The height you have them at seem about right, just make sure their high enough so you or someone taller can't easily see the light from above.
The Grafik eye is a very nice piece of hardware and I luckily scored a 6 zone for less than what your seeing on Ebay for a 4 zone. Keep looking you might get lucky.
The other option is Insteon lighting controllers from smarthome as well. You will be able to easily control with an IR remote as well if you get their IR adapter or the X10IR adapter. Insteon works with X10 stuff, it's pretty much next gen.
http://www.smarthome.com/_/INSTEON/_/23b/land.aspx
I use this x10 IR controller to control an Insteon outlet for my showcase lighting behind my screen. I have it mounted below my center channel and the Harmony IR signal goes thru the AT screen to control it.
http://www.smarthome.com/4040/Infrar...-IR-543/p.aspx
The nice thing about insteon switches and outlets is that you can easily upgrade everything as you go or you can afford, in the end you can have your whole house automated.
