How do we set the overscan? I have the LN46C630
I want to set my tv to 1:1 pixel mapping
I agree...Under Basic Patterns use #1 and 3 for brightness and contrast. 17 & 234 are the only numbers you need to know for those two patterns. If you have a blue filter or if your TV has a blue only mode you can use the flashing color bars for color saturation and hue. This is all any calibration disc is good for except two things: 1) sharpness which is a moot point when viewing high definition, and 2) white and primary color clipping - the AVCHD disc has a nice pattern for checking this.
I'm stuck with my panel (past 30 day return period), but the good uniformity and black levels prompted me to keep this set regardless of differences between the panel types. Either way, if you're looking for a sharper picture, perhaps the AA panels are the way to go.
But buzzard, do you have the > shaped pixel structure? I'm betting you do as every single 40C630 SQ02 panel mentioned on this thread (including mine) has that structure. Supposedly it's the older structure. So if yours is very sharp, and mine is pretty sharp by my eyes, then there is another variable here (manufacturing plants getting different SQ02 panels?) that's causing this difference. Or it's just the usual: sharpness is subjective.
Had a chance to try out SQ03 and compare to AA03 today. OMG! SQ03 must be the biggest fail of electronics I was ever "fortunate" enough to bring home. If you ever wondered what the lakes of swirling pixels dancing all over the screen would look like... well treat yourself with an SQ03. It's unreal. Often greenish unreal.
Called Samsung to ask them about it.. and she was like, can you run diagnostics - which shows a static image. Stable enough. "Right, well, sir, there is nothing wrong with the TV". Sheesh... that was a test, static image of the sky and the beach. Must be a torture to an LCD. Put some moving pictures and there you are again, treated with swirly chaos of colors. What is that?!!! AA03 is simply... exemplary in comparison. |
