We’ve seen reports and comments here (from other than me) that for much mainstream BD material, the studios can tow the line pretty well. If you were an engineer in a studio, and likely a member of the Society of Motion Picture and Television Engineers, the leading technical society for the motion imaging industry, what would you do, to ensure a proper exchange of picture information, given the following SMPTE directive? passively unbound excursions or try to toe the line?
post #244 of 484
Originally Posted by Mr.D View Post
And there was me just about to say I'd come to the conclusion that there was jack over 235 ...from looking at BDs.
There is not much on the HD I've checked so far, there are certainly pixels here and there there on all content I've looked at. As expected light sources and reflection highlights are where you see issues.
You know I did have a problem a while back where I felt freeview looked clipped in the whites unless I was very gentle with the contrast control especially with the microsoft decoder. I hope to hell we don't have double standards going on.
I don't think it's double standards just that material sourced from video cameras is perhaps more likely to have WTW. So far all the really visible examples have not been from a film type process.
post #245 of 484
Originally Posted by dlarsen View Post
Or worse. TV over internet via flash, etc is gaining popularity every day. I have to say that some of it doesn't look so bad. I think abc.com via flash competes pretty well with their OTA HD feed. Maybe just a tad worse, but not too much. I believe much of it is intended to use levels. Did I mention that convergence is a mess?
Dave
Flash is just a wrapper over perfectly normally encoded video. It is the rather crappy flash player that insists on expanding the levels to 0-255 and not doing decent scaling. If you get the content down and play it in a decent player it does indeed look just fine, I find the playback in the flash player to be noisy as I refer to above with the compression pumping and mosquito artifacts extra noticeable due to the lack of a smooth expansion when compared with playback of the same content in anything else.
John
post #246 of 484
Most every frame is banging the rail. Do you have any gain/offset controls upstream of your framebuffer that could effect this? How did you verify that the TV path as having pass-thru levels?
No gain/offest control, this is the output direct from the mpeg decoder in YCrCb space. I've passed test patterns through and the levels have matched up to what is expected.
John
post #247 of 484
This would make sense I guess.
Film to video transfers can have the appropriate time spent on them.
Live or near live broadcast footage can't really be tweaked to the same level on a shot by shot basis.
The easiest solution I guess is to let the white excurse to the maximum range on those occasions where it blows out and not risk a strict clamping to 235 further exacerbating the visibility of clipping that you won't be able to do anything about anyway.
Not saying this is the case but if that was the scenario then you would have to decide whether to calibrate to preserve level up to 254 for broadcast with an associate contrast knock down for "rigidly" mastered material.
Or vice versa and live with clipped broadcast material.
Or you have different calibration regimes according to each source.
Incidentally I did recalibrate last night with 235 mapping to peak white. I also reprofiled in the Upsilon mixer with a 235 custom white point.
I'll talk to you offline in more detail.
BD looked fine with 235. I did check if I was losing anything above 235 and on the odd occasion I when I did get suspicious and checked over the material there was literally nothing there above 235.
Broadcast TV on this setting looked a little harsh to me but nothing too terrible ( need to spend a bit longer watching it).
Curious.
post #248 of 484
http://www.bbc.co.uk/blogs/bbcintern...rom_the_h.html
What do you make of this then?
He seems to be suggesting that there is nothing above 235 but keep it if it gets your peak luminance to a level you are visually happy but correspondingly don't worry if you have to "clip" it to get it there. ( from the perspective of a display that doesn't have the ability to clip the signal independently of the screen itself)
This almost takes us back full circle.
Maybe its easier to think of it in this somewhat facile way:
235 is the "minimum" white point you should map to , that doesn't mean you can't or shouldn't go higher but you definitely shouldn't go lower...
post #249 of 484
You mean, here inside the castle we use proper test patterns and meters, but here's a compressed/messed up one for you plebs, and by the way just adjust it how you like anyway? Not sure I'll read too much into that.
But even so I agree that it is looking like it is going to be a trade off thing with most probably prefering extra contrast ratio on most content at the expense of a bit of "sparkle", as Poynton puts it, in the highlights.
John
post #250 of 484
I'm not sure that's doing what you think it's doing, to clip everything above 235 you need to set up an adjustment with contrast boost set to maximum. Otherwise it will still be outputiing everything above nominal just mapped into a lower range, not very intuitive I'm afraid.
John
post #251 of 484
John
Yep I've replied to you. I wouldn't say its not intuitive , in a way its more clever than I thought as it compensates for display hardware even if it clips.
post #252 of 484
let me summerize you're post....
"If you clamp..."
That is a surefire way to eliminate WTW.
BUT...
I've never seen a cable box that clips.
My Onkyo passes BTB and WTW and my toshiba has no functions for clipping the HDMI signal. The different color channels clip at different intensties. None of this is uncommon.
So what do you recomend when you can't clip?
post #253 of 484
I did some measurements on my RS20 projector last night. Setting Contrast to show all the 'white bars' up to ~ 250, compared to setting it to show only those above 235, gives up about 9% in brightness (i.e., lumens from a 100% IRE window). So one must decide whether or not ~10% extra brightness is worth clipping whites down to 235. Or, of course, one can choose to go halfway down, etc.
post #254 of 484
I think the question is whether there is anything up past 235 worth hanging on to.
