AVS › AVS Forum › Blu-ray & HD DVD › HD DVD Software › Anyone heard of these two HD DVD's?
post #1 of 4
I was browsing this site, and found these. Anyone own them, or heard of them? The site says that the language may be Spanish only.
http://www.dvdgo.com/dvd-nuevas-cons...1684706/152692
http://www.dvdgo.com/dvd-bioenergia-...1684705/152691
DB
post #2 of 4
DB
It was probably a mistake, I sent an email confirming it for me and post them whatever.
post #3 of 4
Hi Segak-thanks. Yes, I recall from the days, when we used to place pre-orders for all of these "phantom" listings for HD DVD's, that they ususally ended up being HD mastered DVD's, or just incorrectly listed, with false product feeds. I'll keep an eye out for your post in case you get a definitive response. Have a good one! DB
post #4 of 4
The descriptions for both mention Region B. Region B is in the Blu-ray spec, but not DVD or HD DVD.
  Back to Forum: HD DVD Software
