Originally Posted by
MKtheater
Which ones? How much?
Don't know yet. Was not going to pursue this if nobody was interested. I will let you know. I picked up a pair of JBL 8340's. Really like them a whole lot better than the Klipsch RB-35's that I was using for surround. One thing that I like about the 8340 over the 8340A is the ability to play them flat. There is a switch to remove the X-curve. Even though they are bigger, they work better in my room since I can mount them higher due to the angled baffle.
