My latest settings after a more careful calibration:
these apply to SQ01-2010 version panels (you can try them with others, if something internally adjusted the panels to match it might sort of work out for other panels, who knows)
they were carried out on a 55C650 using DTP94 sensor and Calman
[my panel has slightly different shading every other scanline, it seems like the middle and bottom and green sub-pixel often show a different shade FOR THE SAME COLOR ever other scanline, very weird, no idea what the heck is going on, never heard of static dithering by every other scanline since that would be too easy to notice and not so effective, something weird, if anyone else has an SQ01-2010 set that does or doesn't do please report it in the other thread I posted, trying to find out whether only a few, many, or all are doing it; if some don't then perhaps it might slightly alter the required settings from what is posted below]
Mode: Movie
Backlight: 2-4 for a dark room; 4-8 for typical room; 8-14 for a super bright room with a ton of direct sun streaming in, although it is up to your eyeballs in the end and what they like and can handle
Contrast: 98
Brightness: 44 (oops this really needs to be 46 now but that reacts with other settings maybe use 45 for now until I go fix it)
Sharpness: 0
Color: 52 (overall it is a touch too saturated with 4 out of 6 primaries and secondaries but it's tricky to match it work out perfectly between this and other stuff)
Tint: G48/R52
Eco Solution: Off
Black Tone: Off
Dynamic Contrast: Off
Shadow Detail: 0
Gamma: -1 for dim room viewing; 0 for bright room viewing
Felsh Tone: 0
Edge Enhancement: Off
Color Tone: Warm2
Digital Noise Filter: Off
MPEG Noise Filter: Off
HDMI: as needed Low if you send it 16-235 and Normal if you send it 0-255 (usually you need Low for stuff like external blu-ray standalone players and cable boxes and Normal for PCs)
Auto Motion Plus 120Hz: Off (although you can try it, up to you)
Source Edit Name HMDI1/DVI: DVI Devices
BD Wise: Off
Color Space: Custom
Red: R39,G6,B0 (can't get it quite right, can't remove enough blue again)
Green: R36,G51,B0 (falls a fair amount short of ideal max saturation point, once again they don't let you remove enough blue balance)
Blue: R3,G8,B50
Yellow: R56,G50,B0 (there is now way to quite extend it out far enough, can't remove enough blue)
Cyan: R23,G52,B47
Magenta: R34,G6,B51
White Balance:
R-Offset: 28
G-Offset: 23
B-Offset: 22
R-Gain: 23
G-Gain: 23
B-Gain: 28
10p White Balance:
gets a pretty even gamma 2.35 from 10%-90% combined with Gamma: -1 which is good for evening or night viewing (some say you can even go to -2 for viewing in a total black room but you might prefer -1 anyway; gamma 0 is better for broad daylight, well lit room)
1: R5,G7,B3
2: R0,G2,B3
3: R-4,G-3,B-4
4: R-3,G-2,B-5
5: R-2,G-1,B-4
6: R-1,G0,B-4
7: R1,G4,B0
8: R0,G3,B0
9: R1,G1,B1
10: R1,G1,B0
those should be pretty good i think
Calibration done in a pitch black room set to backlight 6 (to give it a bit more light to work with)
ColormetreHFCR claims 5700:1 CR
Calman gives 3900:1 CR
anyway i'm sure there are different combos that can get even better sinc esome settins back react against others but it takes a long time to figure it all out
EDIT: oooops, damn, forget to check the brightness setting and 44 doesn't quite work for these WB settings it chops off the last few black tones, 45 or maybe 46 is needed not 44 but tha tmight then back-react a little from the other settings. but using 45 for brightness with the above shouldn't mess it up too much although it won't be quite perfect.
Also I think I can go back and find a way to reduce the saturation hue shifts a bit, currently red is shifting in hue too much as the saturation of red decreases
anwyay it's a start
