AVS › AVS Forum › Video Components › Home Theater Computers › FAQ for the 3D HTPC
FAQ for the 3D HTPC - Page 9
post #241 of 1309
Your are confusing what IR emitter and glases you can use with Nvida 3D viewer which are the Nvidia emitter and glases with what IR emitter and glases you can use with Nvidia 3D TV player and a 3D TV which are any emitter and glases that the 3D TV supports.
post #242 of 1309
Me?
post #243 of 1309
Walford, please do explain. The difference i mean.
post #244 of 1309
Yes I can confirm I just use the glasses that came with the TV; no need for any external Nvidia emitter of any kind.
There is a wizard in the Nvidia control panel to help you set up the 3D for your TV using the manufacturers glasses.
Have tried a few more 3D Blu Rays now. It's impressive.
post #245 of 1309
The Nvidia 3D player outputs Frame Sequential content and comes with it's own emitter and glases.
The 3D TV player outputs HDMI 1.4a formated 3D content so it can be received by any of the new 3D LCD or Plasma TVs or by the Mits 3D adapter all of which have their own emitter and glases none of which are compatible with the 3D player glases.
post #246 of 1309
I have a Sony 55hx800 3D TV. Using a Sony s470 blu ray 3D player, Sony 3D shutter glasses, I watched "Cloudy with Meatballs" in 3D, it looked great. I then tried the disc in my computer and it won't play in 3D. I'm using a HDMI cable (same one that worked with the Sony player) and Power DVD 10 markII with latest patch as of Nov.24, 2010, (xxxx826-02), and a LG Blu ray player, GGC-H20L. In other words, the only change is I went from the Sony stand alone blu ray player to the blu ray player in my computer.
Why does this setup not work? The disc plays, but it's in 2D.
Also, I have the nvidia 3d glasses kit with IR xmitter . Since the 3D sync output jack on the TV is a different form factor on the nvidia cable, I can't connect it and test it. Is there any way to get the nvidia setup to work?
post #247 of 1309
The First 3D Monitor with HDMI 1.4a Stereo 3D Support is coming:
Acer HS244HQ
http://3dvision-blog.com/acer-hs244h...eo-3d-support/
http://www.easier.com/80712-acer-hs2...d-monitor.html
_ _ _ _ _
post #248 of 1309
It is my understanding that the 3dtv software currently works only with 3d vision equiped pc's (that is, the 3d vision emitter plugged in). The standalone version of 3dtv (no 3d vision hardware required) is still to be released (by the end of November), and will cost $40.
My GT430 came yesterday, and I am yet to test if it will work, as I do not have and do not plan to have the 3d vision kit.
post #249 of 1309
Can you please take a shoot from this page on your PC:
post #250 of 1309
I just put in my GT430, connected it to my samsung ps50c7705.
Updated 3dtv play software to support my plasma
Ran the stereoscopic setup wizard
Configured tmt3 to use nvidia 3d
Put on my tv´s glasses
Popped in cloudy with a chance of meat
changed to 24hz
Opened up tmt3
Enjoyed 3d fullhd
What a joy
post #251 of 1309
I should also add that I do not have to do any fiddling with settings.
I put in a Normal Blu-Ray and it plays normally. I put in a 3D blu ray and the TV detects it and changes the resolution to Full HD 3D.
Put the glasses on and you're away.
I was going to get a MSI Nvidia N460GTX Cyclone 1GB GDDR5 OC as it is a faster card but the Zotac is perfectly capable of the job.
Are you saying that, when you pop in a 3D blu, your system auto switches to 24Hz and the Tv says "put on your glasses" ???
I have to manually switch to 24 Hz, to play 3D blu, and the tv prompts to put on glasses and switches to 3D by it self.
Problem:
I also switch to 24 (from 50hz) when viewing 2D blu, and then it still prompts me to put an the glasses, then i have to disable 3D on my remote
Can this be done in a different way ???
How is your setup, what player do you use, tmt3 or pwdvd ?
post #252 of 1309
I'm totally confused. According to the nvidia website, 3DTV Play software is not out yet, but I've seen several posts from people who supposedly are using it. Are we talking about the same thing?
