AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Official Samsung LNxxC630 Calibration/Settings Thread
post #1 of 800
Greetings,
I know there is currently an owners thread for the C630/C650 but I wanted to create this thread for people to post the best settings they have found for the C630 specifically.
Also, please include weather it is best settings for gaming or HD programming or sports or movies.
We will try to decide and pick the best ones for each category.
post #2 of 800
Originally Posted by sohitek View Post
Greetings,
yes finally someone post their settings
im a recent owner of a 46c630, and having some trouble playing online games via ps3. I currently tried game mode still lags, and hdmi/pc and have NO lag but picture quality is not so good with hdmi 1.
How come when watching my hdmi 2 comcast dvr and when i try to change the black levels its stuck to "normal" i want to change it to "Low". I could change it to "low" in my hdmi 1 connected to my ps3.
post #3 of 800
greetings,
i know there is currently an owners thread for the c630/c650 but i wanted to create this thread for people to post the best settings they have found for the c630 specifically.
Also, please include weather it is best settings for gaming or hd programming or sports or movies.
hd tv
natural
backlight 15
contrast 100
brightness 45
sharpness 70
color 35
color tone normal
size screen fit
digital noise filter low
mpeg noise filter low
film mode auto2
automotion off
post #4 of 800
Thanks Vegas, thats a pretty high backlight!
Do you do any gaming? Which settings do you use then?
Anyone else have any good settings for this tv?
post #5 of 800
You aren't outputting RGB from your cable box (HDMI black level is an RGB thing only), but are displaying Y Pb/Cb Pr/Cr instead. If you want to be able to play with the HDMI black level setting while watching TV you're going to have to turn it on via the service menu of the cable box. You get to this menu by (assuming you have the same comcast hd cable box i have) turning off the box, then hitting the menu button twice on the cable box remote. There are a number of items in here you can mess around with but I would be careful. Anyway once you turn on RGB mode you have access to the HDMI black level but be ready to rework your TV picture settings for RGB as it will probably look a bit different than it did with Y Pb/Cb Pr/Cr. Which mode is better in what situations is a different debate altogether. I'd love to know myself.
post #6 of 800
Are these settings for the C650 also?
post #7 of 800
Absolutely. The settings can be used for any Samsung set. it is just a matter of opinion on how the set looks. There is no right or wrong setting.
post #8 of 800
I have the LN55C630 which has the SQ01 Ultra Clear Panel glossy screen. Its designed to be used in dark rooms because ambient light reflects off the screen and gives off a rainbow effect as well. I have it in my bedroom which is very dark, so these settings are designed for a dark room. The smaller C630 TVs have the semi-matte screen so I can't guarantee my settings for those TV but who knows, they might be fine. The C650 models however have the same glossy panel I have so these setting should match up well. I use my PS3 as my Blu Ray player and gaming device. I used the THX option on the Terminator 2 Blu Ray for calibration and obtaining these settings.
PS3 Settings
Video Settings
BD/DVD Video Output Format (HDMI): Y Pb/Cb Pr/Cr
BD 1080p 24 Hz Output (HDMI): On
Display Settings
Video Output Settings: 1080p
RGB Full Range (HDMI): Full
Y Pb/Cb Pr/Cr Super-White (HDMI): On
TV Settings
Mode: Movie
Backlight: 6
Contrast: 100
Brightness: 32
Sharpness: 7
Color: 50
Tint (G/R): G50/R50
Eco Solution: All off
Auto Adjustment: Grayed out
Screen: Grayed out
Advanced Settings
Black Tone: Off
Dynamic Contrast: Off
Shadow Detail: 0
Gamma: +2
Expert Pattern: Off
RGB Only Mode: Off
Color Space: Auto
White Balance: All 25 (Don't have anything to calibrate this setting with)
10p White Balance: Off (Don't have anything to calibrate this setting with)
Flesh Tone: 0
Edge Enhancement: Off
xvYCC: Off
Picture Options
Color Tone: Warm 1 or 2
Digital Noise Filter: Off
MPEG Noise Filter: Off
HDMI Black Level: Normal (Grayed out)
Film Mode: Off
Auto Motion Plus 120hz: Off
Auto Protection Time: 2 hours
When I play PS3 games I switch the TV to Gaming Mode which is accessible via the Setup section of the Menu Screen. Once in Gaming Mode I changed all the picture settings to what I have above. The only difference should be the picture mode which can only be Standard.
Edit: When watching HDTV via the cable box I turn Dynamic Contrast to Low because I feel some shows look like they're missing a little pop. This hasn't seemed to cause any issues with ABL or floating blacks like I was afraid it would, which is great. Also make sure you're outputting the Digital Cable in Y Pb/Cb Pr/Cr not RGB for these settings.
post #9 of 800
I just ordered a 40" 630 today and I should be taking delivery on May 4th (hey, my birthday). I'm presently reading the owner's manual and I see that there are some excellent calibration features available in the user menu when in the movie mode. I think that's Samsung's 2010 new deal to keep us from messing around in the service menu. LOL
10p White Balance (Off / On)â– â– : Controls the white balance in 10 point interval by adjusting the red, green, and blue brightness.
