AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Official Panasonic DMP-BDT300/350 Owners Thread
Official Panasonic DMP-BDT300/350 Owners Thread - Page 24
post #691 of 923
Originally Posted by Razvanel View Post
I have the BDT300 and the bottom right of the player gets warm even when the player is turned off, anyone else noticing this?
R
I also have the 300 and I don't notice this.
post #692 of 923
R
Do you have "Quick Start" mode on?
I don't have it on, but it does draw significantly more electricity when this mode is enabled and may heat up the unit?
post #693 of 923
'Quick start' mode is indeed On. I'll turn it off and see what happens but I am curious if you guys experience any warming of the bottom right when the Quick Start is on On.
post #694 of 923
not on mine and I use it everyday watching movie on netflix.
post #695 of 923
Does anyone know where I can get an enhanced firmware upgrade for this player except *****************? I got duped buying this player on E-bay thinking it was a US model and now I can't return it. I know I'm missing out on other features (VUDU/ Netflix I believe), and who knows what else. All I really really need is to play my Region 1 DVDs. Any help would be appreciated.
post #696 of 923
Do the 300/350 have speaker distance and level matching menus in set up which the manual doesn't refer to?
post #697 of 923
Originally Posted by Subway Play View Post
My BDT300 has some problems on Blu-ray playback after upgrading 1.61 firmware. Is it possible to downgrade to previous 1.51 firmware? Thanks
I'm catching up on this thread. In case you didn't get a response back in November to your post on page 16: I'm investigating firmware reversion possibilities due to reports herein that 1.61 gimped the speaker level calibration.
My understanding is that the only way to revert to prior firmware is to send the player back to Panasonic.
post #698 of 923
Anybody have problems viewing Crank2 on BDT350. It loads and gets stuck with a triangle on screen and can't get past it, shows only partial screen of previews with the triangle froze on the screen? I have uptodate firmware??
BDT350 connected to Onkyo 875 via HDMI, then HDMI from Onk to Panasonic 65VT25.
Hurk
post #699 of 923
I have just bought a display unit from best buy and found when I got home the tray is locked. is there a key sequence that i can press to reset this?
post #700 of 923
Hurk
Try putting in an SD card in the player if you don't have one.
S~
post #701 of 923
Elaborate please? The player powers up fine, shows you the home screen, you press drawer open . . . and what happens? Is there an error message onscreen? Look closely at the front of the player--is the tray jammed perhaps? Perhaps a disc was left in the player from the store that is now lodged?
post #702 of 923
Try simultaeneously pressing the "POWER" button on the remote and the STOP button on the deck. There is probably a disc still in it too!
post #703 of 923
Ahh found it. Page 32.
post #704 of 923
I will trade someone a DMP-BDT300 for a DMP-BDT310. The DMP-BDT300 has 7.1 analog audio outs and a component video out while the DMP-BDT310 does not. Both players have dual HDMI outs.
post #705 of 923
Re ^^
Given the issues with 1.61 and 1.73, you may want to mention what firmware your 300 is on?
post #706 of 923
S~
How will putting in a SD card fix my issue with Crank2?
post #707 of 923
Lionsgate titles are authored in such a way as to frequently require that an SD card be in place on players that accept one for the BD to even load. Odd/sad but true. I've seen this mentioned many times in many player threads. Why don't you try it and report back?
post #708 of 923
As PaulR.S. said. Lionsgate has a weird way of authoring discs. I've had to put an SD card into every player to get some or all Lionsgate titles to play, including Crank2. It was discussed in the Crank thread.
S~
post #709 of 923
I was able to successfully get Avatar in 3D Blu-ray using the UPC and a copy of the sales receipt from my BDT-DMP300. I did buy my player during the promotion period.
post #710 of 923
I tried it no change. It returned Crank2 however should have tried it in my BD 30. My BD350 was a hit and miss on playing other titles, most times no video just audio. I played titles that wouldn't work in my BD350 (Transporter 2)and in my BD30 and it worked fine. I then triedTransporter 2 in my BD350 with HDMI direct to VT25 and HDMI sub out for audio and it worked just fine. The BC350 Main out run through my Onkyo 875 had issues, even though it was not 3D video and Onk is not 3D compliant it still had issues. I guess it is the Onk compat issues with BD 350. I am in the process of replacing Onk to a 5008, awaiting delivery.
post #711 of 923
How did you do this? Do you have a link with more info?
Thanks for any help
Mark
post #712 of 923
Odd; thx for reporting back. "It" = I, as in it was a rental disc?
I think he means he was able to get the disc under the promo for the BDT100 (?), not that there was an explicit BDT300/350 promo. My understanding is that these players were discontinued (August/September) before the Avatar 3D BD was even "available" (December).
post #713 of 923
Thanks for any help
Mark
I filled out the DMP-BDT100 3D Blu-ray Avatar promotion Form and mailed in the UPC of my DMP-BDT300. I sent a copy of my sales receipt of when I purchased my DMP-BDT300 and the UPC from my player which I cut out of the box. I then mailed everything in to the Rebate Center. My MP-BDT300 was purchased during the rebate period that was applicable to the DMP-BDT100 players. I received my 3D Blu-ray of Avatar from UPS yesterday.
Basically, I did everything the rebate form requested except I sent in the information from my DMP-BDT300 rather than a DMP-BDT100.
post #714 of 923
How long ago did you send in the paperwork? Just curious how long it took to get your disc.
post #715 of 923
I sent it certified return receipt mail and they received it on February 7 and I received Avatar in 3D Blu-ray on March 2.
post #716 of 923
Thx for responding. Good turnaround time.
post #717 of 923
The 2011 Panasonic Blu-ray Players are now available and have added streaming capability. I hope that Panasonic will do a FW update for our players which will make as many of the new streaming services that are found on the 2011 models available to us. I am especially interested in having the new Netflix Interface. The new Netflix Interface allows users to search and directly add movies to their instant queue. It also allows select movies to be streamed in 1080p and 5.1 Dolby Digital.
Panasonic has been very good at supporting its customers in the past. I hope they continue this commitment to its customers by upgrading our players.
post #718 of 923
its dolby digital plus. its more then DD, but less then trueHD. the vudu on the panasonic 85 will do DD+. same with the new models. you should try and see if you can get vudu DD+ with it..try inception or toy story 3.
Jacob
post #719 of 923
Jacob
My Panasonic DMP-BDT300 will do Dolby Digital Plus over VUDU. You are correct, the new Netflix Interface on the 2011 Panasonic 3D Blu-ray players offers 5.1 Dolby Digital Plus on select titles. Even more reason for Panasonic to give us a FW upgrade. Our 2010 Panasonic 3D Blu-ray Players can definitely handle it based upon the current VUDU streaming.
post #720 of 923
The DLNA is also gimped in the 300/350 compared to the new 110/210/310.
