I have a pair of Polk RTi12 and a pair of Ascend Acoustics CMT-340SE. I use a Pioneer 1019 receiver to power them.
I tried to listen to both with different kind of music and movies that I have and found them to be similar sounding.
Both speakers have the same efficiency: 90dB
Polk's driver components are:
Woofer 3 - 7" Diameter Polymer Composite with Rubber surround
Midrange 2 - 5-1/4" Diameter Polymer Composite Dynamic Balance with rubber surround
Tweeter 1 - 1" Diameter Silk/Polymer composite dome
Specs: http://www.polkaudio.com/homeaudio/specs/recent/rti12/
Ascend's driver components are:
Woofer (2) proprietary 6.5 long throw polygel cone woofers w/phase plug, non-resonant polymer chassis, rubber surround, shielded
Tweeter (1) High-definition 27mm soft dome tweeter w/damping chamber and wide roll surround, ferrfofluid damped voice coil, wide dispersion faceplate, magnetically shielded
Specs: http://www.ascendacoustics.com/pages/products/speakers/cmt340m/cmt340mspecs.html
If cost was not an issue how should I go about zeroing in on the speakers. Polk is definitely more attractive.
-sks2131
-sks2131
