AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Official Panasonic DMP-BDT300/350 Owners Thread
Official Panasonic DMP-BDT300/350 Owners Thread - Page 14
post #391 of 923
Originally Posted by Sound & Vision View Post
IMO..... It's the player for sure, and not the disc.. I only say this because if it was the disc reports and complaints would be popping up all over these boards. So far it is only this specific line of panasonic players that are effected.
It looks like your opinion is a valid one... I tested using another Iron Man 2 BD and audio dropouts still occur at the same points in the movie.
post #392 of 923
I agree, the french soundtrack of IM2 is in DD5.1 and full of dropouts.
Originally Posted by JimmyRockFL View Post
Unfortunately, I just ran a movie that utilizes dolby true-hd and found 2 dropout cases. So it seems like my hypothesis on DTS-HD being the culprit is false.
post #393 of 923
Nice!! Newer firmware (1.61) is now out!! I havn't had a chance to try it, but will definantly install it! Keep this link bookmarked as new firmware shows up here first.
http://panasonic.jp/support/global/c...00_350_na.html
post #394 of 923
Going to try when I get home from work. Thanks!
post #395 of 923
I am not a happy camper. I just updated to the new firmware (1.61) on the BDT-350 and it removed my 5.1 output individual speaker settings that I had saved.
Even worse though, is after the firmware, making adjustments to the individual speaker level settings does not work at all. If you change the decebel levels using the pink noise generator from the player to allow you to adjust the speaker settings using an SPL meter, the actual pink noise levels do not change anymore as you adjust the decibels on the player for each speaker (so you can't make any individual speaker adjustments).
This probably will not effect most folks, but as I use an old Cary Cinema 6 that does not allow you to make adjustments using the the pre/pro when utilizing the audio inputs, this function was crucial for me to get proper sound when using the BDT-350. Now I wish I did not upgrade:-(
post #396 of 923
A friend is using an Adapter Kit (3DA-1) with DirecTV and Mits 82737. If he connects a Pany 300/350 blu-ray player directly to the TV (not through the adapter) & sets the Pany & TV each to their 3d mode, will he be able to use the 3d glasses to watch a 3d Blu-ray dvd? I don't know what determines when the adapter emitter is on (does it need to be in 3d mode and/or need a signal going through it?).
post #397 of 923
The big test will be to see whether the audio dropouts people are experiencing on certain movies are corrected. I can try Iron Man 2 this weekend if people want me to test. Someone else might be able to test earlier?
post #398 of 923
Yes, set the players 3D mode to checkerboard and I would just plug the emitter right into the back of the TV and not through the adapter.
post #399 of 923
I am a UK owner of a BDT300 and had reported audio drop-outs on several disks (Gladiator EU remaster, Prince of Persia, Robin Hood) on this forum.
I updated to the new firmware today (BDT300 v1.42) and did a quick test on Prince of Persia, since that was by far the worst offender. The good news is that the problem appears to have been addressed by this latest update!
I have over 200 Blu-Rays and this is the first time I have had this kind of problem with Panasonic, and they appear to have responded pretty quickly. By comparison with other brands, I am impressed. I think there is some unwarranted criticism of the player, since the problem is typically disks that don't follow the standards and cause hardware problems - maybe we should criticise the Blu-Ray software suppliers, not the players?
One final point - as usual, my trusty PS3 was able to play these without any issues! However, the picture quality of the BDT300 is much better and the two HDMI outputs for HD audio make it well worth the investment.
post #400 of 923
Has anyone tried separating sound and video apart with the spare hdmi outlet on the bdt300/350s?
I'm also wondering if perhaps the network device is causing trouble. If you've ever had experience with troubleshooting PCs, sometimes an audio card will conflict with the network card when the network does it's periodic handshakes with other networks. Usually this is from the result of a bad drive from either one of the two.
I have video/sound coming from HDMI one and Audio only on HDMI port 2 and get the dropouts.. I will have to tryout the new update 1.61 to see if it fixes the dropout problem..
post #401 of 923
I'll test tonight with IR2 after update.
post #402 of 923
Vers. 1.61 firmware fixed a BD compatibility issue I've been fighting with CASINO the movie. Panasonic said it was a bad disc....
post #403 of 923
so just to clarify does that casino bd work fine now?
post #404 of 923
BDT350 Firmware has just been updated to version 1.61:
I tested Iron Man 2 using main HDMI to 65VT25 and second HDMI (audio only) to Pio SC-07 with bitestream selected and I am glad to report that audio dropouts now seem to be a thing of the past. I didn't watch the whole movie thoough, only the first few chapters...
Thanks Panasonic for that fix! Now please fix that unstable Blur Reduction option and the 96Hz false contouring issue on the VT25 and you'll make a lot of happy campers!! Think of all that free publicity you will get!
post #405 of 923
Yes, Casino BD is now working with the v .61 firmware.
Used to lock up most Panny BD players just before loading the menu. It still takes a bit to load... but give it an extra moment and it will load.
Sorry for the confusion. I've been dealing with Panasonic Customer support for past several days, when all I asked was if they knew if there was a compatability issue. They never answered, they just kept telling me to try different things...
post #406 of 923
^^^ I own Casino BD and I do remember that main menu screen taking awhile to load. I haven't played it yet on my BDT-300. Watched The Last Of The Mohicans last night and happy to report no droputs while listening to the DTS-MA HD track.
post #407 of 923
well this is great news i thought i would have had to bring back this player thanks god i dint have to cause the processing this does looks truly amazing.
post #408 of 923
Bravo and congratulations Panasonic, for fixing the dropout problem! I've had no issues since the 1.61 upgrade.