I just bought a Sony 55hx800 because it's listed as a supported 3D Tv for 3DTV Play software. I can't play games/blu ray disc using my nvidia3D glasses because my 3d vision emitter is incompatible with the 3d sync output of my TV. If the software exists that allows me to use my sony emitter and sony glasses, please tell me how to get it. If the software does not exist, what are people referring to in these posts?
post #253 of 1309
They were sneaky, those nvidia guys...
They just implemented the 3dtv play software, without really announcing it.
I also thought that it would be software, that you had to purchase, guess they changed their minds on that.
Just update to the newest drivers and it will be included.
I think you should remove your 3d vision emitter, totally from your system.
That way I bet you can run the stereoscopic wizard, an use your sony tv´s emitter and glasses.
Just like I use my samsung ones.
post #254 of 1309
Tried it, didn't work. I did the setup and the test app is in 3D, but that's all that's in 3D. Games are in 2D. The only 2D/3d switch I know of is the "enable stereoscopic 3D" box in the control panel. All the other stuff on that same page is greyed out except the "test stereo 3D" box which I used to verify that the test image is 3D.
Is there some super secret hidden switch somewhere that needs to be set to 3D? The game I tested works perfectly in 3D using my nvidia glasses on my former Sammy plasma set, so I know the game works.
How do I get games into 3D?
On your setup in the control panel, on the "set up stereoscopic 3D" page, is the depth control greyed out, or is it active?
post #255 of 1309
Sure thing.
Here is the config on the Nvidia Software. PC is connected to TV via HDMI 1.4 cable:
Driver is 8.17.12.6099 Nvidia GeForce GT 430
Here is the config in the Arcsoft TotalMedia 5 Software:
Start up Media Center:
Put in 3D Blu Ray:
AnyDVD Scans the disk:
TV Switches to 3D Mode automatically:
Select 3D mode on the blu ray and put Panasonic glasses on:
Watch the Film
Hope this helps in some way.
Cheers
post #256 of 1309
It´s greyed out...
post #257 of 1309
@turbofeet
Weird how your desktop switches to 24Hz
My sammy wont do it ???
Have to do it manually
You have a desktop @ 60 or 50 Hz...
You pop in a disc...
Arcsoft tmt3 or is it tmt5 launches...
Desktop switches to 24hz automatically ????
Nvidia says in their documentation that you have to do that your self
Arcsoft says they haven´t implemented such a feature
How are you acheiving this ?
post #258 of 1309
Sure thing.
OK, thanks.
post #259 of 1309
rica is showing a fully active "set up stereo 3D" page, that is, nothing is greyed out.
turbo and 8hr are showing what I have, everything greyed out except the 'enble 3D ' box and the 'test 3D box.
Turbo, I basically get what you are showing with "Cloudy..Meatballs 3D" disc. The software player (I'm using Cyberlink PWRDVD 10 Mark II) acknowledges capability, but image is only 2D no matter what settings I choose.
Has anyone been successful playing games in 3D?
post #260 of 1309
This is what i was wondering?
post #261 of 1309
The 3d settings cannot be controlled for 3d blu ray (it's just playback, not composing the 3d image, as in simulating 3d or rendering 3d game frames), being greyed out is expected.
It seems the 3d blu ray output is enabled, it's just the 120Hz mode (read: gaming) that is not. This is news for me, and in a good way. All I need from my new gt430 is full-res blu ray playback. The 120 Hz projector is still in the (Black Friday/Christmas) future. Hopefully, the 3dtv Play will be released by then.
post #262 of 1309
I am completely confused as to the best way to set up my HTPC. It will be hooked up to the new JVC projector coming out shortly. I am currently using TMT3 to play my ripped blurays and would like to know the best software to use. I am using Windows media player with the TMT3 driver.
Is there a video card that can send 3d signal to the projector and then a seperate HD audio signal to my 1.3 Denon receiver?
Is there software that can vertical stretch a 3d image so that I can still use my anamorphic lens for CIH setup?
