AVS › AVS Forum › Display Devices › Flat Panel General & New FP Tech › component under mounts?
post #1 of 6
First off let me apologize if this is in the wrong forum or has been discussed before. I tried the search here and Google and could not find what I wanted.
I am looking for something I can use to mount my DVD player, cable box, etc underneath of an occasional table. This one actually:
I am looking for something that I can attach to the underside of this and will hold my equipment, with minimal visibility of the "stand/bracket".
Something like this would be great, but that one is meant to attach to the back of a TV and not to the underside of a cabinet.
Any ideas or suggestions?
post #2 of 6
post #3 of 6
I would just install a shelf below the drawers, either out of wood (stained to match the table's finish or just painted satin black) or maybe a piece of 1/4" thick tempered glass. I had a local glass shop make a tempered glass shelf ($20) then installed it in the open area under my end table using four little shelf pegs like you find in unassembled book cases - you just drill a hole in the wood and the peg is a tight fit. I also used the L-shaped type to add wood shelves to a TV credenza at my workplace to hold the digital converter box. I got these pegs and brackets at my local hardware store.
post #4 of 6
Thanks Randy, I just might have to go that route. I was hoping there would be a clean solution already out there. Is an adjustable under mount bracket too much too ask?
post #5 of 6
Yeah I've looked at those, doesn't really match the look I'm going after.
Originally Posted by Matt L View Post
How about this? It mounts to the wall but should work.
or this:
post #6 of 6
Hey guys, just wanted to bump this because I finally got around to getting a custom piece of glass and building a shelf underneath of the occasional table.
Here is a picture of the completed project. I need to spend a bit more time hiding the cables but overall I think it looks good.
