WRITE DOWN YOUR CALIBRATION SETTINGS (ALL OF THEM) WHEN YOU UPDATE YOUR TV, IT MAY* REVERT BACK TO FACTORY DEFAULT SETTINGS. EASIEST WAY IS TO GO THROUGH THE MENUS AND TAKE PICTURES OF THEM
*(I have reason to believe this only happens when the firmware upgrades the sub board as FW 1012 did, Samsung does not say directly what is being updated, so as a safety measure, take down the calibration settings, as they may or may not reset)
FIRMWARE 1032.0
Release Notes
1. Title
2010 PDP TV Firmware (Folder Name: T-VALAUSC, Version : 1032.0)
2. Applicable Model
PDP C6400, C6500, C7000, C8000
3. Carrier or Corporate Customer
All Customer
4. Description
Support Netflix 2.1 and MLB.tv apps.
And this firmware prevents below issues
. ''USB Power Overload'' message pops up even USB port is not connected
. HDMI ports recognition error and signal loose
. Plug & Play is displayed whenver turning on TV.
Official Samsung Download Center Select Your TV Model From The List
Mirror's (1032.0 Download's if Samsung Site Is Not Working or if the download is slow, File is compatible with all listed TV model's)
Mediafire 1032.0
FIRMWARE 1030.1 (FIRMWARE DATE:11OCT2010)
Applicable Model's
No Known Release Notes
Mirror's (1030.1 Download's if Samsung Site Is Not Working, File is compatible with all listed TV model's)
Mediafire 1030.1
FIRMWARE 1029.0 (FIRMWARE DATE:29SEP2010, POSTED:05OCT2010)
Applicable Model's
Due to Samsung's recent changes to the website, they no longer post the Change-log to the FW files, I contacted them through Live Chat to see if I could get some information, here is what was received:
Karl: Add ''3D Optimize'' option on Menu for better 3D image.
Karl: Enhance performance to enjoy Internet @TV Apps ''MLB''
Karl: And this firmware prevents below issues
Karl: - ''USB Power Overload'' message pops up even USB port is not connected
Karl: - Plug & Play is displayed whenver turning on TV.
Karl: - HDMI 2 is activated when HDMI 1 port is connected.
Official Samsung Download Center Select Your TV Model From The List *CURRENTLY PULLED FROM WEBSITE, 1026 ONLY AVAILABLE FROM THE MAIN SITE*
Mirror's (1029.0 Download's if Samsung Site Is Not Working, File is compatible with all listed TV model's)
Mediafire 1029.0
Firmware 1026.0 Now Available.
Here are some Mirrors for FW 1026.0 if you cannot access it from Samsungs Site.
Mirror 1
Mirror 2
1. Title
2010 PDP TV Firmware(Folder Name: T-VALAUSC, Version : 1026.0)
2. Applicable Model
All Customer
4. Description
. To prevent ''No Picture, Sound OK''
. ''Plug & Play'' Issue
* Problem : The TV will go to ''Plug & Play'' everytime you turns the TV on
. enable to enjoy ''Netflix'' and ''Blockbuster''
. enhanced 3D picture quality (3D TV only)
. intermittent problem some stream may have when playing ''Media play''
Firmware 1022.1 Now Available.
1. Title
2010 PDP TV firmware(version : 1022.1)
2. Applicable Model
All Customer
4. Description
Firmware 1021.2 Now Available, single update file, READ THE UPGRADE GUIDE.
1. Title
2010 PDP TV firmware(version : 1021.2)
2. Applicable Model
All Customer
4. Description
Firmware 1019.1 Now Available, single update file, READ THE UPGRADE GUIDE.
1. Title
2. Applicable Model
All Customer
4. Description
- enable to enjoy ''Netflix'' and ''Blockbuster''
- enhanced 3D picture quality (3D TV only)
- Add ''3D Optimize'' option on User OSD (3D TV only)
- intermittent problem some stream may have when playing ''Media play''
Also as stated by Scarabaeus
"The new firmware 1019.1 updates the TV from HDMI 1.4 to HDMI 1.4a
It now supports Top-and-Bottom signalling over HDMI.
Supported modes:
HDMI 1.4a mandatory modes:
* Frame Packing 1080p24, 720p60
* Side-by-Side(half) 1080i60
* Top-and-Bottom(half) 1080p24, 720p60
Additional supported modes:
* Side-by-Side(half) 1080p60, 720p60, 1080p24, 1080p30 with horizontal subsampling
* Top-and-Bottom(half) 1080p60, 1080i60, 1080p30
Unlike the Panasonic, it does not support Quincunx subsampling for side-by-side. This eliminates the correct display of Sensio material."
Firmware 1017.0 Now Available, single update file, READ THE UPGRADE GUIDE.
Whats Changed:
1. Title
Firmware ver. 1017.0
2. Applicable Model
PDP C7000
All Customer
4. Description
Enhanced picture quality of 3D
Firmware 1016.0 Now Available, single update file, READ THE UPGRADE GUIDE.
The PN50C7000 I got shipped with 1009 FW, I connected it to my network, downloaded the Internet@TV apps, then went to the FW update page and selected update from Internet, to my dismay, no update was available, so at first I thought maybe it was just the BR player that got the update, but I was wrong, the TV did to, but the update did not push to the servers so I checked Samsungs website, and their they were, two updates, one for the main board and one for the sub board. If you own this TV and plan to do the FW upgrade, ABSOLUTELY READ THE "UPGRADE" GUIDE, YOU MUST INSTALL THEM BOTH, BUT IN ORDER 1012 THEN 1014.
So I gave in last night on 09APR10 and purchased the PN50C7000 with a good amount off due to I was upgrading from a warranty return. The bad news is that the store I went to was out of stock on both the BluRay players and the glasses, but they did order them for me. The 2D picture on this set is beautiful. Anyways on to the firmware.
- NETWORK UPDATE: 1032.0
- USB UPGRADE: 1032.0
FIRMWARE 1032.0
Release Notes
1. Title
2. Applicable Model
All Customer
4. Description
Mediafire 1032.0
Applicable Model's
Mediafire 1030.1
Applicable Model's
Mediafire 1029.0
Mirror 1
Mirror 2
1. Title
2. Applicable Model
All Customer
4. Description
1. Title
2. Applicable Model
All Customer
4. Description
1. Title
2. Applicable Model
All Customer
4. Description
1. Title
2. Applicable Model
All Customer
4. Description
Supported modes:
Whats Changed:
1. Title
2. Applicable Model
PDP C7000
All Customer
4. Description