Available when the picture mode is set to ✎✎Movie and when the external input is set to all input.
Some external devices may not support this ✎✎function.
Interval: Select interval to adjust.
Red: Adjust the red level.
Green: Adjust the green level.
Blue: Adjust the blue level.
Reset: Resets the 10p White Balance to its default settings.
Flesh Toneâ– â– : Emphasize
That's super. I'll be calibrating it with a Chroma 5 Colorimeter so hopefully I can come up with some good numbers. Remember, though, that every unit is different.
Buzz
post #10 of 800
Buzz
Nice, let us know what you come up with.
post #11 of 800
Buzz
Definitely let us know your settings! I have a 40C630 as well, version SQO2.
post #12 of 800
Hi everyone. Just ordered the LN40C630, my first HDTV, and I have some questions that might have 'duh' answers, or maybe not. I ask here instead of the main LNxxC630/650 thread because it seems more gamers are watching this one:
1 - Can you create custom display settings for different inputs? (Wii, Xbox 360, PSP via component, DirectTV box, etc). I read somewhere that the TV automatically detects the input in question, but I wanted to make sure. If so, how many 'customs' can you have?
2 - Can Game Mode be adjusted? I don't want lag, but I don't want a dark screen either, and some people have mentioned darkness as a Game Mode side-effect.
Can't wait to get this baby on Thursday I'll be sure to contribute my settings for the devices listed above.
post #13 of 800
1. You can customize 4 different viewing modes for each input. So ya you won't have any customization limitations.
2. Game Mode locks the picture mode at standard, so only one mode is available for customization, but it is indeed customizable. Turning on game mode locks out Auto Motion Plus 120hz however, but having it on would sort of defeat the purpose of game mode anyway.
post #14 of 800
Posted this in the regular thread.. seems more at home here.
Edit: This is for Blu Ray playback-
Hey everyone, just thought I'd chime in with calibration settings on my 46C630 using a Sony BDP-360 Blu Ray player.
I'd been a bit disappointed with the black level on the 630 as the picture was a bit washed out and I really didn't want to set the Dynamic Contrast too high. I went into the Blu Ray player's settings and changed the color space from Auto (which was a YCbCr space) to RGB (0-255). This enables the HDMI Black Level on the 630 to be changed from Normal to Low, which in my opinion makes a world of difference. Here are my settings with this RGB colorspace:
Mode: Standard
Backlight: 10
Contrast: 85
Brightness: 47
Sharpness: 30
Color: 57
Eco Solution: All Off
Advanced Settings:
Black Tone: Dark
Gamma: +2 (brightens things up just a bit)
Color Space: Native
Picture Options:
Color Tone: Warm1
HDMI Black Level: Low
AMP 120hz: Off
All settings not mentioned are default.
Any feedback is welcome..
post #15 of 800
Thanks Video, for the BR settings. Can you post your normal TV viewing settings as well? Also, as a newbie with this et, is there a way to lock in my settings for TV, DVD/BR etc. so that I can easily switch from one to another without needing to manually set again?
post #16 of 800
Hey-
I would but I don't have my cable box hooked up to this one. This is strictly for Blu-rays and gaming in the basement.
I'm pretty sure this set saves settings for each input.
post #17 of 800
Originally Posted by Videodrome View Post
Hey-
Yep... it does. Figured that out tonight.
post #18 of 800
Anyone else with an LN55C630 or C650 wanna post their settings? I keep going back and forth on what I've got going for both PS3 Blu Ray and HDTV Cable Box viewing.
post #19 of 800
My 40" 630 arrived today. The panel is an SQ02 as expected which is what I wanted as it will be hanging on the wall of a naturally lighted very bright room.
Attachment 174619
I took a look at the service menu and it doesn't seem to offer anything for calibration.
Attachment 174620
Fortunately the user menu has a bunch of options so calibration can be accomplished from there.
Bear in mind that I'm new to calibrating with anything other than a disk so I'm getting my feet wet with an X-Rite Chroma 5 Colorimeter and ChromaPure software.
The factory setup for the TV input "looks" very nice so I'm putting that on the back burner. I did some calibration work using HDMI 1 in the Movie Mode with HD images from ChromaPure that I had burned on a DVD. I didn't have too much time available today and I'm sure I can improve greatly on my results so far. One thing is for sure, the present picture looks much better than the factory settings (sky high blue) and I'll post as my numbers get better.
Attachment 174621
Attachment 174622
If anyone is interested in what my numbers are so far please chime in and I'll post them as soon as I can.
