AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › KuroControl program for Pioneer KRP500m/600m and Elites
KuroControl program for Pioneer KRP500m/600m and Elites - Page 8
post #211 of 329
Originally Posted by mfilippello View Post
here's the log from my connect attempt. I refreshed once and then powered on. I am not a computer guy so please forgive my basic level of understanding. Since this product now has rs232 support and the 8g units obviously use that to communicate, i figured any info might help.
yeah it looks like your tv doesn't support most of the commands that i'm using.. the reason that the power button is flaky is because the QST command fails also and thats what I use to check the power state.. otherwise it looks like the protocol is the same..
post #212 of 329
Originally Posted by krp-500m View Post
Just a thought... since it looks like the IP address is correct and is being responded to...
If you have a Mac or linux, you could potentially run a port scan on the TV's IP and try to narrow down on the port numbers it can possibly be listening for control connections...
On windows PCs there may be similar tools that you can install..
I have a KRP-500A, european model.
It is listening on the following ports:
80 (HTTP)
110 (POP)
3128 (SQUID)
8080 (HTTP-PROXY)
I assume Kurocontrol does not have a way to set the port at the moment.
Would you mind allowing us to set it up ourselves in the GUI, or give the option to use 3128 ?
Thx !
post #213 of 329
80 (HTTP)
110 (POP)
3128 (SQUID)
8080 (HTTP-PROXY)
Thx !
Ok I added a port setting for the network connection..
post #214 of 329
It seems better now, but I don't know what this means... works or not ?
02/05/2010 19:38:37 Connecting to 192.168.1.18...
02/05/2010 19:38:37 Connect Succeeded
02/05/2010 19:38:37 Sending Command ISN...
02/05/2010 19:38:38 An existing connection was forcibly closed by the remote host
post #215 of 329
It connected but it looks like that port is being used for something else since the connection was closed right after the first command was sent..
post #216 of 329
So I guess this means there's not gonna be a way to connect then ?
post #217 of 329
If that model doesn't support IP commands then you have to connect through the serial port..
post #218 of 329
Sure, I meant over ethernet.
Thx for your help anyway xsiv4ce
post #219 of 329
80 (HTTP)
110 (POP)
3128 (SQUID)
8080 (HTTP-PROXY)
Thx !
What program/utility did you use? Did you make sure to scan for "all ports" in a range (for example, 80 to 10000). The reason I ask is that typically the port scan utilities scan for only the "common" or "well known" ports unless you explicitly specify the option to scan all.
post #220 of 329
First of all, thanks xsiv4ce for posting this program. But it seems that I got some problems when I tried to connect to my 600m. Here is the error message.
5/16/2010 10:58:05 AM Connecting to 192.168.0.106...
5/16/2010 10:58:05 AM Connect Succeeded
5/16/2010 10:58:05 AM Sending Command ISN...
5/16/2010 10:58:05 AM Command reply = XXX
5/16/2010 10:58:05 AM Command failed
5/16/2010 10:58:05 AM Sending Command OSDS01...
5/16/2010 10:58:05 AM Sending Command INP...
5/16/2010 10:58:05 AM Sending Command INPS00...
5/16/2010 10:58:06 AM Command reply = XXX
5/16/2010 10:58:06 AM Command failed
5/16/2010 10:58:06 AM Sending Command AVS...
5/16/2010 10:58:06 AM Sending Command FST...
5/16/2010 10:58:06 AM Sending Command CNT...
5/16/2010 10:58:06 AM Sending Command BRT...
5/16/2010 10:58:06 AM Sending Command COL...
5/16/2010 10:58:06 AM Sending Command TNT...
5/16/2010 10:58:06 AM Sending Command SHP...
5/16/2010 10:58:06 AM Sending Command CTP...
5/16/2010 10:58:06 AM Sending Command RHI...
5/16/2010 10:58:06 AM Sending Command RLW...
5/16/2010 10:58:06 AM Sending Command GHI...
5/16/2010 10:58:06 AM Sending Command GLW...
5/16/2010 10:58:06 AM Sending Command BHI...
5/16/2010 10:58:06 AM Sending Command BLW...
5/16/2010 10:58:07 AM Command reply = XXX
5/16/2010 10:58:07 AM Command failed
5/16/2010 10:58:07 AM Sending Command GMM...
5/16/2010 10:58:07 AM Sending Command PUC...
5/16/2010 10:58:07 AM Sending Command ITM...
5/16/2010 10:58:07 AM Sending Command TOP...
5/16/2010 10:58:07 AM Sending Command DRP...
5/16/2010 10:58:07 AM Sending Command BLK...
5/16/2010 10:58:07 AM Sending Command ACL...
5/16/2010 10:58:07 AM Sending Command ENH...
5/16/2010 10:58:07 AM Sending Command CTI...
5/16/2010 10:58:07 AM Sending Command CGR...
5/16/2010 10:58:07 AM Sending Command CGY...
