Amp is Sony STR-DA3400ES
I am trying to get the IR (remote) to work from a longer distance than the normal. So, I bought an IR "extender" that plugs into the back of the receiver. There are three IR connections in the back - two outputs and one input. I plug the extender into the IR input. Nothing! I assume that input is correct since I am trying to input an IR signal.
So, I bought a different style IR extender - same result. Nothing!
There is nothing in the GUI setup regarding IR input/output (also very little in the receiver user manual.
I'm almost afraid to ask - do I plug it into the IR output?