Buzz
post #20 of 800
Mode: Standard
Backlight: 10
Contrast: 85
Brightness: 47
Sharpness: 30
Color: 57
Advanced Settings:
Black Tone: Dark
Color Space: Native
Picture Options:
Color Tone: Warm1
AMP 120hz: Off
if you have the bluray player set to output RGB 0-255, then the tv should have the HDMI Black Leval set to 'Normal'
post #21 of 800
^Yup. If you use RGB 0-255 and set HDMI Black Level to Low, you'll be clipping black (0-15) and white (236-255) levels. If you want more pop, try playing around with the brightness (black level), contrast (white level) and gamma . Try upping your contrast (usually Samsung's can be set near 100 without affecting the PQ too much) then try playing around with the brightness and gamma settings as well. Not sure how the C series are, but with older Samsungs, setting the gamma slider higher has the opposite effect on the gamma reading (higher setting on the slider gives a lower gamma reading). A higher gamma reading will have poorer shadow detail but it will give more pop. So if you move the gamma slider lower, it should give you more pop. Having a basic setup disc is essential if you want to at least get the contrast and brightness set properly.
post #22 of 800
Attachment 174619
Attachment 174620
Attachment 174621
Attachment 174622
Buzz
I'm very interested in what numbers you're getting.
post #23 of 800
2nd calibration from the neophyte. Better results although red and magenta are a bit high. I watched Fargo on DVD and the picture looked very good although I 1) wish I had a movie I knew well so I could comment on relativity, and 2) I don't have any Blu-ray discs on hand (will tomorrow though).
Post calibration black level measured .014
Source: HDMI1
Mode: Movie
Backlight: 10
Contrast: 90
Brightness: 48
Sharpness: 7
Color: 63
Tint (G/R): G50/R50
Advanced Settings
Black Tone: Off
Shadow Detail: 0
Gamma: +1
Expert Pattern: Off
RGB Only Mode: Off
Color Space: Custom
White Balance:
Red offset 26
G 24
B 22
Red Gain 32
G 24
B 22
10 Pt white balance on but didn't use (yet)
Flesh Tone: 0
Picture Options
Color Tone: Warm 2`
Auto Motion Plus 120hz: Standard
Attachment 174671
post #24 of 800
Yep, I read a bit about this and changed the Colorspace back to Auto and was able to get a comparable picture by lowering the backlight down to 5.
post #25 of 800
Mode: Standard
Backlight: 10
Contrast: 85
Brightness: 47
Sharpness: 30
Color: 57
Advanced Settings:
Black Tone: Dark
Color Space: Native
Picture Options:
Color Tone: Warm1
AMP 120hz: Off
A couple of comments.
If you have a DVD with the THX logo, you should be able to find the THX Optimizer inside the DVD menu. You can use it to adjust your Brightness, Contrast, Color and Tint settings. In addition, there is a color bar with Blue, Red, Yellow, Green, Magenta and Cyan that you can use to adjust each individual color in the color space (using the "CUSTOM" setting). Doing this will make a world of difference to your picture quality.
Also, if you are having problems with the black level, I noticed that you have your Backlight at 10. There's your problem. Drop the backlight and your black levels will dramatically improve. I recommend 5 or 6. Trust me that its still plenty bright enough, even for daytime viewing.
Also, Dynamic Contrast settings can add just that little bit of extra "pop" to your picture. Experiment with the various settings to see if you like any of them. I don't recommend putting it at the high setting unless you watch a ton of animation (Dynamic Contrast makes animation pop like nobody's business!) as high mode makes live action material look garish. Low or Medium settings can work fine depending on your sources. I have mine set to Low and everything looks good from HD cable, to DVD to Blu Ray.
Also, you may want to experiment with your Sharpness settings. LCD is so sharp and crisp, most LCD owners around these parts turn it all the way down to 0 to help reduce some of the artifacts associated with the heavy compression used with Cable or Satellite. I've tested my own LCD at various Sharpness settings and determined that there is very little difference between 0 and 30 with good quality DVD and BD sources and dropping the Sharpness to 0 does help (somewhat) with Cable sources without making the picture look too soft.
post #26 of 800
Well dang, I wish I would've read this before posting my comments!
post #27 of 800
actually, the important bit of what you quoted was the part where he said that if you have your bluray player set to output RGB 0-255, you should set the tv's HDMI black level setting to "normal"
post #28 of 800
Source: HDMI1
Mode: Movie
Backlight: 10
Contrast: 90
Brightness: 48
Sharpness: 7
Color: 63
Tint (G/R): G50/R50
Advanced Settings
Black Tone: Off
Shadow Detail: 0
Gamma: +1
Expert Pattern: Off
RGB Only Mode: Off
Color Space: Custom
White Balance:
Red offset 26
G 24
B 22
Red Gain 32
G 24
B 22
Flesh Tone: 0
Picture Options
Color Tone: Warm 2`
Attachment 174671
Nice, I'm gonna try out your settings (save for the standard AMP120, that'd make me vomit) tonight!
post #29 of 800
There will be some changes sometime between now and the end of the weekend when I fix the red and magenta problems. Meanwhile, it's much better now than with the factory setup.
Buzz
post #30 of 800
Buzz
can you show us your color space settings? thanks
btw you can turn on dynamic contrast on low and have a little better colors without losing any shadow detail.
