I built a new house and installed a Leviton 42" structured wiring panel. I have the supply wires for the TV cable coming in there. I have 7 CAT6 and 7 RG6 from the various rooms coming there. I bought a D-link 8 port gigabit switch.
Here are the equipment that are going to go inside the panel. The panel has 2 AC outlets and I am planning on putting a power strip inside.
1) Cable Modem
2) 8 port switch
3) HD Home Run
4) all the AC/DC power supplies and power strips
5) RG6 cable splitter (I am getting 1-4 splitter right now - because I don't need TV cable in all rooms - might upgrade later with an amp).
Now, how do I attach them inside the panel so that they are all securely mounted inside. There are a lot of little holes - they are made for Leviton's own switches (costs a lot), etc. Is there a generic mounting hardware I can use?
1) Cable Modem
2) 8 port switch
3) HD Home Run