However, I am now getting odd dropouts when viewing 3D films. Both the audio AND video sporadically drop every now and then. Has anyone tested 3d films? I can't really test this issue much since there's a lack of 3d movies.
post #409 of 923
what movies exactly...cause i will try once i get home...
post #410 of 923
All I've tried on 3d is monsters vs. aliens and cloudy with chance of meatballs.
post #411 of 923
ok so i have cloudy with a chance of meatballs but not m vs a i will watch it tonight
post #412 of 923
Got my 350 a couple of days ago and the Optima BG-ZD101 DLP Link glasses came yesterday. All I can say is Holy #$%^. At first, I had my Samsung HL67A750 in the incorrect mode 1 and was not impressed, even though I was getting a slight 3D image. I thought, "Oh well more money down the drain". Eventually, I figured out my error. Yikes, night and day. Incidentally, you need to be in 3D mode 2 on the TV.
So far, I've only watched the Panny Demo disc and Cloudy With a Chance of Meatballs 3D. And a couple other BD discs like Apocalyto and Hell Boy II. No audio dropouts. I didn't expect any. I'm on Firmware 1.61 and I'm not running to a receiver. I'm in the market for a new receiver.
I must say the DLNA capabilities of this player sucks. It's certainly no substitute for the PS3. Once, I determined this, I regretted getting the 350 instead of the 300. But, upon further investigation, I find I got my 350 for the same price as the 300.
So, if you've got a slightly older Samsung (or Mitsubishi) DLP TV with 3D gaming capability, this player works great.
post #413 of 923
I just picked up the Panasonic DMP-BDT300 today after finding a deal I couldn't pass up, just over $204 including tax and 2 year replacement plan from Ultimate Electronics. Of course this was a display model, but it is in mint condition and includes remote, all accessories and box.
The reason I was looking to get this model is because I recently upgraded my display to a new Mitsubishi DLP and wanted to go 3D eventually without having to rely on the Mitsubishi adapter, and to ensure compatibility with my Onkyo receiver when doing 3D and lossless audio, even though it has hdmi 1.4.
This replaces my Samsung BD-C6900, has anyone compared the BDT300 to this? Since I have both at the moment, I might try to compare PQ at least but I am guessing it would be hard to tell.
post #414 of 923
I also have the 300 but like the BD35 model better because of it's speed in ejecting tray and loading the movie. I'm thinking that maybe the 300 got slower because of all the network stuff added to it.
post #415 of 923
My first 3d blu-ray player was the BD-6900. My experiences with it were not great. It had a very fast loading process but was notoriously buggy. The player would constantly freeze. Despite having brand new batteries in my remote control, the samsung bd-6900 had a poor receiver and I constantly had to repeatedly tap the same button on the remote. As far as video, the bd-6900 ran remarkably well though. The audio was a different story. If you have an Onkyo receiver, it has been well known that the bd-6900 and onkyo receivers have handshake issues when playing Dolby True-HD or DTS HD-Master to the receiver. The blame is on the BD-6900 as other blu-ray players work fine with the onkyo.
That was the main reason why I got the BDT300. It's a far better player. Yes, it does have some flaws of its own but they are more bearable to stomach than the BD-6900. Honestly, I don't think you'll be seeing a perfect blu-ray player for a few years. The technology is still rather new in the market.
post #416 of 923
I purchased the 350 model about a week ago and have watched Avatar and Iron Man. This unit has a great picture and the sound on both video and music is great.
However, the problem is that when watching the movie, the video will drop out (audio is still proceeding) from 2-5 seconds.
The 350 HDMI out (i tried both the main and the sub) is connected to a denon 3310ci (with monster hdmi) which is then fed to a Mits 65833 TV
(with audioquest hdmi). There were about 20 drop outs on Avatar alone.
When replaying the same scenes the drop outs don't re-occur either so this seem like a hdmi handshake issue.
I have update the firmware to 1.6 on the 350 and the denon is also up to date.
The 350 replaced a Samsung 1400 Blu-ray play (about 3yrs old) and I did not have these drop outs.
Over the next few days I will try connecting the 350 directly to the Tv.
Has anyone had an issue with the 300/350 and video drop outs? If so, are there any suggesstions to fix.
post #417 of 923
No, some of us were having audio dropouts on certain movies prior to 1.6 but I haven't had any video dropouts. I have the 300 but haven't tried Avatar since I'm waiting for the 3D version to come out.
post #418 of 923
How many are you using the 300 model on a Mitsubishi DLP. Do you like what you see? Are you having any problems with the player and the checkerboard out put?
I am looking into getting this player for my WD-65835 DLP. Since I found out that Oppo new 93 3D player will not do checkerboard output. Any info would be grat!
thank you,
Daniel
post #419 of 923
thank you,
Daniel
I'm using the 300 with a Mits 73833 DLP. It seems to be working fine except I haven't tried any full-length 3D movies but only the samples that came with the 300 and the 3D adapter. Also, I'm not using the adapter right now but am connected from the main on the 300 directly to the TV and the sub on the 300 to a Denon 2311ci and using only the 3D emitter with the 3D glasses. I can only watch 3D BD movies and no other content that is 3D until I get a HDMI splitter that works with 3D.
post #420 of 923
thank you,
Daniel
I use a Samsung DLP with this player and it works great with no ghosting with the 10 Blu ray 3D discs that I have. So you should have no issues since they are similar type of televisions.
