Originally Posted by
jakmal
I think this is probably the issue with the PS3 (HDMI controller being clocked lower resulting in lesser than available bandwidth as per spec).
Well, PS3 developers explained the main reasons for limiting HD audio to DD/DTS
in an entirely different way, whatever you (or 8:13 or whoever) think.
(I am sorry the interview is Japanese as the 3D developers are Japanese.)
jakmal
This is just conjecture, but I think we might need a new chip in the PS3 to be proper HDMI 1.4a compliant.
It looks like they are not so optimistic about implementing HD audio bitstreaming by a firmware upgrade (need to tweak memory and SPU further). It is under development anyway.
jakmal
Spec-wise, both HDMI 1.3 and HDMI 1.4 have the same bandwidth (340 MHz clock), but in reality, it is very difficult to clock the HDMI controller at 340 MHz in an ASIC. Usually, the HDMI controller design is constrained to operate at lower frequency.. so even chips which claim HDMI 1.4a might not run their controllers at 340 MHz.
This is
correct, but: Actually the video bandwidth necessary for the mandatory HDMI 1.4a 3D video formats is not so different from that of HDMI 1.3 2D video formats.
- Frame Packing 1080p@24: 1920 x (1080+1080+45 [Active space]) x 24Hz =
101.6MHz, 101.6MHz x 24 bit x 10/8 [overhead]=
3.04 Gb/s
- Frame Packing 720p@60: 1280 x (720+720+30 [Active space]) x 60Hz =
112.9Hz, 112.9Hz x 24 bit x 10/8 [overhead] =
3.39 Gb/s
- Side-by-Side (Half) 1080i@60: (960+960) x 540 x 60Hz =
62.2MHz, 62.2MHz x 24 bit x 10/8 [overhead] =
1.87 Gb/s
- Top-and-Bottom 720p@60: 1280 x (360+360) x 60Hz =
55.3MHz, 55.3MHz x 24 bit x 10/8 [overhead] =
1.66 Gb/s
- Top-and-Bottom 1080p@24: 1920 x (540+540) x 24Hz =
40.8MHz, 49.8MHz x 24 bit x 10/8 [overhead] =
1.49 Gb/s.
Compare:
2D 1080p@60: 1920 x 1080 x 60Hz =
124.4MHz, 124.4MHz x 24 bit x 10/8 [overhead] =
3.73Gb/s.
The resolution of Frame Packing 1080p is twice, but the refresh rate is only 23.976Hz/24Hz.
And audio is nothing compared with video,
~0.04 Gb/s (multichannel LPCM).
Further audio data are carried in the Data Island Period (Hblank and Vblank), so that audio bandwidth is guaranteed. Seeking the reason for non-HD audio bitstreaming in the bandwidth argument of HDMI 1.3 vs 1.4 sounds ridiculous for me (and is wrong according to the developers [although they did not deny it explicitly]).