5/16/2010 10:58:07 AM Sending Command CGG...
5/16/2010 10:58:07 AM Sending Command CGC...
5/16/2010 10:58:07 AM Sending Command CGB...
5/16/2010 10:58:08 AM Command failed
5/16/2010 10:58:08 AM Sending Command CGM...
5/16/2010 10:58:08 AM Command reply = XXX
5/16/2010 10:58:08 AM Sending Command CSM...
5/16/2010 10:58:08 AM Sending Command NR3...
5/16/2010 10:58:08 AM Sending Command FNR...
5/16/2010 10:58:08 AM Sending Command BNR...
5/16/2010 10:58:08 AM Sending Command MOR...
5/16/2010 10:58:08 AM Sending Command DYC...
5/16/2010 10:58:08 AM Sending Command IPM...
5/16/2010 10:58:08 AM Sending Command FFM...
5/16/2010 10:58:08 AM Sending Command GR1...
5/16/2010 10:58:08 AM Input string was not in a correct format.
5/16/2010 10:58:08 AM Sending Command QST...
5/16/2010 10:58:08 AM Command reply = QST5*MSN*IN6IN620***000000000 IAPM000891UC000**01465CE
5
I tried both the network and serial port, both give me the same result. I used KuroReader, and I can connect to it. I am wondering whether I need to enable anything else in 600m in order to make it work. Appreciate for any suggestions.
PS. I tried to use IE and firefox to connect to 600m, but whenever I type password and click enter, the browser closes itself. Not sure if this problem is related to the problem with KuroControl.
post #221 of 329
5
It looks like you got out of sync. That shouldn't happen with a serial connection.
The browser problem is caused by blocking pop-ups.
post #222 of 329
Thank you very much, Bodosom. I found out that I have to leave the TV on for KuroControl to get any settings from it. I put the TV in standby when I tried it last time, since KuroReader can read info from it when it is in standby.
Thanks again for the help.
post #223 of 329
Can someone confirm that this works fine with the 101FD? Is there any potential damage that this program can do to the panel?
post #224 of 329
83.
If you're worried you should buy ControlCAL.
post #225 of 329
I just set up ISF Night, and everything looks great.
Only problem is that I can't seem to make any changes to the Sharpness setting.
post #226 of 329
For the sharpness setting, it's always best to use the adjustment arrows instead of manually inputting "113". Once you get sharpness working for a different ISF mode or input, Save the settings to an XML file (Save button on the right of the window), and then reload it (Load button) onto the ISF setting that has a non-working Sharpness setting. That's how I fixed it for myself... I'm sure there's a better way of doing it (i.e. sending the command manually).
post #227 of 329
How do you send the sharpness command manually?
I tried editing one of the XML files with Notepad and set the Sharpness to 113, but it doesn't work. Neither did trying to adjust Sharpness on another picture setting.
post #228 of 329
SHPnnn
I use -10 (which is 005 which is 118) hence SHP118. You may recall I said
SHP 113 - 143 (0-30)
post #229 of 329
Gamma seems to return at 3 while I want it at 2.
What am I doing wrong?
post #230 of 329
If you're using the ISF modes, the gamma should be 3, which means the 9-point gamma is being used. You can't set the one point gamma when using the 9-point gamma...
post #231 of 329
post #232 of 329
After adding ISF day & night, KuroLink is greyed out. Any way to activate it?
post #233 of 329
Dang, even sending the Sharpness setting manually doesn't work. I wonder, has anyone with a 101FD been able to adjust Sharpness for an ISF mode? Hopefully it's something the author can look into for the next release.
post #234 of 329
Given a proper configuration it shouldn't be but it doesn't do anything but cause problems.
post #235 of 329
Since it works there's nothing to look into. Rather than seek outside explanations (e.g. my 101FD is special, the program is defective) you should look inward.
post #236 of 329
Like I said, try to set the ISF mode in another input and Save it, then Load it on the malfunctional sharpness input. Or how about this, you can download my ISF-Night setting (see attached) - just change later.
ISFNight.zip 0.5400390625k . file
post #237 of 329
KuroLink workes after properly restarting the PS3 and the AVR.
Just wanted to report back.
post #238 of 329
I don't know why, but the program won't even load up other picture settings and insists on showing ISF Night and what I've set for it. I tried setting it to Pure to see if the -15 Sharpness setting already in place would transfer into KuroControl, so I could then copy it and/or see if/why it would show up but not allow me to adjust it for ISF Night...but the Pure settings won't load up at all. Changing inputs doesn't seem to help; I can't seem to be able to do anything with the program other than set up ISF.
post #239 of 329
I don't know why ...
I can't tell if you're asking for some help or making idle observations.
I'm just sayin ...
post #240 of 329
Use my settings. Also, the setting numbers for Pure aren't the same as ISF. Most ISF settings use the 128 system, and I'm not sure what Pure uses.
