So i've been trying to figure out the best way to wire my new home, I'm really confused with the wealth of information I've read and I'm trying to see if someone could help me with the right approach?
Basically my 'Phase 1' approach to the project is just doing a pre-wire for the entire home with a centralized A/V system. 'Phase 2' would be integration of Control 4.
I understand the concept of running 2RG6 + 2Cat5e to every TV location for current and future TV's. This will get me 2Coax, 1 Data and 1 Phone. Then for the purpose of just networking running tons of Cat5e or Cat6 where necessary.
Now what I'm confused about is how to connect/terminate the various runs to each location and if I should just be using Cat5e or actually running Component, RCA's etc as well. For Instance:
My main living room with have a 55" Samsung LED-LCD tv mounted above a fireplace. There will be 5.1 Surround mounted in the walls/ceiling with a subwoofer. My thought is I'll need to have a wall plate in back of the TV so you can't see the wires. But what kind of terminations should be there? If I have 2RG6 + 2Cat5e there would that be enough? If so how do I distribute the video to the TV? Do I use a 'balun' here? If so I'll need more Cat5e correct? And if that's the case, do I connect via HDMI or use Component? I've seen products that take a Cat5e able and has a wall plate you connect it to that then has Component, RCA, digital audio, etc ports on it. I'm just really confused at what to use? Then some people will just run a really long component cable from the A/V rack to the TV, but I've heard doing everything with Cat5e and baluns is the way to go. The audio to the surround I'm not worried about because the receiver would be in the central A/V rack with the speaker wires going there.
Also with the above setup. What if I wanted to connect a local DVD player, Xbox or Local Audio Source in that location? I'd have to have Cat5e runs to handle that as well with the use of baluns and wall plates so the DVD/Xbox has something to connect too?
Speaking of the Baluns, I've seen some that are wall plate like, and then are just sort of 'boxes' ... does it matter which ones to purchase? The box ones seem like they'd be ugly to install.
My other concern is if I start WITHOUT Control 4, how am I going to Control the TV, Receiver etc w/ a remote when the Receiver is upstairs in a different room?
Another concern is I want to have a centralized A/V rack that distributes the audio/video thru the home, but what if I sell the place in 10 years and the new owner just has local sources and doesn't want to purchase the equipment for a centralized system? Should I plan for that as well? If I did that, what would I need to do? Run speaker wires from the surrounds to a local 5.1 wallplate alongside the wires running to the A/V rack? Then also having a wall plate that will sent video signals to the TV? It just seems like I'd be setting up 2 systems, no?
If anyone can shed any light I'd appreciate it. I'm trying to wire the home myself in order to save thousands on labor. I know I can do it but I just have some confusion on what needs to be done.
Ryan
Ryan
