Most AVR's will pass through HDMI 1.4a 3D video formats to a 3D TV and there is no reason that that HDMI 1.4a video format has to be created by a unit with an HDMI 1.4 transmitter chip or even an HDMI tranmitter chip. A DVI transmitter chip could output the 3D video format and then could have a DVI-HDMI adapter used to connect it to the TV via an AVR.
However. Only a 1.4 capable AVR can extract the audio from the doube packed buffer 3D format transmitted from 3D blu-ray players since the audio is not contained in the same location in the buffer as it is in the other HDMI 1.4a 3d or HDMI 1.3 2D formats.
The solution you are using to avoid getting a 1.4 AVR is completly valid and is often reccomended.
