Hi
My name is Alex and i'm newb newb newbie....but learn learn learning everyday.
Few months ago i bought my first projector. A native 720p - Epson 705HD. Its bright for movies but great for HD sports from the satellite...and i thinks its good for first projector...
While i'm deciding which screen paint to choose, how to get the paints (cause i'm from europe) and what material to use for the screens i've start thinking about curved screens. The projector can 13'-15' throw from the screen.
I was going to ask you what makes curved screens so special but I red some threads so i'll not lose your time.
I have a few questions so I hope you'll help me
Lets start with the room! The wall where i can place the screen is 3,80m width (12' or 15" aprox.). If i cut 20cm for black borders and some free space i'll have around 3,60 or 3,50m native width for the screen. So the difference between 2.35:1 , 2.37:1 , 2.40:1 will depending from the screen height right? So i'll have to learn a little bit more how to calculate the screen.
If i go with the curved screen i'll need from a anamorphic lens right? They are so expensive that there is no way the give so much money for that! I found DIY anamorphic solutions so what do you think about them? is it worth to make my own?
So simply
- can i use anamorphic lens with my 705HD projector and use it on curved screen?
- can i use anamorphic lens just on 2:35:1(2.37:1and so on) screen?
- and i know... if there is no anamorphic lens - there would be no curved screen and so i'll have to just thinking about 16:9 screen with masking... ;/
Alex
So simply
Alex
I need to purchase more then 10 prisms to get them for a good price... If I ask only two prisms the price for them will be something like 400euros. I dont know why is so expensive. May be they are mega superb turbo quality prisms....
However they told me if i purchase more then 10 the price will be under 100euros for a prisms....
