AVS › AVS Forum › Audio › Speakers › Sealed In Wall speakers on a budget?
post #1 of 6
I am looking for a pair of in walls for a bedroom. The location of the speakers is a shared wall with another bedroom and sound passing through the wall is a concern. It seems that a sealed in wall speaker would be a good choice to help isolate sound.
Does anyone have any suggestion on in wall speakers that are sealed or ar ein a sealed enclosure and are budget friendly? I found a seies by Klipsch and Antlantic Technology but both are wlel above my budget for this application. I was hoping for find something serviceable in the sub 300$/pair range.
post #2 of 6
How about these? http://www.axiomaudio.com/t2.html
post #3 of 6
Axiom has a great rep. Some good advice there, especially since The Speaker Company is no longer an option.
post #4 of 6
how about these? http://www.axiomaudio.com/t2.html
+1
post #5 of 6
I'm looking for the same thing. Is Axiom still the best and only choice or has the market expanded?
post #6 of 6
What is your budget?
  Back to Forum: Speakers