Your help would be greatly appreciated as this is so overwhelming. I bought the new Oppo player that is 3d capable since I didnt think it was possible to do on my HTPC yet but now it is looking promising by the posts I read. So I may just sell the Oppo.
post #263 of 1309
[quote=adammb;19547757]I am completely confused as to the best way to set up my HTPC. It will be hooked up to the new JVC projector coming out shortly. I am currently using TMT3 to play my ripped blurays and would like to know the best software to use. I am using Windows media player with the TMT3 driver.
QUOTE]
I bought the nVidia GT 430, hooked up the tv to the hdmi out.
Used an old Ati dvi to hdmi adapter, and hooked up my onkyo 1.3 amp, with a hdmi cable.
So now I have 3D full-hd on the hdmi
And with the Ati adapter I have full-hd audio on my 1.3 onkyo
Am using Arcsoft TMT3 with 3D plugin, works like a charm.
Holdig off on the TMT5 version a bit longer, needs bugs sorted out.
post #264 of 1309
Have you seen anything that does the vertical stretching. I was leaning towards the TMT5 because they sent me a black friday special of $60.
To clarify the DVI to HDMI adaptor is a simple cord adapter plugged into the video card correct?
If this is the case then I can finally rip all my movies onto my computer and not have to deal with switching out disks each time which would be fantastic. Although I would need to run a second HDMI cord to my projector which isnt the end of the world and for now my easiest solution. Now if only I could figure out how to vertical stretch the image without spending $3000
post #265 of 1309
PC is set to 60HZ and the Panasonic TV is set with 3D Mode on Auto.
To be honest I think the TV is the key part that is making it all work for me and the fact that the Gfx card and the TV both have have HDMI 1.4 connections and are connected by a HDMI 1.4 cable.
I am using a seperate sound card as well (ASUS Xonar HDAV 1.3 Deluxe) for bistreaming so I do not need to put the HDMI Cable through the Amp, which is another factor out of the way.
post #266 of 1309
Guys,
I can't see any supported Acer DLP HD ready PJ on the list of supported 3D PJs of AMD HD3D Technology.
Any feedback from Ati 6870/6850 owners with any Acer 3D ready PJ + active shutter glasses (compatible with DLP Link) would be appreciated.
Or any other supported PJ owner might tell us what's happening with an Ati?
(BTW AMD doesn't have its own Ati3Vision+ shutter glasses )
post #267 of 1309
I want to use my HTPC for gaming also, which Nvidia card should I get and which intel core i7 should I use? I was thinking between a i7-920 and i7-950. But if I could use a cheaper intel, which one should I get?
post #268 of 1309
If you want a quite decent but quiet one maybe this might be worth a go:
Otherwise a more beefy one if u don't mind the noise.
post #269 of 1309
I solved my two problems..
1.can't game in 3D:
Turns out, the Nvidia sync emitter module must connect to the computer even though the nvidia emitter and glasses aren't used to play games. The other jack on the nvidia emitter is disconnected. Basically, you go through the same routine to set up 3DTV play as nvidia 3D vision, only you wear the TV glasses instead of the nvidia glasses. After you finish setup, you can set the desktop resolution to anything you want, but you must set the in-game resolution to 1280x720 in order to get 3D. Other res will play but it will be 2D. Also notice the nvidia control panel will no longer be greyed out under "set up stereo 3D".
Can't play Blu Rays in 3D:
I had all hardware required except the cable. I sorta knew cable had to be HDMI 1.4, but since the HDMI cable I was using worked with my stand alone Blu Ray player, I assumed I met these requirements, whatever those requirements are. Turns out HDMI 1.3 satisfies stand alone requirements but not computer requirements, which must be 1.4. I ordered a 1.4 cable, so presumably it will work although right now, this is only an unproven theory. Even with all the correct HW and SW, you must go to the nvidia control panel and set the resolution to 1920x1080 x 24 refresh, do this by choosing this res under 'HD3D' and refresh will change to 24. This is necessary only for Blu Ray playback in 3D.
Here's how to set up 3DTV play:
http://www.nvidia.com/object/3dtv-play.html
Go to this address and click on 'set up guide' on the left hand pane at the bottom.
Hope this helps those who want to both game and watch blu ray 3D on their computers with a 3D ready TV.
post #270 of 1309
