I am running a digital optical cable from my Vizio 42" VS420LF1A directly to my Sony Home Theater receiver and it will not output in Dolby Digital 5.1, even though I have my TV settings set to Dolby Digital in the menu, and the receiver is on Automatic detection of the signal. Instead the audio comes out in PCM format.
If I remove the digital optical cable from my TV and plug it directly into a device (ie: my Blu-ray player/HD Satellite box) the audio comes out in 5.1 just fine.
What could the issue be? I'd appreciate any help.
Thank You,
Derek
Thank You,
Derek