I hate clipped looking whites and video ( even from film) always looks clipped to me regardless.
However sacrificing 10% extra brightness is a visually large impact , video is not linear after all. There is no way anyone can justify that if there is literally nothing worth hanging on to above 235.
What we need to do is categorically get to a point where we can say where white is.
post #255 of 484
Agree, absolutely. If there is anything worthwhile above 235, one is probably willing to sacrifice 10% in brightness; but if there is not, then one certainly doesn't want to throw the 10% away. So as you have been correctly emphasizing, the question to answer is whether or not that is anything significant above 235.
post #256 of 484
10% light output is actually NOT that signifigant imho.
If you walked into a room and I showed you a display outputing 120cd/m^2 and then again at 100cd/m^2 and it was a truly blind test, you'd probably be only slightly better than a coin flip at picking them correctly.
You eyes are not that sensitive to the absolute amount of luminance at the highend.
post #257 of 484
I am so glad this discussion evolved into a very serious discussion regarding where white is and what is given up when we decide to clip. I was amazed at the early tone of this conversation when it was so dogmatic.
The conversation has moved to an empirical one that has real meaning for a lot of us. In my case, my green channel runs out of luminance too early to take much advantage of the very beneficial and needed extra luminance, calibrating 235 as the highest white my display produces.
The earlier part of this thread seemed to theorectical and I struggled with really understanding the principle here until 16 and 235 were called reference black and white respectively. I am glad BTB has been part of the discussion as well as WTW.
post #258 of 484
Looked reasonably obvious to me. It wasn't earth shattering I grant you but I suspect it would be more impactful on contrast starved displays.
post #259 of 484
absolutely a big deal on contrast starved displays.
On a perfect display (no light blacks), the conversation would be completely irrelevant because the gain of clipping would be nothing.
post #260 of 484
If we all agree not to argue we can actually reach meaningful conclusions.
I'd really like to put this topic to bed as it constantly rises up again.
I am coming down on the side of 235 with the ever so slight conundrum as to what broadcast does as uncovered by John's clever software.
As ever try it and see is a good bet. I've recaled for 235 on my setup and am so far happy with the result for BD.
I now need to see what what this does for broadcast. It will either look like a clippy mess or be barely noticable if at all.
post #261 of 484
This seems to validate what I've subjectively noticed on BDs and DVDs for quite some time. I don't watch much broadcast material (and regrettably none of it is currently hd for my setup) so I'm interested primarily in the conclusions that will eventually be made in this thread for DVD/BD content in particular.
post #262 of 484
Will be very interested to hear your final conclusions. At present, I am setting Cst to see the white bars (dimly) up to ~ 242; this leaves the bars up to 235 fully resolved. For this I need Cst = +8, whereas I need to reduce it to +6 to see them all the way up to ~ 250. With this compromise I give up only ~ 5% brightness from what I would have if I clipped all the way down to 235 (Cst = +10).
There are obviously an endless variety of choices people can make depending on their situations.
post #263 of 484
Errm, I think you're conflating visual memory with luma descrimination unless you mean given two otherwise identical displays -- can I tell which one is at 100 and which one is at 110 (or 120).
post #264 of 484
Agreed, particularly if we are talking about once your eyes are adpated to the the display and the darker the background. White will look basically the same once adaptation is done, black may be slightly higher but we are talking tiny perceptual differences. The more background light there is the bigger the difference and the more likely you are to spot the drop.
If you skip the adaptation and try and do an a/b then obviously they will be different.
John
post #265 of 484
Did some hacking today and it's looking good for an ffmpeg based software analyser that takes hours rather than days to run later on in the week.
John
post #266 of 484
John
Excellent John that data will be very useful in cracking ths nut.
I'm back home now so I'll reprofile my display once my i1LT warms up based on what we talked about.
It would be good if some of the other participants in this thread could do some testing (those that can) and see if we can actually find anything on BD or dvd that has meaninful level above 235. The more data the better but try and verify your findings.
After we come to a consensus we can further investigate the practical implications with regard to display optimisation which is after all what everyone wants.
I'm hoping we wil just be able to take Occam's razor to this but we'll see. One step at a time.
post #267 of 484
Some years ago I remember watching a DVD that seemed to had meaningful information over 235. I will borrow it from my friend again to re-test it. Though, it might not be very useful, because I think it was a DVD from a movie captured with video cameras, and not from film, so according to one of your posts, it might be the reason... It's a french movie: "8 femmes".
post #268 of 484
Actually I'd love to play along: I have a PC and plenty of DVD's and Blu-rays. Is there free software I can install to join the search for signs of extra-terrestrial life above 235?
post #269 of 484
John
oh yeah if you had set a at 100 and set b at 120 side by side it would be obvious.
but if you walked in and then out and back in, no way you could tell.
post #270 of 484
The program I'll release later on in the week will be free, but to read the data off blu-ray in particular you need a solution to decrypt the disc, most of us use anydvd-hd for this, that is paid software.
John
