AVS › AVS Forum › Audio › Speakers › Power Selection/ speaker choice
post #1 of 4
So I've spent probably 100 hrs searching these forums, viewing sites, and reading numerous reviews. I've listen to quite a few too, though sadly my options on higher-end audio stores around be are sparse, so the purchase might end up occurring without the chance to test them in person(yes I know that's blasphemy to say here). Plus since I move to Hawaii in 2 months the waiting for in-home testing is limited. (yes Hawaii is nice, but option will be near non-existent there, and a lot of places don't ship there, or it'll cost more then the system to get it out there) But I digress. Questions:
I think I've preliminarily decided on a Paradigm 100's setup. To power it I was looking at AVR's (was debating on separates but think I'll go avr, unless someone know a perfect separate pair for the setup) and was thinking about the Denon avr-4810ci. (yes I know there's no coded material but wanted to go 9.x route., reads: speaker addict). Denon's are rated 135/ch, but I believe that's tested at 2chs running, unless I miss understood. I was therefore going to add a emotiva XPA-3. I wanted to make sure I could do this since looking at the manual I saw "When speakers have been connected to pre-out terminals, do not connect speakers to speaker terminals." So will this work? Also, I've seen a few mixed mentioned of this, but is it recommended to biamp w/ these 2 different sources, or to get a single amp capable of biamp by it self. Finally since the fronts/center will be biamped an concerning power input: I'm not sure I understand to suggested rating scheme. Why is max input less then suitable amp power range? Is this assuming you dont turn your 300watt amp up more the 2/3's?
Suitable Amplifier
Power Range 15 - 300 watts
Maximum Input Power 210 watts
Of course feedback on 1)speaker, 2)receiver and 3)amp selection is always very welcome-though may preference is 9.x arrangement w/ largest possible output (large space to fill, i tad concern since some ppl seem to think the paradigms arent quite the loudest speaker) w/o sounding like garbage of course, and I think my limit in the 7-10K range for everything.
So for the length and the 20 buried questions, I'm just getting to a time crunch and want to make sure I cross T's and dot I's before pulling the trigger. Thanks in advance, since this forum has already supplied plenty of initial info.
post #2 of 4
No input?
post #3 of 4
the way I read the spec's on the Denon 4810CI is 140 wpc with all channels driven - this spec exceeds the usual FTC "2 channels driven" requirement from the old stereo days.
Do not buy an extra external power amp until you have tried your setup in your own home. I assume you are considering the Paradigm Studio 100's....if so, those are very efficient speakers at 93dB, so powering them will not be a serious issue. I believe what they are telling you in their specifications is to limit the RMS amplifier output to 230 watts, while the speakers can actually handle short lived transients to 350 watts. But anywhere near those extremes for a normal home listening room and you are in "ear bleed" sound levels. (and even if your ears don't bleed, you will be functionally deaf in a few years anyway).
Paradigm and Denon are excellent manufacturers with superb products, you can not go wrong with either.
PS: what some "ppl" say has absolutely nothing to do with what YOU hear and enjoy with your own equipment, in your own home !
post #4 of 4
IMO you dont need a $2000 AVR for your speakers. Im not sure you ever need that much AVR. Other than that, im sure you'll be pleased with the studio 100's and they should play plenty loud
  Back to Forum: Speakers
